Servo flutter
My Feedback: (7)
"Flutter" is what happens to a control surface when a combination of bad things happen. What you are probably referring to is servo chatter or wander. The servo doesn't cause flutter, aerodynamic forces do.
TX
I am guessing this is without the engine running?
I had an issue with an elevator, when flying the tail would jump around when in straight level flight.
So I tried to get the surfaces to wiggle on the ground and figured out with full throttle the elevator would flutter.
It turned out to be prop wash flexing the surface and not the servo issue. The servo wouldn't move at all.
I havent fixed it yet but at least it isn't a servo issue.
I guess in a way I am asking have you checked everything? Including swapping the servo to see if it was the servo?
Good Luck with your trouble shooting
doesn't a dirty pot also cause this? I have one that has the jitters at the low throttle setting and was going to open it up and clean and see if that helps. I'm not sure how it cold get dirty being sealed and all but thats what I'm hoping.
