 eagle 2 mods >
eagle 2 mods
eagle 2 mods
Old 06-13-2008 | 02:37 PM
Default eagle 2 mods
ok ive had my eagle two for a while now and i think its time for a change i want to be able to take of from anywhere. yesterday I ordered a set of 5 inch baloon,a nice three blade prop and nose cone and some varius protective gear to keep my radio gear safe. dose anyone have links to vids with these tires or stories and techneiques to help me fly off anyterain. oh by the ways ive been flying for about 5 years now and the plane i think about two years.
Old 06-13-2008 | 02:54 PM
Default RE: eagle 2 mods
now i dont know if this will work for me but here are some photos of my plane now with out its new stuff i modified it to a tail drager.the last ones me
ID:	969888   Click image for larger version
ID:	969889   Click image for larger version
ID:	969890   Click image for larger version
ID:	969891   Click image for larger version
Old 06-13-2008 | 11:16 PM
Colors are Monokote Salmon, grey and white. Two extra bays were added to each wing tip extending each wing by almost 5 inches.
Vertical stabs were added to the top and bottom of each side of the horizontal stab to allow for the needed control for float planes.
Obviously, floats were added and a rudder on one float. One rudder worked fine even with a breeze blowing.
The wing was built flat. Washout was put into each wing by twisting the wing and using the heat gun on the covering. Worked quite well.
Putting the washout into the wing created anheidral in the wing. Yes, both wings point down.
Flying inverted required no down elevator. All I can assume is that the floats and anheidral accounted for it.
Was a fun plane to fly. Floats are foam covered with balsa and 3/4 oz cloth....except for the bottom. I put 4 layers of cloth on it to protect the float from getting punctured on something that may be lying in the water.
Ron
ID:	970144   Click image for larger version
ID:	970145   Click image for larger version
Old 06-13-2008 | 11:43 PM
You can cut out recesses in the floats and have a portion of the wheel protrude from them as they do from wheel pants. It can then go on land or sea or just roll from land to float on water. This isn't my idea. Wendel Hostetler has this option on his Cessna 150 float plans.
Ron
Old 06-14-2008 | 09:28 AM
all great ideas but i dont think ill be going for floats i tryed it and it didnt turn out well. my wings are shortened about two inches on each. i was thinking more like bush planes with tundra tires.
Old 06-22-2008 | 05:46 PM
are there anmore great pics of eagles out there
Old 06-26-2008 | 09:13 AM
ok ive desided to leave this old eagle alone. i went and bought a new eagle kit and a futaba 6 chanels controler. i was planing on extrending a portion of the alerons buy two inches for the flaps mabie about a 4inch section.of course like the first one im going to use taildragger i went and bought a fancy tailwheelfrom dubro and on top of that i only use 5 chanels so i think im going to add a bomb release so i can bomb my friends lol!!! as for covering i think ill stick to monokote since i have the tools. id like to see peoples covering jobs on anyplane just looking for a cool covering job perhaps a army style i think id like to go a little more complicated the one on my first eagle
Old 06-26-2008 | 10:59 AM
Mr E,
This may be what you are looking for; you can save some work by using flaperons. I did not need the struts but it makes it look a lot less like a trainer. The kit was given to me and I did not want to build a trainer so this is what I came up with.
ID:	978850   Click image for larger version
ID:	978851   Click image for larger version
Old 06-29-2008 | 07:35 PM
That is by far the nicest trainer ive seen i love the schem and the struts i was thinking exactly like i was thinking. ok heres what i have so far i got my new plane 3 days ago i can fly threw building trainers all is square and leval checked tree times. i used the dubro super strength landing gear with 5 inch dubro baloon tires big big tires lots of bounce .i went with flaps, they extend about 60 degres. i used a a 12 oz fule tank with a filler line all the lines run out the top of the acsses door the total weight now is close to 4 pounds. i am useing 8 seros with 3 y harnesses well wporth the weight i think i may use a larger engin then the os .46 surpass engin i have in it i was thinking a .50 or a .60 with my prop on i have 3 and 1/2 inches clearence. so far i also have the tail sections done useing pin hinges for most of the hinges my best trainer i think. i plan latter on to make a bomb drop peace so i can bomb my feild. here are some pics to explain what i was saying [img][/img]
Old 06-29-2008 | 07:37 PM
here they are i hope it works this time.
