Reload this Page >
What Is Your Best Two building Rules?
Old 02-08-2014, 07:47 AM
  #51
W7APD Alan
Starting to wonder if anyone here ever built anything other than models?
1. Measure twice.
2. Cut once.
Taken from personal experience, as I survey my pile of lumber scraps, all of which after being cut twice, were still too short!
Old 02-08-2014, 08:59 AM
  #52
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Originally Posted by sensei
Well Jim that is a matter of opinion and certainly dependent on who is performing the build.
Bob
I too have used Gorilla glut and had acceptable results but I can also do a better job with epoxy. I always vacuum bag my wings and Gorilla glue does not foam nearly as much under vacuum so no real advantage there. If the epoxy method is coming out heavier too much epoxy is being used.
Old 02-08-2014, 12:23 PM
  #53
HighPlains
I've seen an excessively large number of foam wing pylon models after they pounded the ground. Mostly the wing skins are not bonded very well to the foam cores judging by how much foam remained attached to the skins. 3M 465 tape held better, but I have not seen enough destroyed wings yet with gorilla glue to assess their strength after the fact.
Old 02-08-2014, 02:14 PM
  #54
450hpstearman
Question asked by other modelers, How do I get such a quality finish? Reply: it starts with the first piece
Old 02-08-2014, 02:57 PM
  #55
hookedonrc
hookedonrc's Avatar
Nice read, there are a lot here that I adhere to, but my top 2 are:
1. Think long and hard about any modification you make. The intent is to make it better not worse.
2. Do NOT glue yourself to your project! (No need to. Ask how I know this. )
i used to to work at the airport in operations and a pilot once told me: "We measure with a micrometer and cut wit a chainsaw."
Not sure what he was referring to.
Old 02-08-2014, 06:13 PM
  #56
rt3232
Rob2160
Loctite every nut and bolt goes for all birds, and then get the nail polish your significant other (hooker red)and cant stand any longer put a little strip acrose the joint, it will tell you in a short time if and when it comes loose.
+1 on all th above rules
Cheers Bob T
Old 02-10-2014, 10:09 AM
  #57
beepee
An addendum to the cut and measure rule: if you have cut on it 3 times and it is still too short, it is time to replace the piece.
Bedford
Old 02-10-2014, 11:50 AM
  #58
flyoz
My Feedback: (7)
flyoz's Avatar
Enjoy the research and prep - its 90% of the magic. Glue a section, check and start another area or walk away (let it dry properly before mucking about with it).
Old 02-14-2014, 08:49 AM
  #59
carlgrover
Rule 1: Do the best you can but don't obsess on making everything perfect.
Rule 2: When things aren't going well and you are starting to get frustrated, walk away and come back to it tomorrow.
Carl
Old 04-12-2014, 02:43 AM
  #60
VincentJ
VincentJ's Avatar
Each time I enter my basement workshop I always put on some great music to listen to while building.
Don't be afraid to ask for help, learn from others...
Try to buy the best tools and equipment that you can afford, in the long run you'll save time and money.
Keep your pencils sharp!
More than two I know, it's part of today's "new math".....LOL
Old 04-12-2014, 06:33 AM
  #61
cocobear
1) Get off the internet and build
2) Stop thinking so much and build.
Dave
Old 04-12-2014, 03:32 PM
  #62
Luft-Gangster
Originally Posted by YAT-28E
#1-Make a pot of coffee
#2-Dont glue you fingers together
Ditto
Old 04-12-2014, 03:51 PM
  #63
TLH101
My Feedback: (90)
TLH101's Avatar
It's my hobby, and I don't need any rules on my hobby!
Too damn many rules in real life!
So, I don't worry about it.
Old 04-13-2014, 11:48 AM
  #64
sensei
sensei's Avatar
There is another rule I have heard of... Don't start vast projects with half vast ideas.
Bob
Old 04-13-2014, 11:58 AM
  #65
TomCrump
TomCrump's Avatar
Bob
LOL
I've seen a lot of half vast ideas at the flying field.
Old 04-13-2014, 03:15 PM
  #66
Jim Branaum
Originally Posted by TomCrump
LOL
Yes.. before AND after!
Old 04-13-2014, 03:25 PM
  #67
sensei
sensei's Avatar
Bob
Old 04-16-2014, 08:24 AM
  #68
Bax
My rules:
#1: Start the project
#2: Finish the project
Unfortunately, #2 has been broken a few times in the past.
Old 04-16-2014, 09:18 AM
  #69
Bob Yeager
Bob Yeager's Avatar
1. Take your time framing, engineering, and sanding.
2. When you are satisfied with the above, realize that you are 1/3 of the way to completion.
Old 04-17-2014, 04:54 PM
  #70
camss69
My Feedback: (46)
camss69's Avatar
My number one rule is don't build if I'm not in the mood to build. I have to be in the building mood or it seems like I'm not satisfied with anything I do. I'm streaky I'll feel like building for a week or two and then not want to touch it for two weeks.
Old 04-20-2014, 08:16 PM
  #71
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
There is some good stuff in this thread. For me, not necessarily rules but guidelines:
Finish a project before starting a new one.
Have a daily goal and keep it tangible.
Old 04-21-2014, 05:09 PM
  #72
foodstick
foodstick's Avatar
Here are a couple that may not have been noted yet.. Back when I started building there was a rule.
The finished plane should way about the same as the kit did when you bought it.. BOX AND ALL ! ..........Sort of a fun one there.
The second one was told to me by a guy that moved here from the East coast.... and then moved to another city to follow his job..
"Life is to short to fly UGLY airplanes !"
Old 04-21-2014, 06:43 PM
  #73
52larry52
"Life is too short to fly UGLY airplanes!", that is a great motto. I really like that one. I believe I'll steal, err I mean "borrow" that line. Thanks foodstick.
Old 04-21-2014, 06:49 PM
  #74
foodstick
foodstick's Avatar
I don't think my friend would mind it at all 52Larry52 !
hahahahah
