Flat worktops?
My Feedback: (17)
I am a little frustrated and I was hopeing that somebody can point me in the right direction.
What are you guys using for work tops to build your kits on? I just spent 400.00 on a new work bench. All the specs looked great. the board is 1 5/8" thick. Unfortunately, When I ran a string across it, there is a 3/16" drop in the middle. I tried to shim it up but at 1 5/8 thick it isn't going to well. I called the nearest billiard shop to see if they have any slate lying around but they don't have anything large enough to build a giant scale plane on. Any suggestions?
VA
Have you tried your local glass supplier? I thick slab of glass properly supported will be nice and flat. Also, consider a solid core door. You can get a good "second" from a buildingsupply company. I paid $20 for mine and it is as flat as can be.
Victor
Victor
Unfortunately, even if you layed a 1/2" thick slab of glass on a table with a 3/16 dip in it, the glass will bend.
If I were you, I'd shove a 2x4 "Leg" under that table right in the middle, then put shims between the 2x4 and the table as needed (IF needed)
My Feedback: (17)
MinnFlyer. I think that the 2x4 will be my first approach. I dont know what this top is made of but man is it strong. I can stand on it and the top barely moves. I will probably have to raise the 2x4 a little at a time to get the top to "bow" back into place.
VA
I am sorry if I was not clear. I did not mean to imply that you should put glass over the warped table, but use glass or a solid core door on a different support. If the top is warped as much sa you say, not much you can do to straighten out.
My Feedback: (17)
Yah know. For the price of a hollow core door, I can just buy one, lay it over my work bench and use it. The outer perimiter of the bench is perfectly level so I could just clamp the door to the edges. I do have a piece of 1/8" tempered glass over my workbench. Obviously it curves with the bench top. Boy it sure does make cutting monokote easy.
3/16 was a guestimate.
Man, I just build mine out of 2X4s, made the frame, and then put 3/4 inch Partical board on it. Make the frame straight, the bench will be straight. Then I tape posterboard over it so when I spill glue and stuff, I can just replace the sheets of posterboard and have a new top! Works great. If you like to use pins, then put cellotex over the partical board and tape the posterboard over the top of that.
Makes a great workbench, and cheap too! Specially when you can get the wood from LP factory second store.
My Feedback: (17)
Thanks Guys. I already invested alot of money into my new work bench. Sooo, I will try to raise the center up with a 2x4 as the top is not currently supported in the center. If I can't get it perfect then I will just throw a hollow core on top to build the wings.
IL
