Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Air Hogs Aero Ace!
Old 03-13-2007 | 07:30 PM
  #4626
Banned
Default RE: Air Hogs Aero Ace!
probably the AA bipe. what is the stir stick mod? are they those struts?does it help in performance?
Old 03-13-2007 | 11:08 PM
  #4627
FERNDALE AIR FORCE's Avatar
Darticus, the bipe flies in the smallest area.
3D, the pic of the plane with struts is the single stir stick mod. For a more stable airplane there is the double stir stick mod. The plane is much faster and can turn quicker in both mods. The mono mod without canards or stir sticks is a good way to meet your neighbors. Most of this is written up on the aeroace mods thread. I check this thread at least once a day, if you have a question please ask. For your edification, I am working on a lighted mono, with lipo port, right now. Have fun,
Tim
Old 03-14-2007 | 06:17 PM
  #4628
Banned
i converted my AA to mono but i dont understand how more weight and drag could help it?
Old 03-14-2007 | 06:19 PM
  #4629
Banned
Also.......whats better the single stick or double stick mod?
Old 03-14-2007 | 06:38 PM
  #4630
Neurotex's Avatar
ORIGINAL: i live for 3D
Drag is needed for lift.[link=http://en.wikipedia.org/wiki/Induced_drag]induced drag[/link]
Old 03-14-2007 | 07:34 PM
  #4631
3D, the single stir stick is "twitchier" My best one had a peice of shrink tube on the tail boom, that changed the cg just enough that the plane would go almost straight up out of a dive and do stall turns. Since the wing is only attached at the center, it allows more flex, and more "tricks" The double stir stick is much more stable and forgiving in flight. It will not turn as hard and fast, nor will it climb as fast as the double (especially the one with the tail boom tube shrink tubed). But it is much more predictable. I don't think one is better than the other, they both perform well, but fly different.
I think the most important mod is the turn w/o throttle mod. And if you think you are going to buy more planes, the three channels mod. If you are going to do both, do the three channels first then the turn w/o throttle.
The lighted plane has been retrofitted for the big charger, and the led's mounted differently( is that a real word?). Pic's later, Tim
Old 03-14-2007 | 09:20 PM
  #4632
Banned
i have a hobbico field charger that i use for my glow planes that can charge lipo. what is needed to make the change? is there any site selling upgrades for the aeroace?
Old 03-14-2007 | 10:31 PM
  #4633
3D, I'm using a triton jr. I open up the plane, wire a micro deans directly to the battery. I port the plug through the windshield. Your charger needs to be able to charge at only 100 mah. I'm using wrapping wire to keep the weight down. I'm getting ready to shoot pics of the lighted plane, I'll shoot a couple of the plane I just put a battery in as well. It will show how I set up the charge rig.
Speaking of batteries, I'm getting ready to order more batteries. If anyone wants some please let me know. Last time around I charged $4 each, this time I have to charge $5 because paypal is taking a chunk.
Tim
3D and anyone else interested, here are pics of the plane I'm working on with the charge port, and a pic of the lighted ace that I re-worked last night. Tim
ID:	642426   Click image for larger version
ID:	642427   Click image for larger version
ID:	642428   Click image for larger version
ID:	642429   Click image for larger version
Old 03-14-2007 | 11:40 PM
  #4634
OK, Here are pics of the plane put together. Tim
ID:	642472   Click image for larger version
ID:	642473   Click image for larger version
Old 03-15-2007 | 12:03 PM
  #4635
Hi All, I just wanted to tell you all that I bought a Mini-XPV at TRU for $29.99 Today. It has a 160mha 3.7 lipo and NO wheels, flier only! I will post some pics soon. I hope this flies better than the MSL which would not stay aloft for more than 20 ft .
Old 03-15-2007 | 12:11 PM
  #4636
A little off topic but... I was gifted an Air Rage B2, the one with the ducted fans. Anyone have any experience with these? Know where there is a forum on them? I've already pulled the guts and they are sweet little fans with lots of thrust. (not measured of course, except by what they blew all around my workspace)
Trying to come up with a project plane to put them on/in. Too much power and weight for an AA
Old 03-15-2007 | 02:10 PM
  #4637
andrewtexas123's Avatar
Do you have any pics of the guts?
For the plane just do a scratch build. Scrol through this thread and look at diffrent designs!
Old 03-15-2007 | 03:50 PM
  #4638
Ayrton S's Avatar
Hi Guys!
I haven't been around for a while, in fact I last dropped in when p160 was the latest! Good to see all the action since.
