Custom Piston Rings
My Feedback: (13)
I was asked by a customer to leave information in this section of RCU Forums. I have been a machinest all my working life and making Custon Piston Rings for approx. 12+ years for Gas, Glow and diesel engines, some motorcycles too. With my custom rings, performance will improve over nearly all factory rings because of the material I use, machining method I use and Ring gap I recomend with my rings. I use fine grained cast iron machined from solid round bar stock rough cut on OD to .010 oversized and finished with a .002 finish cut on OD for accuracy. OD of ring is cylinder bore to assure ring fit is correct and round rather than making ring larger than bore and shinking oversized ring after saw cut into smaller bore. Rings are then hand lapped to .001 smaller than piston ring land. I don't saw cut ring, I have a special tool that snaps ring before heat treat at 850+ degrees F. After heat treating on mandrels I gap ring to .001 to .002 end gap. Rule of thumb in machinest world on cast iron rings is .001 to .0015 ring gap per 1" bore diameter. I make bore gage to .0001 of cylinder bore to gap rings & ship all over the world. I make over 300+ rings and to date made thousands with a lot of happy customers. There is a lot more involved in my manufacturing process along with a lot of tooling involved, too much to discuss here. If I don't currently have dimensions to make rings for certain engines a lot of customers send the piston & cylinder to me to measure for rings & I install rings for no extra charge. I make special rings for 30 CC Homelite & 31 CC Ryobi engines that require a slight mod. of cutting anti rotation pin in ring groove down 1/2 way so my custom rings will overlap pin for much improved performance. Most rings for Gase engines $10 ea. shipped to most countries & US at $14 for 1 & $24 for 2 shipped. Discounts of $1 off per ring on orders of 10 or more mixed sizes & Brands fine. I have been endorsed many times by engine builders like Clarence Lee, Joe Wagner in magazines, etc. Email me if you have additional questions and a list of custom rings that I currently have in stock. Thanks & God Bless all. Frank Bowman at Bowman Rings. Email: [email protected]
My Feedback: (27)
CA
I'm so glad I asked.
I know that Bowman rings make a big difference over perfectly good stock rings.
He even made a set of rings for me that fit a Tamper.
That's a engine powered pogo stick with a big foot for compacting the earth.
It was so old parts were no longer available.
I sent him the cylinder and piston and he did the rest.
Frank; There was a discussion about your rings in a Stihl 066.
How would your rings compare to the stock rings?
Would they be able to with stand the large exhaust port?
As you know that is the trouble spot on most 2 stroke engines.
My Feedback: (13)
Hello Ralph, My rings should be better than original factory because when I make them I heattreat rings with lower tension. This is because my rings are round and I don't need to put a lot of tension to seat ring because it is round. Factory rings have more tension to seat ring, but also wears them out sooner and heats engine more. Where I'm going is with less tension larger port not much of a problem as long as rings are pinned so ring gap doesn't go into open port window. Remember less tension, less heat & ring lasts longer with less chance of over heating. At present time I have rings for Stihl: 028 44CC, 25.4 CC, Super 045, 57CC, MS 440. Great engines with lots of power. Hope that answers question. Hope you got my Piston Ring List Bill, if not email me again as computer returned some of you emails. Thanks Frank
My Feedback: (16)
Frank Bowman's stock list. You can order these as stock without sending him cylinder and piston
Ace Twin .64
Aircom M61 (pin)
Anderson Spitfire .65
Air-O .45
Asp .52 4C, .61, .80 4/C, .91 4/C
Atomic 60
Atwood .49, .51, .63
Avistar .60 (pin)
Bantam .16
Bat .19
Berilli 36 CC (Pin)
BME 3.5 (Pin)
Brison 2.4 (pin), 3.2 (pin)
Brown Jr. .60 cylinder sizes vary (send Piston & cylinder for proper fit & correct ring)
Brownie .29
Bushwacker 37.7 CC (pin) Sears
Bunch .45, .49
Cameron .15, .19
Cave Cobra
Cleveland Tom Thumb .45
Como .29 (pin), .40, .51 (pin), .90 (pin)
Contestor D.60
CRRC Pro 45 CC (pin)
Cub Cadet 25CC (pin)
DL 50 CC (pin)
DME 100 Twin (pin)
Dooling .29, .61, Yellow Jacket
DZY 48 CC Twin (Pin)
Echo 16CC (pin), 21CC (pin), 21.2 CC (pin), 23.6 (pin), 24.4 CC (pin), 30 CC (pin), CS-3000 (pin), 50 CC (pin)
Edco Sky Devil .64 Old or New (RJL) state which one?
