CEN Racing This forum is to discuss all CEN Racing products.
Pics
Old 03-08-2006 | 06:55 PM
  #101
Default RE: Pics
I have been looking for a heat sink head for my mt2 and can't find one. Can somebody tell me where I could find one? That would be alot of help, B/c I live where it is hott most of the time. Also I was wondering if anybody knew how I could raise my mt2's ground clearance. I lifted the ground clearance a bit by ajusting shocks. But when I go out for a spin the dogbone drive shafts fly off. Like there not long enough to handle the extra ground clearance. Can you help me? Maby tell me where I could find longer dogbone drive shafts? Also, Has anybody been able to put t-maxx wheels on there mt2? If so Can you please help me with doing it? I would like to add some big t-maxx tires to jack it up some.
Old 03-08-2006 | 07:36 PM
  #102
alvinl's Avatar
Default RE: Pics
I jacked mine up a little bit with the ARO shock towers. They give you a lot more adjustment than the stock towers. But I have not had a problem with the shafts falling out. My problem has been broken diff cups. For the tmaxx wheels, you can get the ARO wheel stops, or since you are having problems with the shafts anyway, do the Swift buggy shaft conversion (compliments of Rolland). Also, you can get some new shocks. CEN makes an aluminum upgrade shock or get a set of 1/8 buggy shocks. Here are some links for you:
Hex Adapters - http://www.rcuniverse.com/forum/m_3532034/tm.htm
Swift Shaft Conversion - http://www.rcuniverse.com/forum/m_38..._2/key_/tm.htm
ARO Shock Towers - PM 'Dr Honda', I cannot find the thread where we ordered them. Here is his page: http://www.rcuniverse.com/community/...1&memid=170219
Old 03-08-2006 | 07:58 PM
  #103
azzman's Avatar
Default RE: Pics
About jacking the FF up, better to do the shaft mod cause the shafts wont handle it jacked up too much, as for the shafts flying out try screwing your hub pivot balls in further.
Old 03-13-2006 | 09:05 AM
  #104
Default RE: Pics
Nemesis 7.7
ID:	425303   Click image for larger version
ID:	425304   Click image for larger version
Old 03-13-2006 | 05:04 PM
  #105
Default RE: Pics
Nemesis 7.7
Old 03-13-2006 | 05:05 PM
  #106
Default RE: Pics
Nemesis 7.7
ID:	425486   Click image for larger version
Old 03-13-2006 | 10:37 PM
  #107
Dr Honda's Avatar
Default RE: Pics
Thanks for the advertisement alvinl.
I’m surprised… all those pictures, and no ARO shock towers??
Old 03-13-2006 | 11:16 PM
  #108
Default RE: Pics
ORIGINAL: Dr Honda
We can't have that now can we... I'm still waiting for my buggy shafts and romulins but I'm getting soooo antsy because I've put all kinds of upgrades in it but have no stock shafts that arent broken so i can't drive it
ID:	425676   Click image for larger version
ID:	425677   Click image for larger version
ID:	425678   Click image for larger version
Old 03-15-2006 | 08:10 PM
  #109
Default RE: Pics
nice and shiny shock towers
Old 03-15-2006 | 09:12 PM
  #110
Default RE: Pics
I like the battery / reciever box. Its the little things that make the difference.
Old 04-10-2006 | 06:33 PM
  #111
poor judgement's Avatar
Default RE: Pics
cmon guys - what u been up to? lets see some more pics!
Old 04-10-2006 | 07:24 PM
  #112
Default RE: Pics
I'd love to but im still waiting for parts. it takes FOREVER to get parts from the US to canada sometimes.
Old 04-11-2006 | 10:23 AM
  #113
Default RE: Pics
Not much new going on, waiting for the monsoons to stop[:@]
But here is my four stroke Genesis' evoloution in chronological order:
ID:	443417   Click image for larger version
ID:	443418   Click image for larger version
ID:	443419   Click image for larger version
ID:	443420   Click image for larger version
ID:	443421   Click image for larger version
ID:	443422   Click image for larger version
ID:	443423   Click image for larger version
ID:	443425   Click image for larger version
ID:	443426   Click image for larger version
ID:	443427   Click image for larger version
Old 04-11-2006 | 10:26 AM
  #114
Default RE: Pics
I am toying with the idea of messing up a Matrix too.
ID:	443439   Click image for larger version
ID:	443440   Click image for larger version
ID:	443441   Click image for larger version
ID:	443442   Click image for larger version
ID:	443443   Click image for larger version
Old 04-11-2006 | 12:09 PM
  #115
Default RE: Pics
ah, now that is the daddy. loads of respect for what u have done there, my meddling has given me enough headaches, ur beastie must have been much worse/harder/more fun to get to work.
dare i ask... what plans do u have for a matrix?
forgot to ask... do u have any detailed photos of the valve arrangement on ur pneumatic wheels n tyres? something like that could very well work for my beach sessions on my truck.
Old 04-11-2006 | 01:14 PM
  #116
Default RE: Pics
No detailed pics with me. I found small inner tubes on-line but don't have that info here either, can get this afternoon. Basically I just drilled a hole in the rim for the 90 degree valve stem to fit through and added lead weights to try and balance the tires. I never did get them balanced completely and I did have high speed wheel hop but it worked good enough for bashing. The cool part was being able to adjust the pressure for different situations: full of air for big jumps and hardly any air for cornering.
As for the Matrix, maybe a smaller twin or large single four stroke laying on it's side. The cooling would be more of a problem to fix with the engine being so low. hmmm, Maybe two rotory engines..
Old 04-11-2006 | 02:32 PM
  #117
jombo's Avatar
Default RE: Pics
here are mine, genisis and nemisis. after playing with these trucks, i dont think i will be taking out any other trucks to play with.
ID:	443516   Click image for larger version
ID:	443517   Click image for larger version
ID:	443518   Click image for larger version
Old 04-11-2006 | 04:16 PM
  #118
Default RE: Pics
very nice trucks, what i have been doing? sitting waiting for the spring flood to stop[:@]
Old 05-02-2006 | 09:11 PM
  #119
Default RE: Pics
This is the Genesis w/ a new set of Jumbo Swamp Kongs and aluminum beadlocks. Havent been able to run in a long time due to moving. She's about ready for some bashin though!!!!
ID:	454856   Click image for larger version
ID:	454857   Click image for larger version
ID:	454858   Click image for larger version
Old 05-03-2006 | 02:55 AM
  #120
Banned
Default RE: Pics
[link=http://homepage.ntlworld.com/robert.palmer97/CEN%20Test%20Pages/Mods%20to%20make%20a%20CEN%20semidecent.htm]working link for poor judgement.. yw[/link]
here s a working link for poor judgement, just copy and paste this into your sig area..
Old 05-03-2006 | 12:42 PM
  #121
Default RE: Pics
ooer - did the other one not work? i thought it was ok... still learning a bit re websites, uploadin etc, but i thought that was ok - cheers for the heads up on that - i will investigate the troublesome bugger...
hmmm just tried the existing sig link - it works fine for me... very odd.
Old 05-03-2006 | 06:01 PM
  #122
Default RE: Pics
huge truck smack, looks very nice