I'm attaching a picture of a fairly extreme mod I tried (or should it be on the mods thread?? d'oh!). I decided to lengthen and lighten the tail with a drinking straw, and while I was at it I used the whole straw ( about 7cm increased to about 25cm...) to see what would happen... what happened was, it was fantastically stable and flew straight very well, but it wouldn't turn in the length of our 4 -court gym! So it's back to slightly longer than normal, I'm gonna try c10cm next. The other mods are single wing, extended wingtips as per usual.
The other pic is of my 16 gm (1/2 oz) Lancaster built originally for X-Twin gear, but I cheated and put in Plantraco kit with actuators on elevator and ailerons. She flies, but needs serious trimming/ long grass/ totally calm dry weather to make progress. I'm sure she'd be just as good with Silverlit gear.
ID:	642733   Click image for larger version
Old 03-15-2007 | 03:58 PM
  #4639
Ayrton
Where did you get the graphics for the Lanc?
Old 03-15-2007 | 03:59 PM
  #4640
No pics yet. I just stripped them out last night. Will try for some pics tonight as it is indoor nite.
ORIGINAL: andrewtexas123
Old 03-15-2007 | 08:24 PM
  #4641
hey dudes. i have this awsome plane from target its called the aero jet from air hogs also their is a new green one with just one wind kind of like Aero ace by-plane but the tail is way diffrent
kidnof new so ya.....
Old 03-15-2007 | 08:26 PM
  #4642
get some pics soon (or when i found out, help on that plz)
Old 03-15-2007 | 10:51 PM
  #4643
Zoil, might that be the acro-jet? The green one is the sport flier I believe. Tim
ID:	643036   Click image for larger version
Old 03-16-2007 | 01:26 AM
  #4644
PlaneKrazee's Avatar
My Feedback: (14)
What is the name of the green and white plane with the black canopy, where did you get and does it fly better than the AA bipe with one wing removed?
Regards,
Brian
Old 03-16-2007 | 05:03 AM
  #4645
Ayrton S's Avatar
Hi Trroadster!
ORIGINAL: trroadster
Ayrton
The Lancaster is a foam chuck glider, like the 50 pence WWII fighter ones from any toy shop, but comes with 4 little spinny props. I like the cartoony appearance and it glides very well - waiting for trimming flights now. There is a B17 available too but it has a rather psychedelic paint job...
Cheers
Ayrton
Old 03-16-2007 | 06:45 AM
  #4646
Good Morning All, Here are some pictures of the NEW MINI - XPV that I found while looking for a Sport Flier, I still can't find one anywhere!!
M-XPV weight is 26.2 grams, a little heavy but the box said that it will climb on 2nd throttle position, too bad there is only 3 steps. The motors still have quite a bit of power, they look like AH JET motors. Just waiting for the weather to break to try it out. On the bad side, The controller is small and awkward ( 49 Hz ). There was 3 different color variations ( red, blue and yellow ) maybe you fly 3 at one time tlike the AHAA.
ID:	643139   Click image for larger version
ID:	643140   Click image for larger version
ID:	643141   Click image for larger version
Old 03-16-2007 | 08:43 AM
  #4647
skypilot, I have yet to find anything that flies as wellace mono mod with a stir stick mod. The green plane has no official air hogs name. The name in Europe is sport flyer. That is what I refer to it as, the acro-jet is the turbo fury. I have also seen it refered to as the kiwi. I'm having issues with mine, poor range and response to controls. Others love the plane.
Tim
Old 03-16-2007 | 09:19 AM
  #4648
}---O---{'s Avatar
I have researched the Air Hogs/Spin Master line and the green one you are talking about is called the Kiwi.
Has anyone heard anything about a release date for the XPV batteries?
Heliwabbit...
Old 03-16-2007 | 11:07 AM
  #4649
My Feedback: (14)
Thank you for the replies.
Are you replacing the boom with a lighter tube on the AA mono conversion? I like the idea of the charging jack. I have had several of these planes that would not take a charge. It was always the ones that flew the best. I'll have to get cracking.
What do you use for the new boom material? The stir sticks are the added bracing?
Of my best planes, the first one was lost in a thermal before I did the transmitter mod, another was drawn to a spruce tree like a magnet and is still up there, and two others would not take a charge.
I'll check out the mod thread.
Old 03-16-2007 | 11:13 AM
  #4650
Hi,just puchased,a gold 1,thought green was cool looking,(only pic they would show lol) but was outta stock.only gold and purple available,so gold it was.wish ya luck with it,[8D]
