F27 STRYKER - Way Past the Limits - Part 5 - Step in to the Dark Side...
#76
PA
RE: F27 STRYKER - Way Past the Limits - Part 5 - Step in to the Dark Side...
I was using the same setup as my stryker but the model itself was considerably lighter and more aerodynamic. I miss it already
Im looking into another project now. The only other maiden I have is my f-18... Still waiting on a couple of parts for that though. Maybe next weekend if it isnt to cold.
#77
ON, CANADA
It is a great looking model; that Hawk. Most realistic foamy jet I have seen to date.
My next project after powering the Stryker on 6S will be to fly the Stryker with a camera downlink to video goggles and be able to pan the camera with the rudder control on my tx. I did some range testing today on the tx/rx and it appears it will handle 1 mile easily. The video set-up I get will be similar in range. I have seen this done with slow flyers like the Easystar but never on a 70mph Stryker. Should be a blast but have to wait for Santa to bring the whole thing and by then it will be freezing up here and supremely cold at altitude so I may have to wait till spring for this.
#78
NC
somegeek,
More people are going to 6S use, Maybe you should change the title of this thread to Super Dark Side......LOL....
Gryphon
Gryphon
#79
I've just finished modding my Stryker with a 2409-12T, 25A ESC, 7x5 APC and 2200mah 15C batts and the auw came in at 20oz's which really surprised me as I was expecting around 25oz's. No maiden yet but static tests vertically showed a huge amount of lift so vertical should be good. I can't wait for a decent day when it's not 25mph winds or torrential rain. That'll be around April then[]
One question though, I can't find a 7x6APC anywhere so will a cut down 8x6 give the same results or is it not that simple?
#80
PA
ORIGINAL: Gryphon
somegeek,
Gryphon
somegeek,
Gryphon
#81
ME
yes you can cut it down and it will drop the amps but not as well a the true 7x6... the blades will be wider and thicker on the cut down 8x6 pulling a few more amps then a 7x6 would... you may be able to trip some trailing edge as well to get closer... make sure you balance it well..
#82
WA
ORIGINAL: Wastegate
Got any pics? 20oz is a nice flight weight. Think I've heard folks getting as low as 19oz? Think my flight weight is around 25oz after my repairs. [:@] My next fuse will be lighter for sure.
#83
PA
ORIGINAL: Mach62
#84
ORIGINAL: Wastegate
if its the out runner you want to use a APCE 7x5
they dont list a 7x6 APCE but you can get a sports 7x6 from sussex model centre
Ray
#85
I'll get some pics before I crash it! The body is a B variant with no additional strengthening except for Extreme packing tape and has never had a repair. I painted it with JapLac paint which seems to stick as well as anything else I've tried but I'm still surprised at 20oz's! Rx is a micro unit and servos are HS81's. The motor is mounted to an L-shaped bracket screwed to the base of the original mount. Transmitter is a Futaba 6EXA and is superb value for money.
Ray, it's the bell variant that costs Β£10. I'll stick with the 7x5 then. Thanks.
#86
PA
ORIGINAL: Wastegate
#87
PA
ORIGINAL: Wastegate
#88
PA
Hey, check out this link that charts various prop sizes on the 12T motor. All that data is already entered for you and the chart will pop right up. Very cool link to check out various motors/props as well...
http://www.peakeff.com/GraphKIR.aspx...er+Pro+2409-12
Opinions on what you see in this chart for the 12T?
#89
It's the same ESC as mentioned in post 2576 of part 4 so should be good for 30amps especially as it is suspended in the back to allow maximum cooling across both sides of it. Btw the 20oz's is with a little lead on the rear as well. I think I'm going to get some serious wing flutter though.
What amount of elevon throw should I be using? I was thinking about 5mm up and 5mm down.
#90
ORIGINAL: critterhunter
i tend to use 10 volts max for my calculations unless i am planning to use 3S2P
10.5 volts is only sustained at a 70% draw on 20C ( depending on Manufacturer of packs)
nice tool/site to check prop sizes [8D],
Ray
#91
PA
ORIGINAL: Wastegate
#92
PA
ORIGINAL: DepronJet
Ray
Ray
Kind'a neat to see the MPH estimates for each prop size as well on there. I see there are a few that are "guessed" to be MUCH faster than the 8x6, by about 20 to 30 mph. Then again, as has been said, what prop should be better on paper isn't always true in the air.
