RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
OFFICIAL HYPER 7 THREAD
Old 05-28-2007 | 11:22 PM
  #226
Default RE: OFFICIAL HYPER 7 THREAD
Hyper 7 Pro
milled extended chassis
Mugen big bore shocks
Pro-Line wing
Thunder Tiger Pro 21B-R
OFNA 053
Spektrum DX2/JR ST125MG/Spektrum Z270
SavageShockCovers.com shock socks
artwork on the wall by Jason Jenkins
Old 05-29-2007 | 01:55 PM
  #227
hi i brought a roller insted as its too much to build one up from stratch and hear it is !!!!!!!!!!!1111
Old 05-31-2007 | 08:25 PM
  #228
Townsley's Avatar
this might be off topic, but how do you tell if ur clutch shoes are worn out and when they need replaced?
Old 06-01-2007 | 05:10 PM
  #229
My Feedback: (138)
[8D]hi . flatspunout stadium truck freak very nice buggy's . Townsley you have a p.m. . thank's .
Old 06-02-2007 | 01:14 AM
  #230
I check the shoes and bearings about every 1/2 gallon of so, and if everything looks fine I'll scuff and clean the shoes, clutch bell and add a little oil to the bearings. I change the shoes usually about 2 gallons, there pretty cheap!
ORIGINAL: Townsley
Old 06-03-2007 | 07:13 PM
  #231
Townsley's Avatar
i blew out my back left shock, i looked and there was oil on the bottom. =[ should i just buy a whole new shock? i was runnin the stock with stock oil. anyway i also was wonderin what shocks other people run on their hyper 7's and what oil weight they use? what works the best in evry ones opinions? thanks
Old 06-03-2007 | 08:05 PM
  #232
no just buy a shock rebuild kit. i run 60 in the front and 40 in the rear. it helps calm down he steering a lot.
Old 06-03-2007 | 09:21 PM
  #233
Check the shock shaft also, it could be bent and need to be replaced.
I run 45frt and 40rr.
[quote]ORIGINAL: Townsley
[/quote
Old 06-03-2007 | 11:51 PM
  #234
Townsley's Avatar
alright. where can i get one of those? ive never done or repaired shocks before so im a noob at the whole thing...anyway. how would i do it? ill go to the lhs tommorow n get soem stuff.
Old 06-04-2007 | 07:39 AM
  #235
My Feedback: (138)
[8D]hi . here's a link to how to build the shock's .
http://ofna.com/images/man-hyp7pro-3.jpg
hope that help's . thank's .
Old 06-04-2007 | 07:49 AM
  #236
My Feedback: (138)
[8D]hi . doe's anyone know where i can get the pcr pro shock tower's as ebay doe's not have them . if you do know where i can find them please lmk . thank's .
Old 06-04-2007 | 08:08 AM
  #237
Foxy's Avatar
ORIGINAL: Townsley
White springs, 25 wt front, 30wt back. Stock oil is thicker than that, which may be why it blew out. There's also a trick involving drilling the pistons.
Old 06-05-2007 | 10:26 AM
  #238
Townsley's Avatar
where can i get the repair kit? thanks for all the info though. 60 in the front 40 in the rear? what is the the wieght of the stock shock oil in it?
Old 06-05-2007 | 01:03 PM
  #239
i really dont know. i know the guy that works at my lhs that has run the hyper 7 forever gave me my fluid setup. 60wt in the front 40 wt in the rear. he runs 3-3-5 in his diffs front to rear and i run 3-5-5
Old 06-05-2007 | 05:27 PM
  #240
Hi everone....well if it will help any ....in my 7 I run ...5-7-3..in my diff's and 60 in the front shocks and 55 in the rear it runs very well on the med. size tracks. and as for the engine I run a modded hyper 21 8 port....in alot of club racing they won't let you run big blocks...don't get my wrong there great for bashing..."S"...lots of speed[8D]
Old 06-05-2007 | 05:35 PM
  #241
Rs43EVOman's Avatar
ORIGINAL: junebug48
no, im not sure gut the best shock tower ive yet to see are the ones sold in the yannick upgrade kit. you can get just the shock towers on ebay at the dinball store.
Im not sure if ive ever posted pics here, but this is my Hyper 7, and the hop-ups list.
