Official Hyper 8 Thread
#826
RE: Official Hyper 8 Thread
do you actually need to buy a special throttle retuirn spring to add to linkages or could i just make one my self with an exhaust spring or somthing similar. and good luck 46u let us no how u get on.
#827
GA
Matter of fact I had the same problem with my Savage not idling well with out the return spring. I would think you could use any spring that will not over power the servo. Coarse I run strong servos on both my Savage and Hyper 8 even on the brake and throttle servo sure makes the brakes work very well.
#828
adz06, it sounds like you need to adjust the idle stop screw on the carb so it will not close more than 1 mm. For a throttle return spring look in the Sportsworks section of the hobby shop and you will find a pack of two springs - cheap. Another solution is to use a small rubber band around the ball on the slide and the air inlet.
Ed M.
Ed M.
#829
i have tried screwing it in and out and it didnt seem to make much difference at all i think i will try witht he linkages again then try the idle screw on the carb.
ORIGINAL: bentgear
Ed M.
Ed M.
#830
I NEED A HELP FROM YOU GUYS. I JUST GOT MY HYPER 8 RTR AND I JUST WANT TO KNOW HOW TO ADJUST THE REAR TOE ON THIS THING. PLEASE REPLY WITH A LITTLE DRAWING OR INSTRUCTION. THANKS.
#831
VA
ORIGINAL: mikeae86
For the rear toe, you have to use the plastic inserts. The ones that go into the "rear suspension holder" (front) is for anti squat. The inserts that go into "lower arm holder" (connected to rear diff case) is for your toe..... It should have came with black inserts that range from 1.5 to 3 degrees. I have the Pro version and its page 10 step 26 in my manual......
If ya got more questions just ask..... Remember to take your time and be patient!!!!!
#833
here is a link to the hyper 8 manual http://www.modellismobucarelli.it/po...anuaHyper8.pdf
ORIGINAL: mikeae86
thanks firefighter7, would you please send me the manual for this hyper 8. thanks again.
#834
ORIGINAL: mikeae86
#835
thats what i was wondering lol. i got my self new work bench today was a handling though as i had to build it with no instructions and they give you spanners which didnt fit the bolts supplied lol wasnt to hard to put together worth it.
#836
Hi, just wondering how would i go about tightening my hyper 8 pro kit brakes?? They just need tightening up slightly there a litlle too slack for me thx.
#837
VA
All you have to do is loosen up the set screw on the end of the break linkage (round silver piece) and move it in a little bit. Or if you have a Spektrum type transmiter you can make the adjustment from the radio.....
#838
Yea thats what i thought i should do but just wanted to check, ok thats for that i shall do that now, the end of my throttle linkage hits the side of the body how can i stop that too.
THX
THX
#839
ORIGINAL: JamieKerr
THX
THX
#840
Ok thanks, another quick question the brake linkage slighlt hits the fuel tank??? there dosent look like there is much i can do about it though??
Thx
JK
Thx
JK
#841
ive never had that problem but i think slide out the we bit that the brake pulls bk on (its hard to describe) the bit that when u pull it it tightens the pads against the disc. u can slide it in and out if u loosen the set screw at top.its kinda hard to explain ill see if i can get a diagram to show u.
ORIGINAL: JamieKerr
Thx
JK
Thx
JK
#842
VA
ORIGINAL: adz06
ORIGINAL: JamieKerr
Thx
JK
Thx
JK
You mean the part that fits into the hole on the brake cam? I just looked in my manual. They are calling it the "brake rod".
#843
BRAKE ROD go to page 14 in the manual heres link to online manual http://www.modellismobucarelli.it/po...anuaHyper8.pdf
#844
yep thats what i was talking bout i just looked in my manual to looks like u found it first lol.
ORIGINAL: Firefighter7
ORIGINAL: adz06
ORIGINAL: JamieKerr
Thx
JK
Thx
JK
#845
GA
#846
GA
ORIGINAL: JamieKerr
Thx
JK
Thx
JK
Just got back from the first round of the Georgia Championship Series for 2007. Did not do as well as I would have liked but did start and finish and racked up 145 points. Missed getting bumped up to the A main by one position.
#847
Today I broke my first thing the rear upper arm rod end snapped, over a very small jump.
Was slightly annoyed but another set has been orderd. Has this snapped to any of you>>>????
#848
GA
The only problem I have had in about 4 gallons that is one gallon with my back up motor to break in and 3 on my STS D21B is the rear wing and damn radio box lids. I hate the radio box on these things!!!!!!!!!!!!!!!!!!!!!!!!!!
#849
yeah my lids come of an odd time to but i just grabbed some pliers and bent the we hooks at the back of lid and i use the bigger body clips rather than the smaller ones to hold the lid on tightly. also i have foudn the plastic lid to be better. seemingly people are only having trouble with the back of the lid some people have but 2 cable ties on the back and use them like hinges.
#850
What parts break on the buggies mainly?? i broke a rear upper arm rod which i dont really know how it was a 1 foot jump?? thx
