ARTF Engine Mount changing
Has anyone got any ideas about changing a pre-fitted engine mount on an ARTF? I've just got a Seagull PC-9 and want to fit my Saito. It doesn't go in the supplied mount and the new mount for the engine doesn't line up with the pre-drilled holes/fittings. But they're close enough to make just drilling again not an option. The best I can come up with is wiggling some more ply up into the fuselage behind the existing firewall and epoxying it in, then filling in the existing holes with more epoxy before re-drilling. And I'll have to fill in the hole for the fuel tank bung as that's way to high for where the carb will be on the 4-stroke. Any ideas for making this task easier will be much appreciated, surely I can't be the first one with this prob.
RCU Forum Manager/Admin
My Feedback: (9)
There's a simpler solution. Get a wooden dowel rod that will fit TIGHTLY into the existing holes and glue it in place in the holes. After the glue is dry cut off the rod flush with the firewall, and then redrill your new holes for your new mount.
Ken
Ken
Thanks, that sounds like a better idea to plug the old holes. I may still stick a bit of liteply on the back as well esp. re. the resiting of the fuel tank bung cutout. Thanks for your input
