stupid s3 question
stupid s3 question
i think this may be a stupid question so here it is how do you other ttr guys position the air cleaner so it doesnt rub on the brake/throttle linkage!? i just got done installing the linkages and so forth put the air cleaner on then the body and man that thing is smashed down pretty hard im not even gonna fire this pig up till i figure something out does somebody make a different boot oe what?[:@]
RE: stupid s3 question
This is something I have been pondering myself. I use the Thunder Tiger air filter, and it does rub the linkage a bit. I have not, however, noticed any problem with this. And it is NOT a stupid question! The foam itself is pretty plyable and doesn't seem to interfere with the throttle or brake. All I am worried about is ripping the filter. So far, that hasn't happened, knock on wood. Look Familiar?
NJ
I have some rub but it isn't much. The throttle link just touches the foam a little bit... No problems with it yet. I suppose there are smaller cleaners that can be put on but I'd keep it this way and just keep on eye on the filter.. Take off the body..... push down the cleaner to simulate the body being on, rotate the elbow if needed to get maximum clearance and move the servo arm by hand to make sure theres no binding...should be good to go.
VA
You can get an air filter hose like the one that comes on they hyper 7 buggies. I don't use it myself because I'm not having any trouble on my kyosho but heres a pic of it. It wraps around the side of the motor over to sit ontop of the reciver box. I don't know where you can get one because it came on my H7 which is now sold.
i have a proline body for the mugen mbx and the roof line is not as low as the s3 stock body with the proline one im golden no smashed filter but i like the low slung look of the s3 body. buuuut the proline body has a sick ass wicked paint sceme done by a pro not my 5min. spray can job. i just dont whant my 1000.00 ttr to go bye bye befor i get it to the track.
thanks stampy ill search the ofna,gs,racers edge sites mabey ill find something like that it looks like a fix to my prob. the only thing is does it grab air good?
VA
I just put it on my buggy and I kinda like it actually . As far as grabbing air it does put the filter in a tucked away place but it always worked fine on my hyper. Edit: I am also using the motor saver air filter (don't even know the brand name just liked it and put it on) Its surrounded by a screen and the foam is all compressed in there so it really gets a good seal around the side of the filter so dirt doesn't sneak by there. Its still dirty from raceday (i raced without the prefilter you see with it on my buggy)
NJ
Thats a nice set-up. I'm going to look for that too. However, I'm going to provide a fresh flow of cool outside air directed right at the filter by means of a cowl induction type vent or a small hood scoop type thing. I also use the Motor-saver filter elemants. Where can I find the steel core filter housing so the foam don't compress and restrict the flow?
VA
Mine just came out of the package this way with the dust boot too and I just got it from the lhs I work at. Anything I buy is from there. I was thinking about cutting out a scoop in the side of the window too to get some air but thats gunna let a lot of dirt get in there too.
Several posts on this forum have steered me clear of the motor saver air filter. People here have nothing but bad things to say about it. How do you like it Stampy?
NJ
thats why i was thinking of a rearward facing cowl induction style vent/scoop on the rear part of the roof. its got to be better than nothing.
if any of you guys find that air cleaner tube like little stampy has post back what web site you found it on. i have a snickers bar for a reward!!! ya better hurry cause i might eat it!!!
FL
VA
ORIGINAL: lstRacerX
Yeah having an actual cowl is better I was thinking about making a scoop but that would scoop dirt from the front tires straight into your filter too .
The link peakman posted is the same tube that comes on the H7
PEAKMAN WINS REWARD oh crap uhhhh my dog ate some home made pot brownies earlier and he got the munchies and ate the snickers bar!!! now hes passed out on the floor with a pinky sticking out between his legs!!!!! sorry dude but thankf 4 the link!!!!!
