Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Sebart Wind S Pro
Old 08-30-2010 | 01:47 AM
  #176
Default RE: Sebart Wind S Pro
hi guys,
what incidence are people running on the tail, i was going to measure the wing then set the tail at 0 deg. will post some pics of my wind `s` pro as she nearly ready to go .
regrad s
steve
Old 08-30-2010 | 06:21 AM
  #177
My Feedback: (45)
Steve,
I basically set my wing to .5, and then from that made the tail 0. By doing this I ended up having to lower the front of the stab about 1 turn on the adjusters to get the elevators at 0, but this worked well for me.
Arch
Old 08-30-2010 | 07:20 AM
  #178
arch,
all set for flight now , many thanks arch.
regards
steve
Old 08-30-2010 | 07:34 AM
  #179
My Feedback: (45)
I've been very happy with mine. I intentionally even let it sit out in the sun at the field yesterday to see if the covering wrinkled up. There was one small spot on the right stab that had a bubble, but other than that everything still looks new. I've been extremely happy with how mine went together and it flies even better.
Arch
Old 08-30-2010 | 07:39 PM
  #180
Arch,
The same for me. I set the plane in a foam stand with the wing at .5 degrees and then set thestab at 0 degrees. It seems to be a good starting point.
I'm currently trying to find a cg that I like. Where are you running your cg (As in mm from the leading edge)?The instructions say 190mm to 210mm.
Terry
Old 08-31-2010 | 06:16 AM
  #181
My Feedback: (45)
Terry,
I'm running mine a little further forward than he recommended. I'm running mine at about 175-180mm. With the canopy off, mine balances just behind the bolts that hold the wing on.
I really like the feel of a much more forward CG. Plane still snaps awesome with the CG where it is, but I have 0 pitch mix in either direction.
Arch
Old 09-01-2010 | 07:24 AM
  #182
hi guys , i just recieved my CC-Ice 80Hv ...... which version of software are u guys using ..? I 'm use it with Axi 5325-24 .
Some say the older version 1.55v run fine without issue .?? ??
So which is it ...??
Any advice ... thank you.
Old 09-01-2010 | 02:32 PM
  #183
My Feedback: (41)
V3.25 is what I'm running. Don't forget to turn on the outrunner feature if you have one. The new Ice Controllers are really good. Mike</p>
Old 09-01-2010 | 03:30 PM
  #184
Mastertech's Avatar
My Feedback: (31)
Are the ICE ESC any more robust than the HV series? I've had 2 of 2 fail now.
Old 09-01-2010 | 07:50 PM
  #185
nonstoprc's Avatar
My Feedback: (90)
Can you please elaborate on the two ICE ESC failures? What went wrong?
Old 09-01-2010 | 07:55 PM
  #186
Mastertech's Avatar
My Feedback: (31)
ORIGINAL: nonstoprc
I never said I had an ICE failure. I've had two HV series esc's die. My 85hv and 110hv died. I'm hoping the ICE are better.
Old 09-01-2010 | 08:31 PM
  #187
nonstoprc's Avatar
My Feedback: (90)
sorry my mistake. Maybe elaborate on the failures on 85hv and 110?
Old 09-01-2010 | 08:48 PM
  #188
Mastertech's Avatar
My Feedback: (31)
The 85 just changed the throttle settings on it's own then died. The 110 was dead after I flew it. There is a thread on the 85 issue now. It mirrors my problems.
Old 09-02-2010 | 08:00 PM
  #189
What is the starting datum that you guys are using to measure your incidence angles?
Do we use the model sitting at a position that gives the 0.5 degree wing angle then adjust the tail, and if so, what thrust angle was that giving you? Matt13
Old 09-03-2010 | 01:15 AM
  #190
hi matt,
jig the model so the wing is giving you +0.5 deg , on the wing and fix the model steady at this point , now adjust your tail in to 0 deg on both sides and lock it off , ref to the thrust line i have et mine to the nose of the model , and will adjust the thrust lines if required,hope this helps.
rgds
steve
Old 09-07-2010 | 07:24 PM
  #191
apereira's Avatar
Hello all,
Does any of you owners of the wind S, can give some comparison to any other recent plane flying FAI? like, Axiome, Osmose Evo, Integral, Onas...... any.
