Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
Build an Ashley MM
Old 01-29-2016, 06:46 PM
  #51
sahartman21
Default Build an Ashley MM
The tray was cut to fit the servos and holes were drilled for the servo screws.
The tray was test fit to verify the servos don't hit the fuselage and there was the desired clearance for the aileron torque rods.
ID:	2144203   Click image for larger version
ID:	2144204   Click image for larger version
ID:	2144205   Click image for larger version
ID:	2144206   Click image for larger version
ID:	2144207   Click image for larger version
Old 01-29-2016, 06:48 PM
  #52
sahartman21
Shoe Goo was used to attach the tray.
ID:	2144209   Click image for larger version
ID:	2144210   Click image for larger version
Old 01-30-2016, 03:11 PM
  #53
sahartman21
The servo tray was installed for the other model today.
ID:	2144335   Click image for larger version
Old 02-06-2016, 03:19 PM
  #54
sahartman21
Jordon Peace stopped by this morning and we sheeted a couple wings.
I began by weighing each sheet of balsa and sorting from them from lightest to heaviest.
I prefer to use heaver balsa sheets on the top of the wing. The bottom of the wing will have the lighter wood.
ID:	2145629   Click image for larger version
Old 02-06-2016, 03:29 PM
  #55
sahartman21
A template was made for the wing sheeting by placing large "T" pins around the wing shucks. Place the pins about 1/4" wider (both front and back) than the shucks. They should also be about 1/4" longer than the shucks.
Sheeting is positioned on the top and bottom of the template. A third piece is added and trimmed to fit the center section. The cut off from the third piece is used to fill the remaining space. These are cut and taped together to make a skin.
The opposite side is made similarly but the tape is applied to the other side of the skin.
ID:	2145631   Click image for larger version
ID:	2145632   Click image for larger version
ID:	2145633   Click image for larger version
ID:	2145634   Click image for larger version
ID:	2145635   Click image for larger version
ID:	2145636   Click image for larger version
ID:	2145637   Click image for larger version
Old 02-06-2016, 03:37 PM
  #56
sahartman21
Some landing gear supports/wing spars were made from 1/8" thick light ply.
These were cut about 12 1/2" by 1 3/4" and slid into the wing. The spars were trimmed to fit.
ID:	2145643   Click image for larger version
ID:	2145644   Click image for larger version
ID:	2145645   Click image for larger version
ID:	2145646   Click image for larger version
ID:	2145647   Click image for larger version
ID:	2145648   Click image for larger version
ID:	2145649   Click image for larger version
Old 02-06-2016, 03:45 PM
  #57
sahartman21
The wing sheeting was taped together to make a balsa "book" that folds at the trailing edge.
The carbon fiber strips were planned out that the landing gear does not interfere with the strips.
ID:	2145651   Click image for larger version
ID:	2145652   Click image for larger version
ID:	2145653   Click image for larger version
Old 02-06-2016, 03:49 PM
  #58
sahartman21
Slots were cut for carbon fiber strips that will later be glued in the top of the wing.
ID:	2145655   Click image for larger version
ID:	2145656   Click image for larger version
Old 02-06-2016, 03:58 PM
  #59
sahartman21
I test run the vacuum pump prior to mixing the finishing epoxy. Take the time to confirm that it works before going further.
Old 02-06-2016, 04:02 PM
  #60
sahartman21
Some finishing epoxy is mixed and applied to the spars and vertical carbon shears. They are slid in place.
ID:	2145661   Click image for larger version
ID:	2145662   Click image for larger version
ID:	2145663   Click image for larger version
ID:	2145664   Click image for larger version
Old 02-06-2016, 04:08 PM
  #61
sahartman21
A piece of 1.6 ounce fiberglass cloth was laid over the balsa sheeting.
Approximately 1 ounce of finishing epoxy was mixed for each side of the wing. A cap of 91% alcohol is added to each batch of finishing epoxy. This thins it out and makes the epoxy easier to spread.
A plastic squeegee was used to spread out the finishing epoxy.
ID:	2145667   Click image for larger version
ID:	2145668   Click image for larger version
ID:	2145669   Click image for larger version
Old 02-06-2016, 04:13 PM
  #62
sahartman21
The wing core was installed between the wing sheeting.
I test fit and pin the sheeting in place on the core.
The cores are fit between the shucks and are held together with masking tape.
ID:	2145671   Click image for larger version
ID:	2145672   Click image for larger version
ID:	2145673   Click image for larger version
ID:	2145674   Click image for larger version
Old 02-06-2016, 04:22 PM
  #63
sahartman21
The wing is placed on a 4 mil thick tarp that is used to make a vacuum bag.
