Go Back  RCU Forums > RC Airplanes > ARF or RTF > NitroModels Support
 Nitro Models Pitts-40 Special Design >
NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
Old 03-08-2008 | 09:43 PM
  #76
opjose's Avatar
Default RE: Nitro Models Pitts-40 Special Design
It's somewhat pitch sensitive, due to it's very short tail.
This is by design so that the Pitts can do those awesome "tumble" manouevers that other planes cannot do.
If this is to be your first Biplane, consider something with a longer tail.
An Ultimate does not have an elongated tail like a Skybolt, but it would be better suited to be your first aerobatic biplane.
Even with it, there will be many new things you have to deal with.
A Skybolt tracks as if is on rails, but doesn't do many of the classic moves the Pitts and Ultimate can do.
Old 03-08-2008 | 09:56 PM
  #77
theradioflyer's Avatar
Am I correct in that the Red is the originally the Kyosho pitts S2A?
Edit: I take it back. Most likely made from the same factory mostly same parts but Kyosho's tail feathers are different.
Old 03-09-2008 | 01:39 AM
  #78
EvaderMaster's Avatar
Would it not be so bad on low rates? I thought biplanes just have more drag than a normal aerobatic plane, especially coming in on landings when you can notice it.
But in other words was the point trying to come to me is that a ultimate would be a better biplane to start with?
Old 03-09-2008 | 01:50 AM
  #79
opjose's Avatar
The Pitts has a shorter tail, and hence it is less stable in pitch than the Ultimate or Skybolt.
Low rates do help, but I would not recommend this plane as a first BiPlane.
If you are new to Biplanes you have to contend with several minor differences over single wing tail draggers.
As you mentioned, they have higher drag, so they must land under power.
They tend to yaw more.
Due to the shorter wings they tend to roll a bit dependant upon throttle position.
They need longer takeoffs, no yanking the elevator back, least you lawn dart the plane.
The Pitts is designed to be highly aerobatic, and it has a short tail moment.
That's not to say you could not fly it... but if you are trying to decide which Biplane to get first, I'd advise you to start out with another aerobatic biplane. The Ultimate 40S is a bit easier to fly.
Old 03-11-2008 | 03:41 PM
  #80
My hat is off to Nitro Models. They did a great job of packaging ,speedy delivery and there were no broken parts. I have begun assembly and I must say that I am tempted to order another just in case. I was wondering about the aileron servos though,in the event that I might over power a little, it started me thinking about striping out those small servos. If anyone has any ideas or has used larger ones I would like to know which ones and how they worked. Who knows maybe the 81's will do just fine but I would hate to find out the hard way. I also wanted to know how everyones model balanced out and if any weight had to be added or what. Thanks guys and again ,Great Job NITRO MODELS I would buy from you guys again in a minute
Old 03-11-2008 | 03:57 PM
  #81
I used Futaba S3115's for my ailerons. I think they will be just fine but I still haven't flown mine yet so don't know for sure. I sure hope the weather around here improves soon.
Old 03-12-2008 | 01:19 AM
  #82
marquisvns's Avatar
Hi there, the orange ones for $85 are all sold out, anyone has any idea where to buy one? the cutsie orange ones?
[email protected]
Old 03-12-2008 | 02:34 PM
  #83
At the price they were selling at it's no wonder they sold out. I haven't seen them anywhere else. Hope you find one.
Old 03-12-2008 | 02:52 PM
  #84
I saw the red version at this link for 125.00
http://www.raidentech.com/pisp40arfnig.html
http://www.egrandbuy.com/biplanes.html orange version
Old 03-17-2008 | 03:46 PM
  #85
linkadrip, I am wondering if you have had the chance to fly your plane yet? Mine is still sitting on a shelf waiting for the weather to improve.
Old 03-17-2008 | 07:41 PM
  #86
linkadrip's Avatar
Nope no Maiden yet Still have a few things to iron out with the Engine it beign new and not fully broken in yet Still have to make another hole in my Cowl to adjust the LSN and The tail wheel needs some work.
Today was the first nice day we have had here would have been a great day to maiden the plane. I just want to make sure it's right. my CG is a 3 inches from the leading edge of the top wing. SO i'm pretty certain i have to move the battery back behind the cockpit. Or add weight witch i really dont want to do.