I really like the airplane, and always see Silvestri flying with the wing fences, but do not see anybody else on this thread using it.
Regards
Old 09-08-2010 | 07:17 AM
  #192
My Feedback: (45)
I have talked to Chris Moon and he was going to email Silvestri to try to get the templates for the wing fences so that I could try them. I've flown Integrals, Black Magics, a couple of Visa's, Passports and many others, and this is certainly a competitive airframe. Being a mid wing design it presents better in rolling maneuvers than anything I've ever flown. I have no complaints on it. I wont say that it is the greatest flying plane ever, but it certainly flies as well as anything else I've flown. The airframe certainly wouldn't be a limiting factor if you were flying it.
Arch
Old 09-09-2010 | 10:50 AM
  #193
hey arch,
flew the wind`s ` today and yes this model does roll very compared to other models, no aileron trim req,only few clicks of up!!.
Old 09-09-2010 | 11:28 AM
  #194
My Feedback: (45)
Steve,
Very cool. That is almost identical to what mine needed. I then just slightly adjusted the stab to get rid of the elevator trim and have done nothing else with the adjusters since.
Arch
Old 09-09-2010 | 11:30 AM
  #195
My Feedback: (45)
Also,
After you drilled the holes for the stabs in the stab tube, did you pull the stab and look at the tube. Mine was just slightly short and you had to be careful that both holes actually had some "meat" around them. If you pushed it all the way in to one side and then drilled the holes one would be about 1/4" in and the other would be right at the edge of the tube or even worse, just slightly out of the tube. It may not be an issue for you on yours, but something to check anyway.
Arch
Old 09-09-2010 | 12:24 PM
  #196
hi arch,
had 6 flights today to trim the model up and set a few mixers , minimal knife edge mix and a tad on of down at low stick on the throttle, regards
to the tail tube you are spot on , could do with being a little longer as i drilled 3m in to mine and run cap heads, to be honest i have just orede another one this week , they are great value for money and a great model , the composite wings are out very soon and will fit straight on to the planes we own , so that will be a must to try.
regards
steve
ID:	1497966   Click image for larger version
ID:	1497967   Click image for larger version
Old 09-09-2010 | 12:35 PM
  #197
My Feedback: (45)
Steve,
Glad to know you are happy with it. I plan on getting another one as well. I saw where you placed your batteries. I shifted my CG slightly forward of where I'm guessing yours is judging from the battery location in the picture, and the knife edge mix went away and it didn't affect anything else. Snaps are still ultra crips and so are all the rolling maneuvers.
Arch
Old 09-16-2010 | 08:08 AM
  #198
Some pictures of my plane…
Plettemberg Xtra 30-09 EVO
Schulze 32.80 KA
PT Model's 21x 14 carbon
AIL Futaba 9551 x 2
ELE Futaba 9650 x 2
RUD Futaba 9452
Spinner Philippe Marquet 82mm
Reciever Futaba HS6008
Radio Futaba 12Z
Wheight 4700 grams.
ID:	1501765   Click image for larger version
ID:	1501766   Click image for larger version
ID:	1501767   Click image for larger version
ID:	1501768   Click image for larger version
Old 09-16-2010 | 08:09 AM
  #199
more..
ID:	1501770   Click image for larger version
ID:	1501771   Click image for larger version
ID:	1501772   Click image for larger version
ID:	1501773   Click image for larger version
Old 09-16-2010 | 08:11 AM
  #200
more...
ID:	1501775   Click image for larger version
ID:	1501776   Click image for larger version
ID:	1501777   Click image for larger version
ID:	1501778   Click image for larger version
