Supra Fly 60 build
Well here I go... I'm gonna do it. I've obtained a set of Supra Fly 2500 plans that I scaled down to match Hanno's 60 size specs. Thanks again bem!
It will be foam core wings, stab, and turtle decks. I have an original cowl that I will try to reproduce in glass. I also have a new canopy that Will need to be reproduced. I'm not sure about that one yet. I hope that anyone who has any pics or info post it here for all to see. I'll try to post pics as I get into this project.
I've been wanting to do this for a long time and started one other time on the 45. Please wish me luck! I'll need it!!!
Chris
Chris
Hi,
I assume You have seen that stab and wing templates on the drawing are the outer edge WITH sheeting. So You need to substract the thickness of the sheeting you are going touse so the templatesfor foam-cutting will be accurate. Just easy to forget this. Just measure on the drawing and You will see this.
It will be exciting to follow this build.
/Bo
/Bo
Here's a few updates... Got the gel cote in the mold, glass laid, and the first cowl out. It turned out really good for my first glass project. I'm also thinking about doing the turtle decks with glass or carbon fibre... The fuse sides are also done just waiting to get the formers finished up.
Chris,
very nicely done!
With the cowl and canopy molds, you should consider making a short kit including these, and laser cut wood for the fuse and cores for the wings, stabs and turtle deck. Glass, carbon decks sound nice but they do require painting. Using sheeted foam decks gives you the option to produce a model which can be entirely covered (except for the cowl).
BTW, what industrial mold material did you use for the cowl? Where to obtain it? I like what appears to be a relatively easy pour into the mould container approach.
David.
P.S. I'm building a Calypso at the moment - getting retract gear work done on the panels.
very nicely done!
David.
Thank you David, I'd like to do a kit for this but first things first. Once I get through this one I'll look more into that. I'm planning on painting the fuse so the glass or carbon deck will be quicker and easier for me right now. I'm even considering painting the entire plane.
The material I used for the mold was given to me by a friend that works in a pattern shop. It's called Pro-cast 132. It was very easy to use and didn't harm my brand new Supra-Fly 45 Unlimited cowl. I'm not sure were to get it but I bet there's a lot of other products just like it.
Chris,
Here are some more Supra Fly 60 pictures. It is from EZ Modelers Catalog No. 5.
Maybe they will inspire You on your way to building,finish and eventually fly your Supra Fly.
regards,
Bo
regards,
Bo
Chris,
very nice! Progress?
I'm just about 3 years behind you...
When you have some figures/info on the cowl/canopy and cores, please PM me with costs. It might also be worth looking into having the decks done in foam - precise and quick. Since one is sheeting wings/stabs, doing the decks as well as just a little more epoxy...
I did the decks with formers and sheeting but it is somewhat more time consuming if you want clean and light results (bored out all the formers).
David.
David.
The ones I haven't drawn up yet...
Actually, there are no Calypso plans I'm aware of so I will draw some up.
This is a Blue Bird (World Models) kit. For what its worth, some cores, some fuse sides and some badly warped glass, ply and balsa. Considering its a ~27 year old kit, I can't complain. Back in the day it would have been something - today, better off laser cutting fresh cores and wood. I was interested in your mold material in order to make one for this cowl. Hopefully, I'll get around to it before putting it in service.
David.
Actually, there are no Calypso plans I'm aware of so I will draw some up.This is a Blue Bird (World Models) kit. For what its worth, some cores, some fuse sides and some badly warped glass, ply and balsa. Considering its a ~27 year old kit, I can't complain. Back in the day it would have been something - today, better off laser cutting fresh cores and wood. I was interested in your mold material in order to make one for this cowl. Hopefully, I'll get around to it before putting it in service.
David.
This is very cool Chris.
So the ply plates on the bottom are to provide some structure to the plug? To pull the original canopy from the plug, do you simply disassemble the cradle and pull it right off? I imagine you need to spray the canopy interior with release wax - correct?
I understand that mold silicone is quite pricey but I bet it is really very fast compared to the traditional two part glass/epoxy approach - right?
David.
David.