But its still cold here And will be warming up and i'll get her out there. Going to work on some of them things tonight most likely. So maybe next weekend i will get a chance unless we have another freak Snow Storm like this past weekend. IF you get to maiden before i do will be happy to here how it went.
Old 03-18-2008 | 07:46 AM
  #87
I probably wont be able to get out with mine for about another week. After that my calendar is clear, and I hope the weather will be too. The plane is all set to go.
Old 03-26-2008 | 05:57 PM
  #88
I got so close to finally flying my plane today. Got to the field and got it all set up and ready to go, checked the controls and everything was set. Fueled it up and disaster strikes. The fuel tank had split just above the bung. I sealed the tank area well so not much of a problem with the fuel that leaked. So close, Saturday looks to be good so I'll have to try it again then.
Old 03-30-2008 | 04:11 PM
  #89
My Feedback: (12)
Well I've been following this thread hoping to see a first flight report but due to bad weather for everyone else, i guess i'll go first....I purchased this model a couple weeks ago, and despite several problems, it went together alright. They sent me the decals and manual from the Ultimate 40. (So i now have a pitts with ultimate stickers on it! [8D]) I powered mine with a Thunder Tiger Pro 46 with Jtec Pitts muffler. I'll try and post some pics later tonight if possible. It was rather cold and windy here today, but i had to fly it or crash it one. The pitts actually has nice ground handling for such a small coupled plane. Mine required nearly full right aileron and 4 clicks of down trim to get her straight and true. The tt 46 is a monster in such a small plane. Its an absolute rocket!!! I have near max throws on mine and it may be too much depending on your flying skill. KEEP THIS IN MIND as it will snap very hard!!! Flying wide open and pulling up putting the sticks in the corners will let it tumble very tight and fast, BUT it will spin several more times after the sticks are released. so be a few mistakes high on your first few flights. This plane's small size doesn't fare so great on really windy days either. But all in all, its a great flier!!!! Much better and more relaxed than I had expected...i used to have a Global tequila sunrise 25 that I was initially gonna compare it too, but theres no comparison!!! (Thank God!) You'll need to keep quiet a bit of speed on when you bring it in for a landing, as it will tip stall in a heartbeat!!! I have 4 successful flights on mine so far and bring it in around 1/4 throttle till its right over the runway and then bleed it the rest of the way off for a nice 3 point landing. No bounced landings so far.....So, for $85 on the closeout price, i got one heck of a deal on this beast!!! Its one nice lookin plane too........I hope the weather clears soon for you guys, cause your in for a treat on this one!!!
Oh ya, be easy on the elevator when you take off so it desnt try and snap on you....I hate to keep rambling but I also need to stress that you LOCKTITE the small bolts and nuts on the struts. After my last time up, I looked my plane over and had one bolt about to fall out......So be sure and keep an eye on them......take care guys!
Old 03-30-2008 | 04:18 PM
  #90
opjose's Avatar
ORIGINAL: BIGUGLYSTICK
Yup this is the most often made mistake with these short tailed planes, and it is particularly dangerous on the Pitts.
Don't ask how I know....
Old 03-30-2008 | 05:30 PM
  #91
linkadrip's Avatar
That's is great BIGUGLYSTICK Congrats on your maiden.[sm=thumbup.gif] I ran mine today trying to get it ready to fly. having so many problems with this Saito .62 Ordered a turbomuffler for it waiting for that.. the engine runs good just wont idel below 2000 rpm. But when i get my new muffler i'll check all my lines again have to take the cowling off to install the turbo muffler. But i'm sure its going to be intresting to fly. That is if the Weather ever gets better. I ran it around the yard on the grass and was suprised that i Goes pretty good the Steering on mine isnt real great. Doesnt turn very sharp like my other planes. this one needs alot of room to turn it around.
Old 03-31-2008 | 03:03 PM
  #92
Linkadrip,
Sorry to hear the problems with your engine, my Saito .62 has run great from day 1. I finally got to fly mine on Saturday. Only got two flights on it though, because the landing gear came off on the second landing due to pilot error. Real simple fix with no major damage.
