Forum questions or problems Post any questions about how to use the forum or any bugs/problems you may be having in this forum.
highlighting problem
Old 06-06-2007 | 01:42 PM
saleens7's Avatar
Default highlighting problem
i cannot highlight text so i can wrap [img][/img]'s, or 's around it,
it cant be a problem with my computer as i can highlight text on other forums...
Old 06-06-2007 | 01:46 PM
Banned
Default RE: highlighting problem
ORIGINAL: saleens7
what is your browser and os versions?
Old 06-06-2007 | 03:07 PM
saleens7's Avatar
ORIGINAL: RCadmin
ORIGINAL: saleens7
i use internet explorer (thats the browser, right?)...what is os versions? i have windows XP, if that helps...
Old 06-06-2007 | 08:01 PM
My Feedback: (9)
Same sort of problem here. When I "swipe" a whole word or sentence, only the first letter is highlighted.
IE 7 and XP Pro
Old 06-08-2007 | 06:09 AM
IE6 and XP
It also affects the LINK button function.
When I select some text ( I have to use the SHIFT-ARROW keys to select because click-drag-mouse doesn't work) and want to create a link with that text, the LINK button used to bring up a prompt with the highlighted text prefilled in at the URL text textbox. It doesn't do that now. You have to manually fill in the URL text again no matter if you have anything highlighted
EX: [link=http://www.rcuniverse.com/forum/post.asp?do=reply&messageID=5954239&toStyle=tm]LINK TO THIS THREAD[/link]LINK TO THIS THREAD
[link]http://www.rcuniverse.com/forum/post.asp?do=reply&messageID=5954239&toStyle=tm[/link]LINK TO THIS THREAD
As you can see, the link prompt simply pushes the selected text aside and creates the text again (first Example). If you leave the URL text blank ... it simply inserts the URL and again pushes the highlighted text aside.
I copied the Error on Page text (found by clicking on the Warning prompt on the status IE status bar). It only occurs during the post.asp EDIT ( It also happens at the EDIT.asp). I can highlight text all day as long as I'm not at post.asp.
Here's the text:
LINE: 18
CHAR: 2
ERROR: Object doesn't support this property or method
CODE:0
URL: http://www.rcuniverse.com/forum/post...239&toStyle=tm
The URL is the URL displayed while writing the post.
Old 06-08-2007 | 07:40 AM
Banned
Can you guys clear your browser cache, close all your browser windows and restart browser and retest. I think you have old javascript files cached
marc
Old 06-08-2007 | 01:48 PM
ORIGINAL: RCadmin
marc
As you can see from the QUOTE thread ... I've already done that and the problem still exists ...
Just in case, I'm not flushing correctly ... exactly how do you clear the cache? In IE6, I've hit the Delete Cookies, Delete Files, and Clear History buttons.
Where is the Clear Cache button??
Old 06-08-2007 | 10:10 PM
Banned
delete files is correct. I am having our developer look at this bug.
Old 06-09-2007 | 08:42 AM
ORIGINAL: RCadmin
Where is the (IE6, XP) Clear Cache button??
Here's another tid-bit. The area where I cannot highlight is in the textbox for the message I'm writing.
If I scroll down to the previous post(er)s, I can highlight text just fine.
So it has something to do with the function of the message textbox only ... any text outside of the message textbox is selectable.
Old 06-10-2007 | 10:43 AM
Banned
yes. we are aware it is textbox only. that is due to the javascript functions which allow you to edit tags like bold
Old 06-10-2007 | 03:34 PM
RCadmin:: ... yes. we are aware it is textbox only.
Sorry ... just trying to help. I guess I'll just shut up.
Old 06-11-2007 | 09:38 PM
Banned
Can anyone with this issue make screenshots of browser's
'About' window?
Menu -> Help -> About
so far we are unable to duplicate across any browser here.
Old 06-13-2007 | 12:03 PM
ORIGINAL: RCadmin
'About' window?
Will do when I get home today.
Old 06-13-2007 | 05:17 PM
ORIGINAL: RCadmin
'About' window?
Ok, here it is ...
Old 06-14-2007 | 05:06 PM
Banned
thanks. this is helpful
Old 06-15-2007 | 07:55 AM
My Feedback: (16)
Hi Marc. Same problem and same version of ie with SP2 here. I noticed the same thing start ~10 days ago if that helps you narrow it down any.
PR
Old 06-15-2007 | 10:17 AM
Banned
can I get more screenshots posted here of your browser as I requested above. we will have tough time to fix this without that info
Old 06-15-2007 | 11:50 AM
My Feedback: (16)
Here ya go.
Edit: Let me make a better one, can't read this one, deleted this one.
Try this one...
Old 06-15-2007 | 08:42 PM
ORIGINAL: RCadmin
How's this screen shot:
Old 06-19-2007 | 11:30 PM
My Feedback: (16)
ORIGINAL: RCadmin
'About' window?
Hi Marc,
Are you getting anywhere with this? I should be around the PC most of tomorrow if you need any more info to help solve this issue. As of right now there is no change. Cleared the cookies and temp files (again) but still can't get the "drag to highlight" to work.
LMK
Old 07-03-2007 | 06:14 AM
ORIGINAL: Pushrod02
Hi Marc,
LMK
Been on two week vacation. It's July now and the problem still exists.
Too bad they can't just undo the upbug (upgrade) they did that caused it in the first place. Believe it or not, this did work in the past.
Old 07-10-2007 | 04:28 PM
Bumping the thread back to the top for the benefit of the NEW users experiencing the same problem and starting new threads for the same problem.
Continue sending in your OS and browser data to the admin and they will continue to not fix it!!!!
Old 07-14-2007 | 08:34 PM
tippy:: ... Bumping the thread back to the top for the benefit of the NEW users experiencing the same problem and starting new threads for the same problem.
Still broke.
Old 07-27-2007 | 08:07 AM
ORIGINAL: tippy
Still broke.
Problem still exists. It's been a while since the problem was first reported.
Have you gotten closer to resolving the issue or have you abandon all efforts ... making us that are having the problem "expendable"??
Old 07-31-2007 | 05:31 PM
tippy :: ... or have you abandon all efforts ... making us that are having the problem "expendable"??
No response from RCU??? I guess we've been abandoned in place ... with no expectations of ever resolving the problem.
Too bad ... I'm gonna miss RCU
