Go Back  RCU Forums > RC Airplanes > ARF or RTF > NitroModels Support
Reload this Page >
NITROMODELS REPLACEMENT PARTS REQUEST_Post Here
NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
Old 08-30-2010, 04:14 PM
  #401
Michel
Default RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here
Hi
Well ,.......................... I was wrong ,............. this thread is worth something .
I was looking for a Canopy for my CMP Zero 120 , and a good modeler has helped me out from this thread .
I will hold a small reserve for CMP though , I wish they would give there product support a little more oppenness . As far as I can translate . If you didn,t buy it from them ,................. they are not interrested in you, and they give you , a real COLD shoulder . It is the first time , in this hobby , that I have dealt with a company like this , with this attitude .
Please CMP ,.......................... Change youre policy ,................. I bet you it,s worth it .
All the best CMP
Michel Gravelle
Old 08-31-2010, 06:38 PM
  #402
ptmyers
I recently purchased the MQ-9 Reaper. The kit is missing a collet for the main front landing gear. What do I need to do to get a replacement?
PT
Old 08-31-2010, 07:05 PM
  #403
Michel
Hi
Just do the same thing I did ,.......................................... PRAY , just kidding . Keep looking you,ll find one . I found my part
Michel
Old 08-31-2010, 10:05 PM
  #404
ptmyers
Sorry, thought this was a site where nitroplanes would help with getting parts.
Old 09-02-2010, 09:16 PM
  #405
jinwoo
My Feedback: (7)
Hello,
I just completed the assembly of 3D Hawk received
While I was doing the test of electronics, everything was working fine.
After all has been set up, I disconnect the battery and came back 30 minutes after then connect the battery again.
After couple of seconds, The ESC caught on fire
I believe I have a defective ESC
Can you send me a replacement?
Jinwoo Lee
Here is order number
order yhst-17210252890263-143082 from Nitro Model R C Planes RC Airplane Electric Brushless Nitro Gas Jet Aircraft
Item is
3D-Hawk+Brushless 91A-3DHawk-ARF
outrunner+2S ESC+3*5g
Old 09-03-2010, 11:59 PM
  #406
arcticflyer
Dear Nitro Staff, You huys have been good in the past I hope things are still that way. I just received and built a MaxJet F-18 Tiger Meet kit order(913465). Just to let you know I am an advanced builder/pilot with many years of RC experience. This however, was my first foam EDF kit. Build went fine and I liked the kit.....however on the maiden flight I took off and circled the field one time then lost roll control suddenly (still had elevator and throttle) which resulted in the destruction of the front half of the plane.
Upon inspection of the plane the receiver was still on and all the servos were still plugged in. None of the control surfaces were damaged. The receiver was NOT blinking which indicated no loss of signal. No flutter was heard from the control surfaces....I then cycled the controls and noticed that the inboard (FACTORY INSTALLED) hinge on the right wing had let go.... This hinge was clearly defective and caused the loss of my plane and possibly an expensive lipo battery.
Attached are photos of the hinge and plane. I am willing to send the portion of the wing with the aileron and defective hinge back to your location for inspection at my expense. I am requesting that the entire airframe (kit) be replaced as this was a factory defect.
Thanks, Stan
ID:	1494844   Click image for larger version
ID:	1494845   Click image for larger version
Old 09-04-2010, 09:31 AM
  #407
mattkov
Hey nitro support , on my 4th flight ive crash with my guan li piper 3 j cub and now i need a new elvator and a rudder wich is strange cause the plane had no damage at all the reason of the crash was that the rudder and elevator had a default of fabrication so when i wanted to turn left the rudder just broke anyway so the plane felt and crash on the tail (wth)anyway now i need a new rudder and elevator thanks matt
Old 09-06-2010, 11:15 AM
  #408
steve1mac
steve1mac's Avatar
John,
I need a new front cowl for a  Skymaster 337 46 - 81". I have the Red White and Blue model.
http://www.nitroplanes.com/337sk81nigas.html
I didn't find it in your parts and accessories web page.
How do i place an order for this part?
Old 09-09-2010, 08:07 PM
  #409
arcticflyer
My faith has been restored......After I was finally able to get through to Nitro I got GREAT SERVICE and the problem will be taken care of. Will be doing more business in the future!
Old 09-14-2010, 09:35 PM
  #410
bamiller
Hi Nitro staff!!!
I am trying to find some replacement motors for my guanli A-10 thunderbold (the original brushed motors)  I am trying to find the Twin 370 ducted fan motors that I can order or purchase.  These guys just never lasted longer than a flight or two with the recommended upgraded lipo battery.
http://www.nitroplanes.com/new204chathi.html
I had this problem once before and John just shipped two motors over to me.