A vacuum tube and piece of rope are taped in place on the bag.
A long piece of paper towel is laid on top of the wing.
A bead of latex caulking is used to make the seal for the bag. The bag is folded over to join surfaces and the caulking makes the seal.
The pump is turned on and empties the air from the bag.
It was relatively cold in my garage so an electric blanket was placed over the surfaces to insure the epoxy was warm enough to dry.
ID:	2145676   Click image for larger version
ID:	2145677   Click image for larger version
ID:	2145678   Click image for larger version
Old 02-07-2016, 12:01 PM
  #64
sahartman21
The wings were removed from the vacuum bag the next morning.
Old 02-07-2016, 12:11 PM
  #65
sahartman21
A razor saw was used to trim the trailing edge flush with the shucks.
The leading edge was trimmed until the edge was flush with the cores.
A sanding block was used to true up the edges.
ID:	2145848   Click image for larger version
ID:	2145849   Click image for larger version
ID:	2145850   Click image for larger version
ID:	2145851   Click image for larger version
ID:	2145852   Click image for larger version
Old 02-07-2016, 12:18 PM
  #66
sahartman21
The leading edge (1/4" thick balsa) was attached with Gorilla Glue.
The surface was dampened with a moist paper towel initially. A thin bead of glue was applied and the leading edge was taped in place.
Gorilla Glue foams to fill gaps. There was a little too much foam so it was removed before it dried.
ID:	2145856   Click image for larger version
ID:	2145857   Click image for larger version
ID:	2145858   Click image for larger version
ID:	2145859   Click image for larger version
ID:	2145860   Click image for larger version
Old 02-07-2016, 05:54 PM
  #67
sahartman21
The leading edge must be trimmed back to fit in the wing saddle.
ID:	2145926   Click image for larger version
Old 02-07-2016, 05:57 PM
  #68
sahartman21
The landing gear blocks are cut from 3/16" plywood.
ID:	2145928   Click image for larger version
Old 02-07-2016, 06:01 PM
  #69
sahartman21
I've positioned the landing gear so that the axel is about 5/8" forward of the center of gravity.
The bottom sheeting was cut to fit the landing gear blocks.
ID:	2145930   Click image for larger version
ID:	2145931   Click image for larger version
ID:	2145932   Click image for larger version
Old 02-07-2016, 08:26 PM
  #70
Kevin Matney
Kevin Matney's Avatar
Looks like you have done a time or 2!! Great job
Old 02-08-2016, 03:07 PM
  #71
sahartman21
A Dremel was used to grind out foam and wood for the installation of the landing gear blocks.
Finishing epoxy and micro balloons were mixed and dabbed in place.
The blocks were added and the gear was taped flush.
They were set out of the way to dry.
ID:	2146033   Click image for larger version
ID:	2146034   Click image for larger version
ID:	2146035   Click image for larger version
ID:	2146036   Click image for larger version
ID:	2146037   Click image for larger version
ID:	2146038   Click image for larger version
ID:	2146039   Click image for larger version
Old 02-08-2016, 03:09 PM
  #72
sahartman21
The belly pan requires some trimming to get to the proper size.
ID:	2146049   Click image for larger version
ID:	2146051   Click image for larger version
Old 02-08-2016, 03:12 PM
  #73
sahartman21
Some 1/16" holes were drilled to verify the location of the wing hold down blocks.
ID:	2146059   Click image for larger version
ID:	2146060   Click image for larger version
ID:	2146061   Click image for larger version
Old 02-08-2016, 03:16 PM
  #74
sahartman21
Some wing mount blocks were cut from 3/16" thick plywood.
These were cut approximately 7/8" square and were glued in place.
ID:	2146064   Click image for larger version
ID:	2146065   Click image for larger version
ID:	2146066   Click image for larger version
ID:	2146067   Click image for larger version
Old 02-09-2016, 06:57 PM
  #75
sahartman21
A hole saw was used to remove material for dowel inserts.
A piece of tape covers the hole to keep the glue in.
The dowel is marked to length and trimmed with a Jigsaw.
Some micro balloons and finishing epoxy were mixed.
The mix was added into the holes and the dowels were added.
Parts were set out of the way to dry.
ID:	2146343   Click image for larger version
ID:	2146344   Click image for larger version
ID:	2146345   Click image for larger version
ID:	2146346   Click image for larger version
ID:	2146347   Click image for larger version
ID:	2146348   Click image for larger version
ID:	2146349   Click image for larger version
ID:	2146351   Click image for larger version
ID:	2146352   Click image for larger version
ID:	2146353   Click image for larger version