The plane flies great though! Took quite a bit of left aileron trim but other than that it flew great and didn't notice anything bad about it at all. The Saito .62 is perfect for it with great power but not too much. It didn't seem to be pitch sensative at all and tracked straight and flew very smooth. I think I will really enjoy flying this plane.
I should have left the wheel pants off and used larger wheels the first flight because the field was not in the best shape. I can't wait to fly it again.
Old 03-31-2008 | 07:30 PM
  #93
linkadrip's Avatar
pkevinb
Congrats on your maiden i'm almost there. Maybe next weekend waiting on a turbomuffler have to readjust my throttle linkage So the idel wont drop below 2200RPM. have to move my battery behind the cockpit CG is currentl 3 inches from leading edge of top wing i dont think that is good since the manual state 4 inches.. But it taxies around on the grasss fine as long as i dont drop my throttle down below 2000 rpm it wont die so my linkage is not adjusted correctly.
Wondering what Prop you used on yours i have a MAS 13X5 on mine. I'm getting closer though soon..
Old 04-01-2008 | 07:39 AM
  #94
I used a MAS 12x6, and it seemed to work well. I have my plane repaired an hope to get it out again tomorrow.
Old 04-20-2008 | 08:52 PM
  #95
linkadrip's Avatar
Well i'm ready to fly this plane but i need to know how others got it balanced out to 4"CG behind the leading edge of the top wing i'm at 3" i want to fly it. but not sure if it being at 3 is going to be a real bad deal. It wants to tip on its nose when i goose it with power. I took the bottom wing off and i can't see a way to move my battery back without taking the servos out.Am i going ot have to do this? or should i just get some stick on weights and stick them on the aft part of the fuse. Any idea's pictures would be really nice of were others have there battery mounted. Mine is sitting currently righ above the landing gear since ther was a nice spot for it there.
But i know i'm going to have to move it or add weight to the Aft of the plane.[]
Old 04-21-2008 | 10:22 PM
  #96
linkadrip's Avatar
Ok Took the servos out got he battery moved back finally under the servos and it balances out to 4 inches behind the leading edge of the top wing. So i'm going to go fly it. Wensday Suppose to be clear. Hope it flys good. It will eighther fly or crash. Think i'll strap a camera to it. For an inflight video of its maiden in case it doesn't make it back at least i'll have a record of its first and last flight. Lets hope it just its first flight and not its last. I install alot of confidence in my flying abilities. This will be the first time i ever flew a nito powered pitts biplane. My other biplane i didn't have very good luck with. Lets hope this one is better.
Just have to remember easy on the elevator on take off and landing and landing is hot comes in fast to avoid tips stalls.
Definetly will try and do.
Old 04-22-2008 | 12:12 PM
  #97
I have a lot of experiance with a ultimate 40 ,it is probably similar to the pitts , it does probably not tipstall ,it just falls down when you take the throttle back [)],it is kinda difficult to fly. I have a saito 72 on the ultimate ,would that one fit on this pitts?
Old 04-22-2008 | 12:37 PM
  #98
linkadrip's Avatar
I have a Saito .62 in mine. I would imagine you could put the saito .72 in it but getting in balance at the recomended 4 inch CG may be a little difficult. And really the plane doesnt need as big an engine in it as i put in it. A .46 is major power for it from what i have heard. its not a real heavy plane. mt superstar 60 trainer has a saito .72 in it and it is over powered and weigh alot more then the pitts 40.
But you can do anything you put you mind too. but i would say the saito .62 is to much for the plane gonna find out tommarrow if it is or not..
Old 04-22-2008 | 12:52 PM
  #99
Yes ,and when you have a heavy engine it lands faster =) Cool design on your pitts! Good luck , those bipes are the coolest to fly!
Old 07-02-2008 | 02:58 AM
  #100
linkadrip's Avatar
Well i thought it time for an update i havent taken pictures of my crashed pitts 40 yet lol. but lets just say it flew great it was awe some then the aileron jammed. and that was due to my setup i think still not sure on that one. but the plane went down and hit nose first into terra firma and broke the front of it and damaged a wing it has been sitting on the work bench for some time and i'll be rebuilding it here in the near future probably this winter..
I'll post some pics of the damage here later on most likely when i get around to repairing it. but the plane did take off nicely and flew very stable till i had no cotrol over the turn.[:@]
