 how do i aply sig covering >
Old 04-03-2009 | 01:41 PM
Default how do i aply sig covering
i have purchased sig coverall but due to shipping hasards they can not ship me the stix it and my local hobbie shop wont buy it eather. sooo how do i aply the coverall without the stix it i know you can use dope but dont understand it and is there any othere ways or site anyone can show me any help would be nice.
Old 04-03-2009 | 02:21 PM
pmw
Default RE: how do i aply sig covering
BalsaRite will work just fine. The difference between the formula for fabric covering vs. film covering is the viscosity. The fabric formula is very thick. I don't like the fabric formula and end up thinning it with acetone. So, I recommend the film formula. There are other exotic methods such as white glue or thinned epoxy, but the best way is either nitrate dope or BalsaRite.
Paul
Old 04-03-2009 | 07:44 PM
Any of the adhesives should work that are comparable to stix-it. Balsa-rite and so on. Some have even used water based polyurethane to stick it down and to fill the weave. I havent so cant comment on how it works, do a search for that. I thin the adhesive with acetone also. Remember that not all acetones are the same. The acetone at Lowes (Crown brand) is too hot and turned my stix-it to cottage cheese. The acetone from Home Depot worked fine for me, not quite as hot. Just paint the adhesive coat on the perimeter where you need to stick it down. I just lay the coverall down and use a small brush to paint acetone on top of the fabric, hold it to the frame for a couple of seconds and it will bond. The acetone reactivates the thinned adhesive. Do that on the whole perimeter. Then I use the iron to slowly shrink it but not too tight, I leave it a little loose. Then paint the perimeter again with the fill coats, only on the perimeter. This will give a good bond. Trim the excess fabric and finish shrinking the interior. Remember, coverall can shrink A LOT. Paint the interior with the fill coat and you're good. If you shrink everything tight before the perimeter is finished, it will loosen up when you paint the fill coat along the perimeter. You cant get a better finish in my opinion. Will never sag unless the internal frame is all crunched up. This is just one way to do it and it goes faster than it sounds here.
Edwin
Old 04-03-2009 | 07:48 PM
Wouldnt you know it. Heres the thread on applying coverall with wbpu.
Edwin
http://www.rcuniverse.com/forum/m_8088219/tm.htm
