*Official Sportwerks Turmoil Thread*
#1353
RE: *Official Sportwerks Turmoil Thread*
i believe there is fluid and not grease in the diffs, as to what weight, i would have to ask the previous owner.......
not sure if that last post was directed to me or not but I am running the Sportwerks 21 V2
#1354
GA
getting ready for the rc pro series finale this weekend. heres most of my turmoil stuff i am taking. have more in a toolbox. also have 2 more gallons of fuel coming my way. only thing i dont have a spare for yet is the center diff and radio tray, hopefully those dont break
#1355
PA
Hey all i just picked up a killer deal on ebay for a turmoil I am guessing rtr roller. I just figured I would reach out to all of you on suggestions of what to do with it.. Should I keep it as a backup car? if so I have only raced with the stock .21 v2 engine.. any suggestions on what type of motor... I would like to stay under 200 if possible. Has any of you converted to brushless by chance? if so how was the conversion? Or should I just let it sit and use it for spare parts
#1356
GA
#1357
i think the .26 V2 is a great engine. not too much power output ([X(]),and its not too weak. although i dont know the price.
has anyone had problems with the breaks on this thing. i was just driving on my street and it locked on half throttle[sm=omg_smile.gif][]. i tried to swing it around, but i hit the curb[sm=crying.gif] thank God nothing broke but i this doesnt happen more. help
#1358
GA
ive had problems with mine but on the other end. compared to my cousin's 8ight and other buggies....mine doesnt like to stop.
and the .26 motor is pretty cheap, i think its around $130
#1362
WV
Well guys im switchin to a losi 8ight. Goin to be sellin my turmoil as a roller with alot of spare parts. Pm me if interested !!!!!!!
#1363
CA
hammy2
the brakes on mine went real fast about 1 1/2 gallons going to get the quad set to replace it when i get back.
#1365
GA
isnt one yet. turmoil was discontinued not to long ago. i asked horizon how long they will produce parts and if there is a new buggy coming out. they said they will make parts for a year but they didnt answer the new buggy question.
only time will tell
only time will tell
#1366
SD
Whats the differences in the pro chassis and the RTR?? If I change the chassis what other parts would I need to replace??
#1367
GA
i really dont think there is a difference in the chassis between the rtr and the pro. i think the only differences are the shock towers, motor mounts, shock springs, wheel nuts and uhhh it comes with aluminum clutch shoes
#1368
SD
You mean that as it isn't really worth it?? Because there is a difference. the pro is milled and has the FGC but I think the RTR has the FGC as well..
#1370
SD
The RTR is not milled...The pro is milled http://sportwerksrc.com/Products/Gal...K1105&Index=14 I am just wondering if there is a difference as in size wise..Would I need to get different drive shafts?? What is the beneft to haveing the pro??
#1373
Hey Guys,
I was just wondering, I see some awesome looking Turmoils out there, how do you get you buggy so clean after racing/bashing? What's the trick, solution, method that is best employeed?
#1374
SD
I tear mine down after every race day..............I use denatured alchohol and compress air...Stay away from the bearings though.
#1375
not only is the PRO chassis milled. it is 7075 alum. the rtr is 6061 which is alot less durable and less rigid. dimensions are the same, just better material and milled. it is a good upgrade from the rtr chassis. the difference is basically like any other pro buggy and its rtr counterpart. 8ight, RC8 etc. if you think there isnt much diference in 6061 vs. 7075, run clutch shoes made of these two grades of alum. and you will change your mind.