ID:	981086   Click image for larger version
ID:	981087   Click image for larger version
ID:	981088   Click image for larger version
ID:	981089   Click image for larger version
ID:	981090   Click image for larger version
ID:	981091   Click image for larger version
ID:	981092   Click image for larger version
Old 06-29-2008 | 07:39 PM
ok now youve seen what i have to work with anyone have a paint schem i can work with i want like bush pilot or army style something cool to look at and get some looks at the feild
Old 06-30-2008 | 03:21 PM
Mr E,
I will going to AK this week and I will see what I can get a picture of. Taking a picture of a bush plane in AK is like taking a picture of a ford here!
Old 06-30-2008 | 04:53 PM
that would be sweet id greatly apreshiate that ..
Old 07-10-2008 | 08:55 PM
would anyone happen to have a paint sceam that youd love to see on a plane. i need to get this plane covered im crazy to get it done its now crying to me to fly it any help anyone. army, civil, any any paint job would do at this point as long as its cool.
Old 07-10-2008 | 09:41 PM
i thought id show you some more pics of my planes bare bones.
ID:	987889   Click image for larger version
ID:	987890   Click image for larger version
ID:	987891   Click image for larger version
ID:	987892   Click image for larger version
ID:	987893   Click image for larger version
ID:	987894   Click image for larger version
ID:	987895   Click image for larger version
ID:	987897   Click image for larger version
ID:	987898   Click image for larger version
ID:	987899   Click image for larger version
Old 07-11-2008 | 06:06 AM
My Feedback: (39)
Hello Mr E,
A number of years ago I did something similar to an Eagle II kit. I had already gotten my wings so I didn't want another trainer. I changed it to a tail dragger, inverted the engine and cowled in the nose, and built the wing with an Eppler 197 airfoil (semi-symmetrical). That plane flew awesome and it was fast too, with a 40 size engine. I have a SIG LT 25 kit stored away and was thinking of doing the same thing to it Nice building job. Both of your Eagles look great.
Cheers!
Jollidude
Old 07-17-2008 | 11:13 AM
JD,
Did you make a template for the wing ribs?
Mr. E,
How are you doing on the build?
Old 07-18-2008 | 11:50 AM
what do you mean a template for the wing i dont understand. as for how its going its not its still sitting awaiting covering i cant think of a schem to do on it im also desideing wether to put a larger engin in. i was looking into a supertiger .61 2 stroke but for now i think the 46 will do .
Old 07-24-2008 | 08:05 PM
well i think i got the colours. i desided ill do monokote save some weight. i plan on doing olive drab and dove greay in an old army scheem. i hope to have it done soon so i can show you all anyone else wana show off there wor bird colours or eagles
Old 07-24-2008 | 09:11 PM
I wish I would have weighed on this earlier. I think some good color shcemes would be of planes like the Pilatus Porter:
http://www.globalsecurity.org/milita...-20-porter.jpg
Or, the Aviat Husky:
http://www.aviataircraft.com/hgallery.html
Many of these planes are used for utility in the bush, and the red coloration on some lends its self to increased visibility, especially in winter conditions. Perhaps it would even be good for a float plane. Good luck with your build, and I look forward to seeing what you come up with.
NorfolkSouthern
Old 07-25-2008 | 02:47 PM
oh man i like the aviot husky read and black i still have time to change it i think ill do that thanks.[8D]
Old 07-25-2008 | 03:06 PM
Mr. E.
If you look at my post about wing rib templates you will see that it is a two part post; one to JD and one to you.
I am still going to send some pictures.
Old 07-26-2008 | 02:46 PM
Ok! I was weighing my model last night and realy oddly it comes im around 3 and a half pounds so i desided that i will cover it in fabric useing the sig stix it and sig cover all fabric (white silk). Dose anyone know if witht that type of covering chemical if i can use auto paint on the plane. Also since i have desided that i will be towing and bomb droping with this plane i would like to put a larger engin init.i figured i would like to beable too tow at least 4 additional pounds. Any sugestions on the size i was thinking .50 maby.60 . NO four strokes i just cant do the tuneing on them. id also like too know what ya think prop size as for clearence i have about tree and a half inches between my 11/6 prop but im looking a prop that will pull the plane great give it good climb im not worried about speed at all. I like the slow planes.
Any help with fabric covering would be nice as ive only dont it on full scale and im going to be useing and iron on chemical. anyone have a link to a rc fabric covering jobs even if its just pictures, if posible a covering job useing sig stix-it.
Old 07-26-2008 | 03:34 PM
My Feedback: (39)
Yes Walter, I did have the template for the ribs. I'll have to check to see if I still have it.
Cheers!
Jollidude
Old 07-26-2008 | 04:52 PM
NS.
If I could I would build one with a turbo prop. but that is to many $s. Thanks for the pictures!