Enya 3.5 (pin), .30 SS (pin), .35 X (pin), .40 X Dykes (pin), .40 Dykes model 6002, .45, .45SS (pin), .46 4C,.49 X (pin), 50SS (pin), .53 4/C, .60 4C, .60 X (pin), .60 standard, .80 X (pin), .80 4C, .90 4C, 120 R 4C, 1.55 4C, 240 4C Twin
ETA .29
Forster .29, .31, .88, .99
Fox 36 Sand Cast (pin), .40 Sch., .45, .50, .59 .047 thick ring only, .59 long shaft Ign., .60 Blue Head, .60 Eagle, Fox Hawk
Red Head .60 (pin), .74, .78, 120 Twin (pin)
GMS .61 (pin), .76 Dykes (pin)
Hassad Blue Streak .64
HB .21 Dykes, .40 PDP Dykes, .50 Dykes, .61 (pin), .61 Dykes
Hiller (Car)
Hirobo 36 (pin)
Homelite 25 CC, 30 CC (pin) old .060 thick , 30 CC newer .030 thick, 33 CC (pin), 38 CC (pin), 40.6 CC Super EZ Chain Saw, 45 CC (pin), 50 CC (pin)
Horner 3.7 Twin (pin)
Hornet .19, .60
Howler .60 (pin)
HP .21 4/C Dykes ,.40 (pin) ,.61 R.I. Silver Star (pin), .61 Dykes (pin) Blk Case Gold Hd.
Irvine .40 Pylon Dykes & Standard, .61 Dykes, .25 Dykes.
Kavan MK 50
KDC Kioritz 21.2 CC (pin), 23.6, 25 CC (pin), 30 CC (pin), 58 CC (pin)
K&B .35 Dykes, .40 Dykes, .40 S Dykes (pin), .61, .61 Dykes (Lee Custom), 1.35 (pin), 1.5 (pin)
Kometa 29
Kraft .61 (pin)
Kratmo 10 CC, 4A Ignition
Laser 61 4/C
Lewis 60
Magnum .53 XL 4C, .61 XL (pin), .91 XL 4C
Maloney 100 (pin), 125 (pin)
McCoy .09, .19, .19 Dykes B.H., .21 Dykes Car, .29 all versions, .29 Dykes B.H., .35 Dykes B.H., .36, .40 Dykes B.H., .49, .55, .60
McCulloch 21 CC (pin), 25 CC (pin) MDB 90 Leaf Blower, 28 CC, 32 CC (pin),
MDL 28 CC (pin)
MDS .78 (pin), 1.48 (pin), 2.18 (pin)
Merco .40, .49, .49 Dykes, .50, .61, .61 Dykes
Moki M .51 (pin), .61 (pin), 1.20 (pin), 1.35 (pin), 1.50 (pin), 1.80 (pin), 2.10 (pin)
O&R Industrial Motor 1 HP
OPS Maxi .30 (pin)
OS .20 FS 4C, .26 4C, .28 FH Dykes (pin), .32 (pin), .37 H (pin), .40 H Dykes & Standard, .40 H (P) Pylon, .40 FS 4C, .40 SR (pin), .807 bore, .40 FSR .835 Bore, .40SR Dykes, .45 (pin), .45 Dykes (pin),
.45 RSR Dykes, .46 Dykes (pin), .46FX (pin), .46SF (pin), .48 Surpass, Max .50 old, .50 FSR Dykes (pin) ,.50 H (pin), .50 SX & SXH (pin), Surpass .52 4C, .58, Max-H .60 FGR .60 4C, .60FSR (pin) .9445 Bore - older or SF .9055 Bore, .61 FS 4C, .61 SX & SXH (pin), .65 (pin), .70 & .75 Surpass, .80 H,.80 Dykes (pin), .90 & .91 4C, .90 & .91 Glow, .91 FX (pin), .91 SX H (pin), 1.08 (pin), 120 4C, 160 FX (pin), BGX-1 3500 (pin)
Poulan 42 CC (pin), 42 CC Wildthing (pin), 46 CC (pin), 54 CC (pin), 60 CC (pin)
Profi .40 (pin), .61 (pin), .76 (pin)
Quadra 35 CC , 40 CC (pin), 42 CC (pin), 50 CC (pin), 150 Twin (pin)
RSC 1.40 (pin)
Ross .60 Dykes (pin), .60 opposed twin Dykes (pin), .61 (pin)
Rossi Speed .60 old, .60 (pin) .021, .61 (pin) .023, .65 (pin) .0235
