91 Honda crx build or what?
RE: 91 Honda crx build or what?
Sorry quad, this is one of those dreams that teenagers have (no offense) that never seem to happen.
I would bet a lot of money this never happens, a 400 or so dollar CRX is bound to have more problems than is worth. How is the entire suspension? Tie-rods? Ball joints? electrical system? I had an 89 civic I am just listing parts that most likely need care.
So I will throw it out there, anyone wanna take me up on this bet?
ORIGINAL: Anthoop
Hmm not sure about this thread Quadzilla..!?
Anyhoo..When you say the original motor is corroded and the valves are 'bad', what exactly do you mean? The block and head is alloy so i presume your referring to the internals....has it not been ran for some time??? Oh and you say "corroded parts like the tranny is really rough", what the gears or synchro rings or selector shafts or bearings??
What engine are you thinking of 'dropping' in there? Are you converting to rear drive? I see you mention a six speed box, you know you can't just fit any old box on any old engine?
Also i hope you understand that fitting a non-standard engine into any car is a major task involving modification and fabrication of parts/electrics...it's not simple! Not forgetting all the other alterations you'll need to make if your increasing the power by well over 100%![&:]
ORIGINAL: quadzilla122
By this i meant i wont put a turbo on the stock motor the motor that i will buy will have a turbo(sorry if i confused you guys) but the motor im going to buy is going to have one. Once again im not keeping the stock motor because several signs of corrosion and the valves are extremely bad(the motor on ebay is $450 and the valves brand new by them selves are about $300+oem)thats is not including all the rest of the corroded parts like the tranny is really rough. I had to change about 3 fuses.
FL
ORIGINAL: AutoXMan
ORIGINAL: VIPER458
well thats not always true. im 19 and my 87 mustang will be running in a few weeks. but i got people helpin me. there would be no way for me to do it on my own.
ORIGINAL: AutoXMan
Sure there are unique cases, but having this CRX at 300 hp would be the equivalent of having the mustand up around 650 horsepower. And just doing it with his rich buddy, catch my drift? Also, quad doesn't have his liscense yet, so there is a big difference between you and him.
I mean I have a plan to build a drag car in the spring, but I wouldn't post about it until it was actually underway and not just a thought in my head.
#31
FL
ORIGINAL: AutoXMan
ORIGINAL: VIPER458
ORIGINAL: AutoXMan
#32
By corrodes parts i mean the sleeve is not making good compression from the.Yes the tranny is very rough. Aslo yes the car has been sitting around for about 1 year. The frame, fenders,hood, trunk,doors, etc show no sign of surface rust so im going to keep all of that(anything not related to electricals and the motor)
Is the tranny difficult to shift (maybe something simple like linkage bushes) or does it crunch when shifting....up or down...all gears or specific?
Again you do understand what's involved in transplanting a non-standard engine into a car right?
#33
ORIGINAL: Anthoop
Have you tested the compression (with a compression tester) or can you actually see that the bores are badly corroded...slight corrosion can be cleaned by honing the bore!
Again you do understand what's involved in transplanting a non-standard a car right?
AutoXman im not rich and neither is he,me and him just rather alot of other hobbies over others. As you can see i have some pretty cheap rcs and about 4 out of like 8 are running. He has saved his money for a while now and as far as my family goes ussualy a persons first car usually ranges from 3k to 10k depending on person. I think having about 3k or 4k in this car it would probably be cooler than most 20k cars and less expensive.
Anthloop, Yes i do know whats involved in putting a non OEM engine into this car.
I just wish you guys would stop putting me down in the dumps about making this car look good again. []
#34
I got the pictures from yesterday because i havent had time today because of history test and a project. The motor is out already but il post pics later.
#35
The stock compression ratio is 9.6:1 and we tested it at a shocking 6.8:1[:@]ouch!
Anthoop, Yes i do know whats involved in putting a non OEM engine into this car.
#37
Almost forgot that the car came with rims and tires that more than $300. Hankook ventus v-threads on what i think is konig or proline rims. There is no hubcap on them so im just taking wild guesses based on there design.
#38
^those rims dont have hubcaps
i read an article about a civic built by full-race that had over 800hp-> http://www.superstreetonline.com/fea...vic/index.html
good luck with this project, but im kinda thinking your gonna run into trouble when putting in your 'race motor'
#41
PA
ok I just would like to say good luck with your honda. Now this is what I'll tell you as a friend on the site, don't wast you time building that car or the money you need to make 300hp engine. I can go to a junk yard get an old Lincoln with a 460 clean it up add intake cam and carb drop it in a fairmount and beat the crap out of that honda in the 1/4 mile. That is what I did at 18. The car ran 12 seconds on some very cheap handed down slicks. I did all this for a $1000 in 1991. I would look for a fox body mustang and do a 302 up. 300 hp is very easy for a 302 with no juice,add some NOS and 400 is around the corner. the trans and rear can take the power with no problem . The honda can't trans, axle's, motor mounts, even the body can't. most guys at the races that have honda's all done have put some very mad money into them like more then what the car is worth new. Also if you can find a 1986 buick regal T-type for like $8,000 put $5000 into it and you will have a 10 second every day driver.
#42
ORIGINAL: [email protected]
#45
http://www.youtube.com/watch?v=AvWptaq1x7E
#46
He didn't underestimate them. He just said thats its easier to start off with a better platform, and its true. Its easier to reach 300HP on a V6 or V8 than a 4-banger.
#47
ON, CANADA
ORIGINAL: annie_himself
Not the stocker, the new motor that he wants to "drop-in."
ORIGINAL: hands without shadows
4 banger, look at the pics.
#48
My bad [sm=red_smile.gif]
#49
FL
Big cars arent my style i like little hatchbacks and coupes.
