 compensating weight >
compensating weight
compensating weight
Old 02-28-2007 | 07:39 PM
Default compensating weight
I need to balance a nose heavy plane, would it be possible to use a heavier wood for the vertical or horizontal stab(basswood or ply)?
what effect could this have on flight performance?
I am looking for options other than adding lead and I have already mounted the servos near the rear as one.
Old 02-28-2007 | 08:09 PM
Insanemoondoggie's Avatar
Default RE: compensating weight
Not sure why type of plane you have, but moving the battery aft if you can is a good way to get your CG without adding more weight.
Old 02-28-2007 | 08:15 PM
meaden's Avatar
Move the battery back...back to the tail if you need to.
I don't think the heavier wood would do much...depends on how nose heavy it is.
Flight effects of adding weight...heavier plane = higher wing loading = higher stall speed, faster landings, less power for the fun stuff...
Old 02-28-2007 | 08:17 PM
you can add a battery comparment with a little hatch on the bottom of the model determine where you need to put the battery and put a hatch there.. this will add only a few grams in actuall wight but will balance the model.
Old 02-28-2007 | 09:07 PM
I didn't think about a possible battery compartment/hatch near the rear. its a 1/12 scale so it gets a little tight for space the farther back we go.
Old 02-28-2007 | 09:30 PM
As suggested move the battery back. Additionally move the fuel tank back to the approximate balance point.
Ed S
Old 03-01-2007 | 07:41 PM
Rcpilot's Avatar
My Feedback: (78)
ORIGINAL: formerlyknownasAWB
[sm=lol.gif][sm=lol.gif][sm=lol.gif][sm=lol.gif][sm=lol.gif]
1/12th scale WHAT?
1/12th scale B-17 bomber? Should be plenty of room in the tail for a battery.
Or are we talking about a 1/12th scale Pitts Bipe?
1/12th scale 747?
Or 1/12th scale Cap 232?
Old 03-01-2007 | 07:58 PM
ok you got me.
I was exagerating a little about it being tight for space. The truth is I can't think clearly when I'm hopped up glue fumes.[sm=tired.gif]
Its a HOB ME-109.
Old 03-02-2007 | 06:53 AM
perhaps ypu should open a window
Old 03-02-2007 | 01:27 PM
Hi!
Never ever add weight!!! That's a death sin!
Move what ever it takes to reach a good balance, servos , batteries receiver, tank you name it ...but never add anything!
Can't you Dremel away on the engine mount. Plastic engine mounts often have long engine bearers that stick out, cut them off. Move the engine back...just remove the firewall and glue it in further back. just some centimetres might be enough.
Old 03-02-2007 | 03:42 PM
I don't know how you are finishing your plane , but remember about 80% of your paint/covering will be behind the CG.
Old 03-02-2007 | 06:17 PM
I agree that you should always try to shift weight around in a plane for balance and add dead weight LAST. Move the battery back, you can glass the stab. The point is you attempt to add dead weight last. I have seen a biplane with a short nose that took a ton of lead to balance. By the time (bad design?) you have to do this, you almost need a larger engine to pull the lead. []
Old 03-03-2007 | 10:12 AM
I can see the light, I have been saved. Amen
ty
Old 03-03-2007 | 11:28 AM
broke_n_bummin's Avatar
If that doesn't work, I guess you could wedge a balloon filled with helium between the motor and the radio.