Ryobi 26 mm Bore EJ 100 (pin), 31CC (pin) older .064 thick, 31 CC (pin) newer .047 thick
Saito .40 4C, FA .45 4C, FA .50 4C, FA .60 T 4C Twin, FA .65 4C, 72 4/C, FA .80, .91 4C, 120 4C,130 TD 4C Twin, 150 4C, 300 4C Twin
Sachs 2.0 (pin)
Scott Thunderbird
Shindiawa 33 CC (pin)
Skil chainsaw (pin)
Sky Chief .53
Spe 25.4 (pin), 40CC (pin), 45CC (pin)
Stihl 25.4 (pin), 028 Chain Saw 44 CC (pin), Super 45 (pin), 57 CC (pin), MS 440 Chainsaw 70 CC (pin)
Super Tigre .19, X.25, S .29 (pin), G21.29 old, .34 (pin), .40 Bullring, S.40 (pin), G21.40 std., G21 .40 Dykes, G21.46 std. ,S.45 (pin), V.45, X.45 (Pin), G21 .46 wide Dykes, .46 Bullring, G.46, G .46 Bullring, V 51, G51 (pin) Italian, G51 (pin) China, V.56, V.56 Dykes, V 60 light case .044 or .047 top to bottom measurement, G24 60 Old, G 60 Bluehead, X60 (pin), V.60 wide & narrow Dykes, S.61 (pin), G.71, S.75 (pin), .90 (pin), 2000 (pin), 2300 (pin), 2500 (pin), 3000 (pin) Italian, 3000 (pin) China, 3250 (pin), 4500 (pin)
Syncro B-30, Syncro ACE, Syncro ACE Special
Tartan 1.34 (pin), Twin .77 (pin)
Technipower 7 Cylinder radial
3MM 53 TOC (pin)
3W 80 CC Boxer Twin (pin)
Thunder Tiger .39 (pin), Pro .50 H (pin), .54 4C, .91 FS 4C, 120 Pro (pin)
Ueda .45, .61
US 25 CC (pin)
Vlvatam 5 CC
Veco .50 Dykes, .61, .61 Dykes
Vega 10CC
Webra 10 ccm, 6.5 (pin), .40, .40 (pin), .40 Dykes (pin), .50 Dykes (pin), .61, .61 (pin),
Speed .61 FS (pin), Speed .61 F Dykes (pin), T480 4C, .91 (pin), .120 Dykes (pin), T 4.90
Weedeater (pin) 1.380 Bore, 22 CC (pin)
Weedwacker (pin)
Westbury Atom III
YS .61 Long Stroke (pin), .63 4/C, .80 H (pin) 2C, F.91 AC 4C, .91 2C (pin), F120 4C
YW 24CC single & 48CC Twin (pin)
Zenoah G20 (Pin), G23 (pin), G26 (pin), G38 (pin), G45 (pin), G62 (pin)
Ace Twin .64
Aircom M61 (pin)
Air-O .45
Atomic 60
Avistar .60 (pin)
Bantam .16
Bat .19
Berilli 36 CC (Pin)
BME 3.5 (Pin)
Brownie .29
Bunch .45, .49
Cameron .15, .19
Cave Cobra
Contestor D.60
DL 50 CC (pin)
DME 100 Twin (pin)
ETA .29
Hiller (Car)
Hirobo 36 (pin)
Hornet .19, .60
Howler .60 (pin)
Kavan MK 50
Kometa 29
Kraft .61 (pin)
Laser 61 4/C
Lewis 60
MDL 28 CC (pin)
OPS Maxi .30 (pin)
RSC 1.40 (pin)
Sachs 2.0 (pin)
Scott Thunderbird
Skil chainsaw (pin)
Sky Chief .53
3MM 53 TOC (pin)
Ueda .45, .61
US 25 CC (pin)
Vlvatam 5 CC
Vega 10CC
Weedwacker (pin)
Westbury Atom III
My Feedback: (13)
Heat Piston with propane torch & find ring gap to pry on ring halves. Once ring starts to pry out put oil under ring and repete process. Light oil works best, be careful if piston gets too hot oil will ignite and catch on fire. If ring is stuck and gap is over .003 replace ring as power is slipping past wide ring gap.
