question about printing double size plans.
i love building and fly balsa wood planes. does anyone know if it is possible to take the plans of a plane and have them doubled in size and have them printed out. if so where could this be done ? office max, staples ? thank you. im thinking of building a double or triple size sig hummer. thanks.
Moderator
Any of the office stores can do that for you. Be aware though that stock sizes don't necessarily scale up the same. If the original model called for 1/4 inch spar strips for example, 1/2 inch strips may not be appropriate for the bigger plane.
The advantage to using Dennis,"HemiKiller", is he can scan the plans and re-arrange
the components to fit on either 36" wide or 42 " wide paper. Whereas going to a print shop
they will just scan then and enlarge to the size paper they have and you will not get a very
good image and also when they turn the plan to enlarge the side that didn't print, there could
be a very slight difference in scaling. If you want a first class job, at a reasonable cost I highly
recommend Dennis, he is not only an expert at printing plans, he is also a model builder.
