Off Topic Forum - Cars, Trucks, Buggies and more Get to know your fellow RCU member modelers in here and discuss off topic non-rc stuff. Only two topics OFF LIMITS are religion and politics. This forum for car & truck members. Plane & Heli members have their own in clubhouse section.
cd drive not functioning properly
Old 12-27-2007 | 05:29 PM
-whitey-'s Avatar
Default cd drive not functioning properly
my cd frive wont read newer cds like crysis wich my brother just bought and the orange box i got for christmas but older cds for counter strike source work , why is that?
BTW i upgraded my ram a graphics card.
Old 12-27-2007 | 05:34 PM
Foxy's Avatar
Default RE: cd drive not functioning properly
If it's a CD drive, that's why. Those games are on DVDs. Changing your RAM or graphics card shouldn't have any effect on your optical drives. If your RAM is the wrong speed or configured incorrectly in your computers BIOS, that can cause files being copied from the DVDs (like when installing) to give CRC errors, or create corrupt files on your hard disk as they are copied over. What 'exactly' is happening?
Old 12-27-2007 | 06:29 PM
-whitey-'s Avatar
when i put in the cd it just spins and says theres nothing in the drive, and im sure my computer can read DVDs.
Old 12-27-2007 | 07:10 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
All optical drives (i.e. CD, DVD, rewritable, etc....) are labeled on the front of the tray. Look at your drive and it will tell you if it's CD or DVD. If it does indeed say DVD then your drive has gone bad and needs to be replaced. If it doesn't say DVD then it's not capable of reading DVD's.
Ken
Old 12-27-2007 | 08:00 PM
ORIGINAL: -whitey-
The tray should be labeled like Ken stated. If still in doubt, put a DVD movie in it and see if it will play.
For example, my tray is labled: DVD+/-R/W / CD-R/W. This means it is good for both CD & DVD and will read, write and re-write on these mediums with the correct discs and software.
Old 12-27-2007 | 08:48 PM
-whitey-'s Avatar
yup its DVD compatible.
Old 12-27-2007 | 08:52 PM
RCKen's Avatar
My Feedback: (9)
In that case I would say that your drive is bad if it won't read DVD's. You'll need to replace it. But it's not a big deal as DVD (even DVD recording) drives are pretty cheap. Takes about 10 minutes (or less) to change one out.
Ken
Old 12-27-2007 | 09:07 PM
-whitey-'s Avatar
thanks , but i want to be 100% sure before i change it.
Old 12-27-2007 | 11:32 PM
I would check for any updates for the drive, then if that doesen't work re load the driver. It worked for me
Old 12-27-2007 | 11:58 PM
-whitey-'s Avatar
ORIGINAL: nitrohog
how do i reload the driver?
Old 12-28-2007 | 10:42 AM
Go to the manufacturers web site (player mfg, not computer) and look for driver updates. Then download the appropriate one. Even if your current driver is the same it may have been corrupted so download it regardless.
Old 12-28-2007 | 12:30 PM
-whitey-'s Avatar
im really not good with things like this , i cant find the correct update for my driver, all i know about is that its a TSSTcorp cd dvdw ts-h552l , can anyone help me find the update? Thanks in advance.
Old 12-28-2007 | 02:37 PM
http://www.samsungodd.com/eng/
Looks like a Samsung product. Try their customer LIVE support at the above site.
Old 12-28-2007 | 04:33 PM
-whitey-'s Avatar
man this isnt as easy as i thought it would be to fix , there doesent seem to be any sepport for my model[] , can i do something like uninstal the driver and reinstal it?
Old 12-28-2007 | 05:05 PM
Foxy's Avatar
I wouldn't bother reinstalling the driver. Basic optical drivers are provided in windows, I've never HAD to install a driver for an optical device in a 15 year career in IT. If it worked one day and doesn't work the next, just replace it, a DVD writer is what, $30?? Is that really worth your time messing about and downtime of your games/music? If you replace it and it still has a problem, then we can start looking at Windows or drivers for solutions, and even if that is the case, it's still advantageous once you do get it all working again, to have two DVD drives.
Old 12-28-2007 | 05:28 PM
RCKen's Avatar
My Feedback: (9)
As Foxy has pointed out, the "drivers" to run the DVD drive are a core part of Windows. If they weren't working properly your hard drive would more than likely not work as well. Trust me here, I do this for a living. My wife and I own and operate a computer shop so I see things like this all the time. Optical drives like CD's and DVD's can go out in a heartbeat like this. They will work one day and not the next. It's a very simple procedure to replace the drive and be back up and running in no time.
Ken
Old 12-28-2007 | 08:12 PM
-whitey-'s Avatar
i guess i will replace it , anything i should know first?
Old 12-28-2007 | 08:31 PM
RCKen's Avatar
My Feedback: (9)
IDE drives like a DVD are very simple to replace. Pull the old one out and put the new one back in. Hook up the power and IDE cable and you're done. The only thing you will need to check is that the jumpers on the back of the new drive are set to match the old drive.
Ken
Old 12-28-2007 | 09:21 PM
-whitey-'s Avatar
Thanks for all the help.
Old 02-23-2008 | 11:49 PM
atv_motocross#38's Avatar
Anyone speak computer here? sorry for posting something completly different on your thread, buy im on edge with my computer. heres my problem http://www.rcuniverse.com/forum/m_70...tm.htm#7126830