#93
WA
Critter,
I linked some charts from that site in Part 4. They are a nice reference to see what different props can do for you. Kinda what convinced me that APC-E (Speed 400) props are the way to go.
Good stuff!
somegeek
Good stuff!
somegeek
#94
PA
Here's a few pictures of the new camera platform build after scrapping the smaller one. 4" wide by 36" long fuse. I think the fuse height is 5 or 6 inches or so. 7 inch wide by 48" long clark-y wing containing a carbon tube for strength and has been tempered with heat and extreme strapping tape to curve it for maximum stability. Controls are rudder/elevator.
Right now with servos, ESC, motor and prop installed the plane weight is only 17 ounces. That's without the RX, battery, or some tape in strategic areas. Still, with those added and the pocket camcorder (very light) I'm expecting it to be well under 30 ounces. If that holds true she should land at a walking speed.
It's still a work in progress so it isn't too pretty yet. Have to hide the electronics in the fuse and if Gorilla glue isn't sandable then she never will get to be a ten. First time I've worked with the stuff. But hey, either way, I wanted a good aerial platform so looks come second.
Some of the "fine" features to notice are the motor mount made from a fish filter tube and some kind of fish filter 90 degree adaptor at the top. It's very light yet strong. Hope it doesn't look so "fishy" once it's painted. I put a pack of smokes on top of the wing for scale. Still have to figure out how to mount the wing to be removable for transport. Would like to avoid dowl rods/rubberbands and use nylon bolts but how to keep the wing from pulling through or the bolts pulling out of the body? Ideas?
Instead of the sinister dark side laugh you can expect to gawk and just say..."What the heck is that thing?!" On it's off days when it isn't hauling the camcorder or a wireless cam into the air it will be hauling garbage to the dump...
#96
NC
jhalbur,
http://www.dynamoelectrics.com/detail.aspx?ID=709 with CC25 and free prop adapter
http://www.dynamoelectrics.com/detail.aspx?ID=714 with CC35 and free prop adapter
It would be smart to upgrade to CC45 from CC35 for an extra $17.
If you will ever run more than 4S or even higher Amps then consider asking for the CC60 or CC80 for the combo over the phone.
His name is Randy. Nice guy. (815) 228-7091
Don't forget to ask for bullet connectors and maybe Deans Ultra plugs as well. Not sure what connectors you are using, get whatever works for you along with props.
Have fun
Gryphon
Have fun
Gryphon
#97
PA
I got impatient waiting for a store to open that carried micro switches and found myself bored earlier today.... Well I fired my rockets with a 12v battery... guess I have to go buy more =D
#98
hi wastegate
can you give me the name of the paint and where you bought it from ive tried a few methods but have allways returned back to acrylic paint a few pics of your stryker would be great
regards Maxamus
regards Maxamus
#99
Maxamus, the paint is a self levelling brush on paint called JapLac (by International paints I think). You can get it from B&Q for a few pounds and it seems to stick quite well. I flexed the wings a bit and it didn't crack so I'll have to see how it performs after a few flights. Although it's a brush on paint, the finish is very good with no brush marks at all and a few coats would leave the body perfectly smooth.
[link=http://www.international-paints.co.uk/details.php?productid=110&surfaceid=24]Paint[/link]
#100
ME
hey ray, I emailed himodel about that duff motor, just got a reply and they said it must be a esc compatability problem..LOL .. told them I even used the esc I bought from them, is that compatable? he said I need to have the right timing setting for an outrunner.. I used the high timing setting on the himodel esc. Then of coarse tried both settings and different esc' that I have on hand to no avail.. the motor is defective.. I asked if they were going to send me a new one.. no reply yet..I really hope they come thru cuz I like their products and all has been good until this one showed up.[&o]
have you had any troubles with them?
