Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
spun a dogbone
Old 04-21-2006 | 07:26 PM
bluecaka69's Avatar
Default spun a dogbone
well i spun the tip right off my universal shaft today looks like the weld didnt hold and others with this prob. any suggestions
ID:	449118   Click image for larger version
Old 04-21-2006 | 07:28 PM
AJsToyz's Avatar
Default RE: spun a dogbone
Blue, I had a rear banana one me. I'm not sure why , I've never got going in reverse to smack anything back there !!! LOL
Old 04-21-2006 | 07:37 PM
hmmmm, there's something you dont see every day!!! Yours dont look rusty like mine though.
Old 04-21-2006 | 07:38 PM
AJsToyz's Avatar
Maybe his is not made in China and its some sort of Malasian knock off ?!
Old 04-21-2006 | 07:49 PM
LOL, almost looks like you can super glue it back together.
Old 04-21-2006 | 10:00 PM
bluecaka69's Avatar
ya its not even two days old yet and this is what happened kindof wierd
Old 04-22-2006 | 08:28 AM
cartronicshn's Avatar
same thing happened to me on a smarttech electric on road car, go figure
Old 05-11-2006 | 11:21 PM
One of my rear wheel dogbones on the Himoto Syclone is now a bow, i managed to take it off and use a hammer to get it straight again. Now i noticed that the rear center shaft is bowing as well, i think i need something stronger for these damn dog bones. Does anyone know of a substitute, HPI SAVAGE or MT2???!!?
Old 05-12-2006 | 12:10 AM
nitroreaper35's Avatar
I had one do the same thing on my volcano.On the rear right side wheel dogbone.I'm thinking a rock got stuck in there somewhere and the tire wouldnt spin and so it torqued it off like that.That was a few months ago,and havent had it happen since.So who know's?some things are stranger then fiction.
Old 05-12-2006 | 04:22 AM
ORIGINAL: charlie_gre
I also had 4 bent dogbones. U dont need hammer to staighten it. If it is bent in the middle you can use hands to straighten it! This metal is so soft that it easil bends. I think i will try hardening it by heating on my cooker and cooling in water then. It should be much harder, but too much force will break it instead of bending...wondering what is worse
Old 05-12-2006 | 11:54 AM
I'm sure this one on the himoto could not be bent by hand, i had to use a hammer!! Dont think hardening it with the cooker is a good idea, at least when it bends you can get it straight again, if it breaks then you know what that means.
Anyway does anyone know of a compatible dogbone thats stronger?? I was thinking Hpi MT2 or the savage but i'm not sure!
Old 05-12-2006 | 04:37 PM
hpi mt2 is not gonnawork, arms are longer and so are dogbones. My friend recently got mt2 and it is whole different car. Similar, but to some extent, definetely not the same.
Old 05-13-2006 | 01:45 AM
Popper252's Avatar
Hey guys i was looking through tower hobbies dogbones and I found some that are pretty damn close to what we need to fit our cars.
They're 79.4mm's long so I don't think it should be too much of a problem. Only thing is they're a little bit pricey.
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCAL5&P=7]79.4mm Dogbone[/link]
What do you all think?
I also found some that are 69mm and may work for the 70mm dogbone that we use. Although i haven't heard of anyone having any problems with those.
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXWZ38&P=7]69mm Dogbone[/link]
Old 05-13-2006 | 05:05 AM
79,4 to fit in 70mm place ? I don't think that 1cm difference is not gonna be crucial.
Old 05-13-2006 | 05:11 AM
ORIGINAL: jackkpl
Thats less than 1 mm difference, you won't notice the difference, if you look at the shafts the ends are designed to allow for travel of the shaft when the suspension rides up and down. If the DB is less than 1mm shorter you won't notice any difference!
Old 05-13-2006 | 05:12 AM
ORIGINAL: jackkpl
Old 05-13-2006 | 05:23 AM
ORIGINAL: jackkpl
Thats 9,4mm difference which equals to 0,94cm . if it was 70,94 vs 70 it would be ok, but 79,4 vs 70 won't
Old 05-13-2006 | 11:47 AM
Popper252's Avatar
I thought that the shaft from the differential to the tires was 80mm. So that's only .6mm difference of a difference... should work.
The 70mm shaft goes from the transmission to the front diff. right? That's what you could use the 69mm dogbone for.
