NITROMODELS REPLACEMENT PARTS REQUEST_Post Here
#427
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here
I have just assembled my Dynam A-10 EDF.. When I plug in the battery, the throttle runs WIDE open and will not respond to the Transmiter.. Everything else is in sync with transmiter, just having problems with the throttle.. Any ideas what would cause this ??
#428
ORIGINAL: FlyDeltaJets2007
Thanks, Timmy! Just let me know what I need to do to handle the payment particulars.
ORIGINAL: Forum support1
I will try to find one in the warehouse and ship it out for you my name is Timmy and I'm from nitroplanes.com.
I need a replacement nose cone for the Airfield 64mm F-18 (Gray).
My order information:
Order #: 944923 (http://www.nitroplanes.com/f18c-64mm-grey-rc-jet.html)
Part I need: 93A18-05-Gray-NoseCone
I would like to order 2 or 3 if possible as the flimsiness of the nose cone tells me this will likely happen again.
I received a voicemail from you guys today (couldn't quite here the caller, Aaron/Harry?) regarding my request to get a replacement nose cone form my Airfield 64mm F-18. He asked me to call back, but didn't leave a phone number and my caller id just said "Private Number". Please pass this on regarding Order Number 944923; I would like to order three (3) replacement nose cones (93A18-05-Gray-NoseCone
) if I can. Please PM me or send me an email to let me know what number I need to call back to get this taken care of. Thanks!!
#430
NL, CANADA
Hi. Please see my post in a new thread titled 'Thunder AC6 never did work' in this support forum. I bought a charger from Nitroplanes when I bought my Airfield 1450mm P-51 Shangri La back in May or June.Order # yhst 123131.Never could get it to charge any liposwhen plugged into the lipo port. I ordered a new lipo card/adapter but I still get the same 'connection break" message. I can charge a car battery using thered and black leads that use the other connections right next to the lipo jack. I guess the main unit/box itself is defective. I have been in contact with Candy at Hota Company and she thought it was the lipo adapter/card but that doesn't seem to be the case. I guess I'll need to send it back? Please let me know. Thanks. Mark Taylor
#431
MD
Hey Guys,,
I am finishing my Yak "50size blue" Upon unwrapping the cowl it is cracked,, No real biggie,,, but I would like to order a new cowl.
Tom
Tom
#433
MI
i called nitro and they told me i had to have the item number off the website but i cant find it anywhere, please help
#434
Hi,
I just bought and completed your 56" yak 52 model. It's the $80 special blue version 2 airplane with the pull-pull and strengthened wings and tail: see link to your add here:
http://www.nitroplanes.com/yak523d5056v.html
Very nice kit and a good deal for the price to be sure. I had read on RCGroups.com and RCUniverse.com forums about the many stabilizer failures the earlier version of this airplane had but was reassured by the note in the advertisement that says that version 2 has a strengthened stab and rear fuse. During assembly, I thought the stabilizer still looked mighty weak but I went ahead and built the plane per directions assuming the problems had been fixed.
My plane flew extremely well on the first flight, but on the second time up the stab fluttered and sheared off flush with the fuselage in straight and level flight at part throttle, causing a major crash. The fuselage survived with minor damage but both wings were severely damaged. When I looked at the failure, I could see that the stab has no reinforcement at all, it’s just made of 5/16" soft balsa sticks with no spar or sheet stock and is very flimsy, so it's no wonder it failed. Apparently whatever upgrade was made has not solved the problem the old version had with stabilizer failures. I can send pics of the fracture if it helps. I accept partial responsibility for the in-flight failure because I should have trusted my instincts and removed the covering from the stab and reinforced it properly, but this is still a real weak link in the design.
I wan to buy a replacement airframe because it's a great kit, but I see the sale has ended and the same plane (although red instead of blue) is now $125. I don't want to pay 50% more for a replacement than I paid for the original.
The only consideration I’m asking from NitroPlanes is to allow me to buy a replacement airframe for the same $80 I paid for the original. I’ll reinforce this one for sure! Here is the link for the identical version 2 plane that I ordered, except in red (the blue is out of stock now.)
http://www.nitroplanes.com/20redyak523d.html
I note you have another 56" yak for $99 but it is different, doesn't have the pull-pull and doesn't appear to have inserted wings or a firewall setup for electric motor. I definitely am not interested in that one.
my order number is yhst-17210252890263-146654.
Thanks and keep up the good work supplying low cost RC gear.
Scott
By the way, your message queues are full at RCGroups and RCuniverse and it is no longer possible to send PMs to you from those forums, you might want to clean them out.
