THE LOUNGE 2
IL
RE: THE LOUNGE 2
ORIGINAL: Lunchboxer
All your cars in your garage now have plenty of parts support.. so you can go hard at it!!
Of course, I'm told there is/will be a Cat S1 being made, with a non-CF body to make it cheaper if desired. So that's on the "want list", but also on the "crappy parts support" list. Gah! [sm=drowning.gif]
RE: THE LOUNGE 2
Heres a couple of pics of my TT-01E (pre-build)
I cant wait to paint this shell - i might use up the last of that lovely pink paint ... (joking)
The sticker sheet is the full size of the box, i dont think i'll be going box art stickers on this one !! [8D]
RE: THE LOUNGE 2
That's a lot of stickers there Luke.. are you sure you need to paint the shell at all?! hee..
There is a little bit os pace which the paint shows through lol
im not sure wether to do it all white
or white with a black middle
RE: THE LOUNGE 2
RE: THE LOUNGE 2
i was looking through some forums and i came across somthing lb and some of you other guys might remember, 2wd buildoff!!. how many of you would partisipate in it if i set one up? it would follow the same base rules as the first one, but with a few twists to make it interesting.
RE: THE LOUNGE 2
this is what i was referring to http://www.rcuniverse.com/forum/m_50...key_2wd/tm.htm
RE: THE LOUNGE 2
Ha, CT4L started that one..
It might be hard for someone who doesn't have a machine shop at home if we are going by that rule.. (parts have to be custom made?)
RE: THE LOUNGE 2
i dont have any large tools. besides a few hand drills, a rotery tool, and a grinder i dont have any power tools at all and i have built some pretty high quality parts for my cars. all you need is a torch, a bolt cutter, brass, and solder with flux. make a frame out of rod or tubing (builders prefference), put a brass plate in the front and back with holes for the gearbox and the steering system and some way to mount the suspension arms, plate it with aluminium plates and you got a tuber style rig.
RE: THE LOUNGE 2
Sorry to hear.. what were you doing before?!
ORIGINAL: Ttam Says Blarg
Lost my job.I don't know what I'm going to do now.... Since I live on a mountian jobs are really hard to get.
RE: THE LOUNGE 2
RE: THE LOUNGE 2
As I said earlier, we got some more snow this morning..
Didn't take me long to clean up the driveway.. good workout.. ha!
