Dalotel
Old 06-21-2007 | 05:25 AM
My Feedback: (7)
Default Dalotel
Hi all,
Could someon point me to plans or info like 3-view drawings of the Daloel. I just love the design. I think it was a model enginnered up to a full scale airplane....
Wladimir
Old 06-21-2007 | 07:49 AM
Default RE: Dalotel
The Dalotel is a french aerobatic aircraft it was around a long time before Hanno Pretner (The Best i ever saw.) made it famous to the R/cers of the world. I built one from Model Airplane News plans back in the 80s and i still have the plans after all these years (and i was out of the hobby for 15 years) It was the absolute best Pattern and sport plane i have ever flown. It would do knife edge loops all day long with no aileron input( no roll with rudder at all) and it would slow down to a crawl for landing,i have owned a lot of aircraft in my life (all kinds of pattern planes) and this is still the most impressive bar none. M.A.N. still has the plans for sale http://209.196.57.92/ME2/dirmod.asp?...tier4=&ntier5= Its simple to build and you will be glad you did. Randy Wallace
Mudbayrob (12-03-2022)
Old 06-21-2007 | 09:39 AM
jlkonn's Avatar
Default RE: Dalotel
Here is a 3 view Dick Hanson sent me once.
Dick offered a very competitive pattern model in the early mid 80's based on this plane.
It was actually named "Viking" but every one called it by Michel Dalotel's last name.
In the early '80s Dalotel wrote to the EAA and asked for help finding investors.
The EAA published his letter which included a picture of the prototype in flight and specs
for various models which varied from fixed gear to retracts and horsepower.
I believe there was only the one prototype built.
If you contact the EAA in Oshkosh they may be able to supply you with a reprint of that article.
Good luck!
JLK
Old 06-21-2007 | 11:44 AM
RFJ's Avatar
RFJ
Default RE: Dalotel
Wladimir,
Here is the plan mentioned by Randy in his post. From MAN June 1982. Sounds like a great flier.
If you are interested I can scan and post the article and I also have some more Dalotel photographs/drawings if required.
Ray
Old 06-21-2007 | 12:16 PM
jlkonn's Avatar
Default RE: Dalotel
Ray,
I would be interested in a copy of the article.
Thanks!
JLK
Old 06-21-2007 | 01:00 PM
RFJ's Avatar
RFJ
Default RE: Dalotel
No problem JLK, here is the article from MAN.
Ray
ID:	708285   Click image for larger version
ID:	708286   Click image for larger version
ID:	708287   Click image for larger version
ID:	708288   Click image for larger version
ID:	708289   Click image for larger version
ID:	708290   Click image for larger version
Old 06-21-2007 | 02:41 PM
propbuster's Avatar
Default RE: Dalotel
Here's an ARF for sale http://cgi.ebay.com/Dalotel-DM-165-5...QQcmdZViewItem
Old 06-21-2007 | 02:43 PM
RFJ's Avatar
RFJ
Default RE: Dalotel
Just for fun, here's a (rather poor) shot of Hans and Hanno Prettner, his first TOC Dalotel and Mr Dalotel himself.
Ray
Old 06-21-2007 | 04:44 PM
Default RE: Dalotel
Heres a rather poor film of a dm165 viking http://www.youtube.com/watch?v=uhPy_exA45w Im going to build one myself after all this talk about them i want one again real bad. Randy Wallace
Old 06-21-2007 | 05:06 PM
RFJ's Avatar
RFJ
Default RE: Dalotel
A Dalotel without retracts and engine cowling....uugh!
Ray
Old 06-21-2007 | 10:22 PM
Default RE: Dalotel
Some pictures of a full scale DM165 and a Chip Hydes back up plane from 1999 TOC .The full scale on the ground is from 1970. Randy Wallace
ID:	708571   Click image for larger version
ID:	708572   Click image for larger version
Old 06-22-2007 | 07:08 AM
Default RE: Dalotel
Heres a couple of pic.s of Dick Hansons Dalotel. Randy Wallace
ID:	708702   Click image for larger version
Old 06-22-2007 | 08:54 AM
Default RE: Dalotel
RE: Dalotel by Obi Mapua-Plan #06822, $19.95.
I built this model back in the '80's as I fell in love with the Dalotel also. It is a great flying airplane! Retracts would be a simple addition (Mine was fixed gear). I started flying it with an OS .60 FS and changed to a small block ST .60.
An OS .70 Surpass would be perfect and have that scale sound! I still have my plans and who knows- I might build another one!