My Feedback: (13)
My rings work fine in chromed cylinders if that is what you are asking. I make dykes rings for pistons machined for dykes. Again low tension and they last longer than conventional rings.
Thanks Frank for making yourself known. If Frank can't help you, you just as well forget your project. I talked to him today because he called me to check on what I needed for sure. He ships fast and gets you back running soon. I use nothing else but "BOWMAN RINGS"
Give him a try, you wont be sorry! Flathead 4
My Feedback: (27)
CA
ORIGINAL: nitro joe
Mr. Bowman
It's nice to see a true artisan posting in the forum.
It would be nice to read your thoughts in here more often!
Oh,and please don't feed the trolls...
Mr. Bowman
For some reason the "Oh,and please don't feed the trolls..." was pretty funny.
I would think chrome-moly on chrome may not be the best thing.
Cast iron rings that fit properly would give a much better and faster seal plus they would not really wear on the cylinder.
$12.00 rings verses $200.00 OEM cylinder.
But I am interested in hearing from the Master.
You don't know the details of the application, making assumptions like that causes confusion. I am asking a simply question about what is available.
"$12.00 rings verses $200.00 OEM cylinder. " Yes thats a real concern, it is a real issue with rings dropping into wide exhaust ports.
PART OF POST WAS REMOVED BY MODERATOR
My Feedback: (13)
Thank you asking, I only make Precision low tension fine grained Cast Iron compression Piston Rings. My standard rings are $10 ea, not $12 up to 2" diameter bore. The shipping, padded envelope, etc is $4 per order. I do not have chrome faced or chrome rings. The chrome is for wear factors but my low tension rings don't wear or heat engines as high tension cast or chrome rings would do. Normally I don't have much time to sit at this computer to post on different sites as I'm always working & find little extra time outside of making rings, working at my church, & some fishing & flying. Thank you very much RCU for your great site and all my customers for your patronage, God Bless all. Frank
HI FRANK BOWMAN DOES GREAT THINGSWE NEED MORE PEOPLE LIKE HIM IN OUR HOBBY TO KEEP OUR ENGINES RUNNING IN TOP FORMSO PLEASE DO SUPPORT HIS BUSINESS EVERY CHANCE YOU GET -I HAVE AND HAVE BEEN MORE THAN HAPPY WITH THE RESULTS-HE IS A REAL RC MASTER-I KNOW I AM A REAL GLO ENGINE GEAR HEAD FOR 25 YEARSTONY LENTINI "THE OMEGA MAN "
Franks piston rings worked great for us. My friend bought a few Webra 1.20 engines, new. They use the dykes type of ring. One of his engines never did develop the compression the others did. We installed one of Franks rings and wow did it make a big difference. It had more compression even before we started it. That engine will hand start now real good, and has very good power. How many Webras 1.20 engine will hand start good??? If you know how to tune a engine right....you will have less problems with rings in the first place...just a general observation! Capt,n
My Feedback: (27)
CA
Hi Frank
One last question .... well maybe.
With 2 ring pistons, someone stated that they run your ring on top and the factory ring on the bottom groove.
Is there a down side to running your rings in both grooves.
There is such a thing as too much of a good thing.
Thanks Again
Thanks Again
My Feedback: (13)
Hello Ralph, With my tighter ring gap that is the norm if you just want to buy 1 of my rings put it in the top groove. For almost no other advantage except possibly slightly less heat just use my ring in top groove & eliminate bottom ring. My low tension rings in both grooves best and will probably take a little longer before rings need replacing. Take care & God Bless, Frank
