Hi-Tech Servos
Old 04-10-2006 | 10:36 AM
Default Hi-Tech Servos
I recently bought 4x5945MG Hi-tech servos. All they had in stock were JR type connectors, I have Futaba.
As I need to lenghten them do I join black to black, red to red and yellow to white to convert them to Futaba leads?
It looks fairly obvious I know but I don't want to cook my new servos.
Cheers and happy modeling,
Airtourer
Old 04-10-2006 | 02:41 PM
Bud Faulkner's Avatar
Default RE: Hi-Tech Servos
I think you'll cook your servo if you do that. I use futaba and i'm not positive but I think jr has orange for signal, red for + and brown for -
I think they make a jr to futaba connector...check here.
http://www.maxxprod.com/mpi/mpi-3.html
Bud
Old 04-10-2006 | 03:39 PM
staggerwing's Avatar
Airtourer you have it right. On Hitech the match is black to black, red to red and yellow to white for Futaba.
Old 04-12-2006 | 12:31 PM
My Feedback: (78)
Airtourer: Hi, name's Ken (Starfighter).
You are correct , the Black is obvious, so's the Red wire. The ONLY one left is the Yellow, so it HAS to go to the White wire.
You WILL NOT harm the servos in any way (unless you reverse the red/black wires). The Yellow is the Signal wire by the way.
Old 04-12-2006 | 01:52 PM
TLH101's Avatar
My Feedback: (90)
You dont really need to change the plugs, they will plug into a Futaba receiver, ot female plug. Wires are in the correct locations.
