RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Official 9.5 Violator Thread
Old 12-06-2007 | 11:48 AM
  #101
Force4x4's Avatar
Default RE: Official 9.5 Violator Thread
Well, I'm back and I can't wait to fire up my RC's, anyone still bashin' their Violator?
Old 01-08-2008 | 12:10 PM
  #102
Got my Violator yesterday. Now I need a pack charger and a starter box. What box do you recommend?
Old 01-09-2008 | 10:53 PM
  #103
Dokioto's Avatar
From looking at pics this looks a lot like my Ofna LX One.. True-False?
Might use some of its parts..
Old 01-12-2008 | 02:53 AM
  #104
Force4x4's Avatar
ORIGINAL: TR762
http://www.amainhobbies.com/product_...oducts_id/5767
http://www.amainhobbies.com/product_...oducts_id/2414
http://www.amainhobbies.com/product_...oducts_id/5768
For a pack charger just make sure it will support your style of pack (Nicd, NiMH, Lipo, etc).
Old 02-10-2008 | 11:48 PM
  #105
Just got mine last week. NICE! Force 32, roto-start with backplate, they even give you a hump-pack and charger! Need to set up shocks and rear spoiler. Looking to upgrade immediately to two-speed... Then she'll run like my GTP On-Road - <<Damn!!>>Can't wait till Spring !!!!!!!! Pic's to follow....WOOOOHOOOO!!!!
Old 02-11-2008 | 12:07 PM
  #106
Allan Aguilar's Avatar
Hello,
My 9.5/Ravager spur gear for the center diff is slowly wearing off, I will be needing a replacement soon, however, the spur gear only cost a lot of money, what other diff spur can I use (ie. Hyper 7/8/8.5, Kyosho 777 & etc.) and I wanted to reuse my diff case and gears. How about a new center diff assembly for other ofna models. Need your inputs here.
Old 02-26-2008 | 05:21 PM
  #107
Paradoxmaker's Avatar
ORIGINAL: Dokioto
False... The Ultras and the Violator share no common parts. The Violator is part of the Ofna (Hong Nor) 9.5 series which is the 9.5, the Ravager, the Violator, and the Mutilator truggy.
Old 02-26-2008 | 05:25 PM
  #108
ORIGINAL: Allan Aguilar
Hello,
The center diff mount from the Jammin can be swapped out with the 9.5 series, but i do not know if the spacing between the mounts is the same.
If you could measure the distance between the mounting screws (front to back) i could measure my Jammin and see if the entire center diff could be used.
Old 02-27-2008 | 12:03 AM
  #109
silverj's Avatar
Allan you can get the center diff with the spur gear for 20 bucks of e-bay!!
Old 02-28-2008 | 08:07 PM
  #110
My correct reply is shown next to this post.
Old 02-28-2008 | 08:08 PM
  #111
ORIGINAL: Paradoxmaker
Hello,
The measurement of the diff mounting screws are 39 mm. center-to-center. Let me know if your Jammin have the same measurement.
Old 02-28-2008 | 08:48 PM
  #112
Hello,
Nope, the Jammin center diff is 35mm center to center....So even though the actual mounts are the same, the diffs apparently are different sizes.
Old 02-29-2008 | 03:13 PM
  #113
I just got mine 2 day's ago and love it! Just upgraded the Steering servo today and can't wait to let it loose on our 1 acre track this weekend. Wonder what it will be like on the 10ft jump!
Old 03-01-2008 | 09:48 PM
  #114
Hi I am new to this forum. I have a 9.5 violator w/ force 32. I am having trouble getting it tuned. First thing I need to know is where do you take the engine temperature if using an infrared temp gun. Because I get many readings, ranging from 195 on top of heat sink to 260 on the polished sides around the top of the glow plug. Second I can get plenty of blue smoke, but when I get good throttle response, by leaning out the low needle, the temp goes up to nearly 300 ( again at the polished part around the plug). When things are rich on both the low and the high to keep temp down, it dies after idling for any amount of time. If someone could give me some advice it would be much appreciated.
Old 04-10-2008 | 08:35 PM
  #115
gentlemen, i just purchased one of these violators off of ebay. i am planning on getting the pillow ball suspension conversion from nitrohouse. does anyone have this conversion? and how did it hold up?
http://www.nitrohouse.com/mutilator,_mod.htm
Old 05-08-2008 | 12:27 AM
  #116
My Feedback: (25)
Does any one here know if the 2 speed transmission from the vioalator will fit in my hyper 7 w/ pbs ?
thanks for any help here
Old 06-09-2008 | 06:34 PM
  #117
BUMP Looks like a dead thread, any violators here? Report for duty violators I have some questions. he he he
1) Will the dogbone fit if trimmed to 310mm?
Old 06-10-2008 | 09:55 AM
  #118
reporting For Duty -
I beleive if you trim the arms you need to get the shorter dogbones / cvd's.
Old 06-10-2008 | 12:01 PM
  #119
Hey - Anyone having SUCCESS with getting the 9.5 Violator 2-speed to shift? Where is the initial set point for the screw? Mine either stays in first gear or starts in second gear - YIKES!!! I called OFNA and the guy there seemed to be clue-less!!! Manual does not say where the set point is!!! Can Anyone Help? Thanks!!
Old 06-10-2008 | 12:46 PM
  #120
ORIGINAL: 4.6Cobra
You use the dogbones/universals off of the Ravager.
PN#:
Universals: 36152
Dogbones: 36110
Roger
Old 06-16-2008 | 10:36 PM
  #121
Force4x4's Avatar
ORIGINAL: JamminRoger
ORIGINAL: 4.6Cobra
PN#:
Universals: 36152
Dogbones: 36110
Roger
Hyper 7's will work also. Long live the VIOLATOR!![>:]
Old 06-17-2008 | 09:56 PM
  #122
Force4x4's Avatar
This is what happens when you are going about 35 and you steer to avoid your son's monster truck and hit a curb[&o]
ID:	972875   Click image for larger version
ID:	972876   Click image for larger version
Old 07-27-2008 | 08:22 AM
  #123
I just ordered a Violator this weekend. What servos are you using in them?
thanks,
stahlee
Old 05-04-2009 | 12:44 PM
  #124
BlindObject's Avatar
I'm gonna bump this cause...it's needed.
Old 05-14-2009 | 09:33 PM
  #125
I'd like to know too, I want something that's stronger and faster...also, hows the .32 treating you guys? Is it finiky?
