KingTech K-80
My Feedback: (21)
I just recieved my KingTech K-80. I did get it mounted on the test stand and had the opertunity to run it up. All I can say is WOW. She fired right up with NO adjustments needed to the ECU. I did 2 run ups on her, and she ran perfect both times. I plan on doing a few more test runs this Friday 4-2-2010 at the Nighthawks in North Jackson, Oh. Anyone wanting to see this new motor is welcome to come out.
Once My F-86 is done, it will be the home for the K-80. I will post pics of the install in the F-86. The F-86 is going to make a good platform for the K-80 as it is 17.5 pounds of thrust.
Here a few pics of it on the test stand.
Joe Lewis
KingTech Rep.
Joe Lewis
KingTech Rep.
Hi,
Yes, there is only 1 small adjustment you will need to make to your ECu setting... that is to lower down your glow plug power from 40 to 30...
check out http://www.rcuniverse.com/forum/m_92..._1/key_/tm.htm
Enjoy =)
Isaac
Enjoy =)
Isaac
ORIGINAL: Jetpilot24
Joe Lewis
KingTech Rep.
Joe Lewis
KingTech Rep.
The factory sets it pretty hot at 40, but at the same time this ensures a quick ignition, if anything, the included medium heat plug might wear out a little sooner. So, Isaac, you are right, one might dial that down a little, and it should still fire up quickly.
I personally have a surplus of medium hot plugs (Fox standard Long) and I dialed it down to 20 or there about and still fires up every time on the first attempt.
Have lots of fun with K-80s guys,
Barry
www.kingtechusa.com
Barry
www.kingtechusa.com
My Feedback: (21)
Thanks for the warm welcome to the family. I am looking forward to getting this motor in the F-86. Here is the link to the build.
Joe Lewis
KingTech Rep
Joe Lewis
KingTech Rep
My Feedback: (21)
I did 2 more runups on with the K-80 on the test stand Fri. Both went very good. I did some simulated flight by running where I thought it might run in the F-86. She never missed a beat. I did some slams from idle to full throttle and back. The K-80 ran flawless. Now I just need to get the F-86 finished and get the K-80 installed.
If anyone is thinking about a 17Lb thrust motor, the K-80 is the way to go. Barry with www.kingtechusa.com and he will get you set up.
Joe Lewis
KingTech Rep
Joe Lewis
KingTech Rep
HI
Hello All
Here is my JL F-4 with twin kingtech K-80's great turbines.
[youtube]http://www.youtube.com/watch?v=clBibvtjQjQ[/youtube]
Got mine from Todd at dreamworks, also a great person to deal with. It's so cool that Kingtech in the US has such great support.
ORIGINAL: hooker53
Joenice looking 86. be sure to get some footage of the maiden with the KingTech. Is everyone using turbine oil or has anyone tried the DTE-Lite on these???
If anyone wants to use anything other than turbine oil, please let us ok it first, so that the warranty will remain effective. Meanwhile, we'd be able to gather more data and learn from one another.
Thanks in advance,
Barry
KingTech USA Int'l
My Feedback: (21)
ORIGINAL: YellowAircraft
Hi,
What make is the Sabre?
Hi,
Here is a link to the Rebuild thread.
It was actually a kit. Remember when we use to build kits?
http://www.rcuniverse.com/forum/m_9277032/tm.htm
Joe Lewis
KingTech Rep
ORIGINAL: hooker53
Barry, So DTE-Lite is ok as per Factory?? AlsoHope you are having a very Happy Easter!!!
If you'd like to use DTE-lite, please write me a quick note through email, including the current cumulative time and I'll input it in your profile, so your warranty will remain effective.
Thanks Roy, Happy Easter to you too!
Barry
Chris:
KingTech Taiwan is making a FOD screen for the K-80 right now, and I should be getting them in a couple of weeks. I will email you and all the registered K-80 owner when it becomes available.
Barry
KingTech USA Int'l
Barry
KingTech USA Int'l