Frank
Old 06-22-2007 | 09:24 PM
My Feedback: (65)
Default RE: Dalotel
Check out d&l DESIGNS they have 2 sizes available, both PLANS, KITS, ARC and ARF.
www.dldesigns.net
Ron9844
Old 06-25-2007 | 09:07 AM
Default RE: Dalotel
I need some foam for my wing cores in the Dallas ,Ft. Worth area? Are someone that will cut a set for me? Randy Wallace
Old 06-25-2007 | 09:35 PM
Default RE: Dalotel
Im starting mine tonight. I wanted to enlarge the plans 20 yr,s ago so the one after this one might just be the home for a YS dz140 ive had for 3 yr.s Randy Wallace
Old 06-26-2007 | 06:51 AM
Default RE: Dalotel
Heres a couple of additional pictures. Randy Wallace I LOVE DALOTELS
ID:	711436   Click image for larger version
Old 06-26-2007 | 07:06 AM
Default RE: Dalotel
Heres Hanno and his gear drive system from the 1980,s I think it was the 1988 TOC. Randy W.
ID:	711454   Click image for larger version
Old 10-24-2007 | 11:04 PM
Default RE: Dalotel
Here is my version of the Dalotel. Wingspan is 82 inches. Powered by a RCS 1.40 gasser. Century jet air retracts. Covered with Century 21 fabric. Designed with Autocad. The model has very accurate scale outlines. A great flying airplane. Suitable for scale or IMAC.
Dave G.
Old 10-25-2007 | 11:59 AM
Default RE: Dalotel
I've flown the TOC sized version with an HP120 inline twin and it was a good flying aerobatic airplane with no bad habits that I can remember (early 80's)
Old 03-08-2008 | 06:51 AM
Default RE: Dalotel
Hello Frank and all the others who love Dalotels! I am Obi Mapua, and after reading your posts, I am tickled pink that my design from 1983 is still very much alive! And what's more, you enjoy the way it flies. I was able to find one that I made, after 20+ years, from a modeler who was moving house. I bought it back from him, and then put in a new Thunder Tiger 46 PRO engine on it. When I flew it, I was shocked!! It had much more power than the 45s that powered my Dalotel 20 years ago! Lunar verticals, if you can believe that...The engines today have much more "oomph" in them. Sadly, I had to hang up my Dalotel, as flying a 20 year old plane is not really recommended. The glue and wood are so dry, that a bad jolt would shatter the airframe. After reading the thread, I am so tempted to "upgrade" the plan. I made a 61 version, and this was a nice flyer too. I am still actively designing model aircraft; my latest on the board is a Yak-55, foam cores are cut; this is a 2-meter airplane, to be powered by a ZDZ 40 RE.
Old 03-08-2008 | 10:13 AM
Default RE: Dalotel
If you have a 60 size plans i would love to have them. Anyway to get a copy from you? Randy Wallace
Old 03-08-2008 | 04:27 PM
RFJ's Avatar
RFJ
Default RE: Dalotel
Obi,
Good to hear from the MAN plan designer. Yes, plans for the 60 size version would also interest me if available.
I don't wish to offend, but I don't think you got the fin/rudder shape quite right on the small one - or was that deliberate to improve its performance.
Ray
Old 03-09-2008 | 02:20 PM
kdc
Default RE: Dalotel
There is a plan for a 54 inch electric Dalotel available plan No MW3025 avail from Traplet www.traplet.com
Also there was a David Boddington plan for a 48 inch Dalotel for 30-35 2 strokes or 40 4stroke published as a free plan in Scale Aircraft Quarterly Summer 1986
Old 03-10-2008 | 05:52 AM
Default RE: Dalotel
Dear Randy and Ray,
Thank you so much for your interest in the 61 plans (the plane would probably be competition competitive with a YS 110) but it's been a long time since I made those plans--by hand, the good old fashioned way--drafting (anybody remember this?). These days I work with CAD, specifically, DesignCAD. I can draw up a set of the 61 Dalotel plans, it might take a while, as I can do one of two things--trace over in CAD the original MAN plans, and scale up--not too hard to do, or, photograph the 61 Dalotel--one still exists with my brother--and then trace that. That route might be longer. I would like to send the plans via e-mails instead of rolled up in a cardboard tube. This is too expensive.
Yes the fin and rudder are "squished"--an error of mine as I couldn't get the right size from photographs of the Dalotel--the right profile didn't come till I saw a 3-view much much later. Don't worry, I'm not offended--although the fin and rudder of the 40 sized Dalotel were still OK in performance. (If I remember right, I was calculating the area--sort of--the fin and rudder to have about the same area as those of pattern planes) The 61's vertical tailplane is corrected, and looks much better. No downgrade in performance.
I would like very much to use a better airfoil and aileron setup. I hope you guys aren't in a rush, the Philippine Nationals is coming up, and I am joining the Senior Pattern event. Sadly, not with a Dalotel, but with another design of mine--a pattern plane. The Nationals are on April 11-13. I will keep you posted on developments.
Thank you all so much for your interest.
Obi Mapua
