Which Hyper 7
#76
FL
Could it be the glow plug?I am using the one that came with it.It says.Glow Plug Nitro .12 or Ofna/Picco .12.At the top it says 1/10 car.But in the catalog i got it says that its a .12 or .21-.28 engine too.HOT Glow plug.Could i just take it back and exchage it for a new Buggy?
#80
LA
use the idle trim on you transmitter to lower the idle. that should be the easiest way. the worst thing you can ever do is go turning screws on your engine if you don't know what you are doing.
#81
AZ
ORIGINAL: EtnieSk8r3000
Can someone tell me the right way to set the needles.And how to make it have lower idle its idling fast.
Lean (tighten screw clockwise):
- More air
- less fuel
- hotter
- more powerful (to a point)
- shorter engine life
Richen (loosen screw counter clockwise):
- More fuel
- less air
- cooler
- less powerful (to a point)
- longer engine life
Idle:
Tighten = increase in RPM
Loosen = decrease in RPM
And to keep your engine from blowing up, get a temperature gauge until you get used to tuning by sound and smoke ($20.00 for a temp gauge is cheaper than $120 or more for an engine).
http://www.rcuniverse.com/forum/fb.asp?m=3455189
#83
AZ
anyone have any tip for me?I am going to try to get it going at my Sister's B.F. house tommorrow.
#88
Banned
Americanesse : Ribbin, Intina,
ENGLISH : Ribbon, Antenna.
Where it goes is described before. It is also to display/WARN to to ohers that you aint got a clue what your doing.