This was the model I had purchased at one time and loved flying it.  I want to see if I can keep the stock motors running on this model while I purchase an entire upgraded plane separately.
I don't have my previous order number but can find it if needed.
email at [email protected] or [email protected]
Thanks soooo much in advance.
-Brent
Old 09-15-2010, 08:28 PM
  #411
steve1mac
steve1mac's Avatar
John,
Old 09-16-2010, 02:21 PM
  #412
Half Fast
Nitroplanes:
I have a F4 Phantom EDF that I purchased in the spring of this year. It is the USS Constellation model (gray) and flies great. Today on the takeoff roll the fan disintegrated. I think the bolts holding the fan to the motor came loose but I am not sure. No other damage that I can find. Motor runs fine. I think this was a 68 mm unit. Could you please send me a replacement fan. I cannot get through on your phone line. I've been on hold for over an hour.
Please let me know if you can help me.
Bill
[email protected]
Old 09-19-2010, 07:25 AM
  #413
johnnychimpo
johnnychimpo's Avatar
I would like a Pole Cat Fuse with tail section and everything needed to rebuild the fuse. My garage was broken into and they took my pole cat fuse.
Old 09-21-2010, 08:19 PM
  #414
beavis242-RCU
Ok so it is now 2 years without landing gear for my katana 140 plane. I just got a reply they will be in in 4 to 6 weeks LOL I get that every 4 weeks for 2 years now. All this time they have kits in stock. They wont take gear outy of a kit or order a set for me in 2 years.
Check my past posts on here begging them to buy a set
Beware of Nitro planes they are the worst suppot in the industry I have run into in 25 years of flying.......
Old 09-23-2010, 08:01 PM
  #415
ol_seabee
Hi
Could you get me a right wing panel and maybe an engine cowl for a 68" Katana 120?
i.e 90A210_Gas_Katana120
The aileron and wing filet are ok if unavailable
ps. I'd be willing to buy a complete arf kit of this model if available
Old 09-25-2010, 04:16 PM
  #416
FlyDeltaJets2007
I need a replacement nose cone for the Airfield 64mm F-18 (Gray).
My order information:
Order #:  944923 (
http://www.nitroplanes.com/f18c-64mm-grey-rc-jet.html)
Part I need:  93A18-05-Gray-NoseCone
I would like to order 2 or 3 if possible as the flimsiness of the nose cone tells me this will likely happen again.
Old 09-28-2010, 04:43 PM
  #417
Forum support1
ORIGINAL: FlyDeltaJets2007
Order #: 944923 (
I will try to find one in the warehouse and ship it out for you my name is Timmy and I'm from nitroplanes.com.
Old 09-28-2010, 06:19 PM
  #418
FlyDeltaJets2007
ORIGINAL: Forum support1
Order #: 944923 (
Thanks, Timmy! Just let me know what I need to do to handle the payment particulars.
Old 09-28-2010, 06:29 PM
  #419
Michel
Hi
Timmy ,................................ any chance you have a canopy for a Zero 120 some where in the warehouse ?
Michel
Old 09-29-2010, 07:49 AM
  #420
johnnychimpo
I just got my CMP Edge 540T. My cowl is cracked in several places on the left and the canopy, plastic part, has a large chip out of the side.
Old 09-30-2010, 02:08 PM
  #421
Forum support1
Michael you want me to find the canopy for you for the zero fighter cmp 120 size right let me go ask my warehouse manager.
Timmy
Old 09-30-2010, 02:35 PM
  #422
Forum support1
Michael and Johnny I got those parts on my table right now. Could i get your guys order number please?
Timmy
Old 09-30-2010, 03:40 PM
  #423
Michel
Hi Timmy
How do I get that canopy for my 120 Zero from you
Can you E-Mail me at [email protected] , so that I can get an account . I don,t have an order number []
Thank you
Michel
Old 09-30-2010, 04:09 PM
  #424
opjose
opjose's Avatar
ORIGINAL: wl7cpa
This is third request with no answer to date:
One more try....
Do you stock the wheel pants for the CMP Katana 120-140 size plane? They are too thin and crack very easily.
You can easily glass the insides for more strength.
Also you can use stock sized pants as replacements, though you do have to paint them to match.
Old 09-30-2010, 09:44 PM
  #425
sradd
When are you going to start carrying spare parts for the 1400mm BF-109 and 1400mm Spitfire.