Scott
#435
My Feedback: (57)
TX
have any of you guys gotten any responce from nitro planes lately. I can't even get them to tell me if and when they are going to get parts in for my jet or my FW 190
#436
Flag this message
Re: order yhst-17210252890263-149883 - Defective P51 airplane
<nobr>Tuesday, October 12, 2010 6:16 PM</nobr>
"Nitro Models R/C Plane" <[email protected]>
Add sender to ContactsTo:
"Paul Haskett" <[email protected]>
<style type="text/css"></style>
Sorry but as our policy states, we do not warranty any types of crashes. Any questions, please refer to our policy page or contact our customer service.
Best Regards,
Nitroplanes
www.HOBBYPARTZ.com is now offering FREE Shipping to Domestic USA! FREE SHIPPING + NO RESTOCKING FEE! 100% CUSTOMER SATISFACTION GUARANTEED.
One-stop Superstore!
Best Regards,
Nitroplanes
NitroModels Inc.
"Where high quality models are made affordable"
<hr size="1" />From: Paul Haskett <[email protected]>
To: [email protected]
Sent: Sat, October 9, 2010 2:02:13 PM
Subject: order yhst-17210252890263-149883 - Defective P51 airplane
**Please note I am a return customer. I have purchased multiple planes from you and they have worked fine and still fly. I am experienced RC pilot on both planes and helis** A week ago Saturday, I purchased the P51 airplane. I recieved my plane on Thursday. I set it up and got it ready to fly. I did all the recommended pre-flight testing and setup and found the plane appeared to be ready to fly. When I took the plane out this morning to fly, it taxied fine and the minute I took off the plane banked hard to the left and dove straight into the ground. I retrieved the plane and checked the CG and tried to fly the plane again. The second time I put the plane in the air it did the very same thing. Banked hard to the left and dove right into the ground. I adjusted the battery and attempted to counter the balance issue, however the 3rd and final flight I attempted the plane still rolled left and dove down. I am no longer interested in attempting to adjust the plane to counter the balance problem that appears to be with the manufacturing of it. All previous purchases from you have not had this issue, and have not required significant amounts of adjustments to getthem in the air. I beleive this plane simply is defective and I would like to proceed with the process of exchanging the P51RTF and getting one that is, hopefully, not defective. Please advise ASAP how we can proceed with rectifying the issue, and getting me a P51 that I can enjoy as much as the F16 EDF Jet 70mm that I recently bought from you and love flying. Below is my record of purchase, as well, you can look to see my other purchases on file. |
#437
John, I am inquiring about a new cowl and manual for the Super Chipmunk-40 ARF. Are they available? If so, please advise cost and delivery. Thank you, LSB ([email protected])
#438
IA
When are replacement parts for the 1450 mm P-51 going to be available? Specifically the 2 blade spinner, electric motor, ESC, tail, wing, and etc. Lack of replacement parts is a killer.
#439
Good luck in getting replacement parts....10 months ago i requested availability of a cowl and canopy for my Marchetti SF260 plane from nitro and they never had it....still waitting...........angelo1939
#440
NL, CANADA
IN
I looked through website, cant find this part.. Ultimate 50cc stab and elevators. the right side separated in flight. Still flew good and got it down without issue.. But alas, I need a new one. Do you have them?
#444
Super Chipmunk 40, replacement cowl needed!! any body have any idea where I can get one? they have been out of stock at nitromodels this entire year.
tnx
tnx
#445
Well, like so many Ineed a fuselage for J3 Cub...been sold out for years...gave my order up a month ago and nothing...no Idon't even get a response...better yet, just send me a new plane...Imean dang
#446
CA
NITROMODELS STAFF,
HELP PLEASE,
I need a new wing set for the CMPro F6F Hellcat- 90.
Please respond back to let me know if available.
Joe
HELP PLEASE,
Joe
#447
order # yhst-17210252890263
plane: red ez hawk
probelm:
i've assymbled the plane and exp. problems when I turn on the trans. and plug in the bat. I get no responce from the servo's or no beep from the ecs unit. I Think its either the Rx or the Tx. Plz help
#449
I have a CMP Zero Fighter 50cc - 80" ARF and recently flipped it over on landing. Unfortunatly it broke the canopy. Is it possible to buy a new canopy? The one I have is the one from this page of your site: http://www.nitroplanes.com/cmpzefi80arf.html
Thank you,
Thank you,
#450
I also have a Boeing P-26 Peashooter 90 - 71" ARFthat also has a broken canopy. Is it possible to buy a new canopy for this airplane? The one I have is the one from this page of your site: http://www.nitroplanes.com/boppe9071arf.html
Thank you,
Thank you,