Hyper 7 PCR
Novarossi T21BF
2-Needle Carb off of a Novarossi P5X
JP-2 tuned pipe
Airtronics 94358Z steering servo
Futaba S3003 Throttle/Brake
Futaba 3PK Super Synth
1400 Mah NiMh RX pack
Front Yannick CNC shock tower towers
Rear Yanick CNC shock tower
Jammin Big Bore shocks off of a X1-CR FT on all 4 corners
Front 2.6mm Sway bar
Carbon Fibre lay down radio tray
Carbon Fibre diff housing
RC Screwz Stainless Steel Screws
5/5/1 diff oil set-up
45wt Front oil/37.5wt rear oil
Jammin Red Medium springs all around
Bearings in Steering
Old 06-05-2007 | 09:07 PM
  #242
Brutus's Avatar
Hey Rs43EVOman, I like the Yannick towers. I am having trouble finding the front sway bar. Any ideas where to find that for the Hyper 7?
Old 06-06-2007 | 05:59 PM
  #243
Townsley's Avatar
does it matter what brand of shock oil i get? so, if my chock is leaking, all i have to do is but the repair kit and replace those little rubber o ring things and it wont leak? hmmmm. anyway, does it matter what brand? imt rying to get it from towers but i dotn see any when i search fro it. its just diff. fluid
Old 06-06-2007 | 06:08 PM
  #244
Rs43EVOman's Avatar
ORIGINAL: Townsley
All the shock oil's for companies are all slightly different. Here's an excellant page on what they all equal, its very helpful site.
[link=http://www.twf8.ws/new/tech/tip/shock.html]Shock oil conversions[/link]. As far as shockil on towerhobbies I dont see how you couldnt find it took me literally 2 seconds. [link=http://www2.towerhobbies.com/cgi-bin/wti0093p?&C=CMH]R/C Car Lubricants / Shock Oils [/link]
ORIGIONAL: Brutus
yeah the yannck towers are great, got them from the dinball Ebay store. And as far as front swaybars, heres the link. There are 2 different thickness for different tuning options.
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCWC5&P=7]Ofna Anti-Roll Bar 2.4mm Hyper 7 RTR Pro[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCWC6&P=7]Ofna Anti-Roll Bar 2.6mm Hyper 7 RTR Pro [/link]
Old 06-06-2007 | 06:39 PM
  #245
Brutus's Avatar
... as far as front swaybars, heres the link. There are 2 different thickness for different tuning options.
Duh... I think I looked just about everywhere ELSE! Thanks!
Old 06-06-2007 | 08:23 PM
  #246
My Feedback: (138)
[8D]hi . very nice buggy Rs43EVOman . i think i see my shock tower's lol . i sill can no find the pcr pro's i don't think i can buy them from ofna and tower and speedmark and horizon hobby do not have them im runing out of place's to look for them . please if anyone know's were i can find them let me know . thank's .
Old 06-06-2007 | 08:25 PM
  #247
Rs43EVOman's Avatar
ORIGINAL: junebug48
[8D]hi . very nice buggy Rs43EVOman . i think i see my shock tower's lol . i sill can no find the pc po's i don't think i can buy them from ofna and tower and speedmark and horizon hobby do not have them im runing out of place's to look for them . please if anyone know's were i can find them let me know . thank's .
Im sorry i dont know what ur talking about, PC PO'S??
Old 06-06-2007 | 08:34 PM
  #248
My Feedback: (138)
[8D]hi . the r buton is not wrking the best lol . i mean pcr pro shock tower's . thank's .
Old 06-06-2007 | 08:40 PM
  #249
Rs43EVOman's Avatar
Well, i rember seeing them and their part number on the PCR site. and there was alsways a link to it under the OFNA.com links page, but the link isnt there anymore. Does OFNA not have association with Paul Coleman anymore?? You should really try calling OFNA and getting the part #, they probably wont be able to sell voer the phone, but if youve got the part number they can be found preatty easily.
wait are these them???
[link=http://cgi.ebay.com/OFNA-87374-CNC-7075-Rear-PCR-Shock-Tower-Hyper-7_W0QQitemZ110070291873QQihZ001QQcategoryZ34063QQr dZ1QQssPageNameZWD1VQQcmdZViewItem]OFNA (#87374) CNC 7075 Rear PCR Shock Tower [/link]
[link=http://cgi.ebay.com/OFNA-87373-Alum-Front-Shock-Tower-for-PCR-Hyper-7_W0QQitemZ5998168174QQihZ009QQcategoryZ49215QQcmd ZViewItem]OFNA (#87373) Alum Front Shock Tower for PCR [/link]
Old 06-06-2007 | 08:47 PM
  #250
My Feedback: (138)
[8D]hi . yes they do still have association with Paul Coleman as he make's part's for the hyper 8 . i will look again at ofna web site . thank's .
