Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC 1/8th Scale Buggies
 I keep having to replace my pullstart? >
RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Old 10-25-2008 | 08:56 PM
Themorales1999's Avatar
Default I keep having to replace my pullstart?
I keep having to replace my pullstart on my Ravager (Force .28) ? It gets cut or melted constantly and at $24 + or - each it's frustrating.
Any ideas how of what I should do, electric start or more manual pullstarts...? []
Old 10-25-2008 | 09:06 PM
46u's Avatar
46u
Default RE: I keep having to replace my pullstart?
Yes I have heard of this problem on the Ravager. You can all ways just replace the handle or string. Better yet get a starter box. Good Luck.
Old 10-25-2008 | 09:16 PM
A started box seems to be too much to carry since I only bash the car around parks or BMX parks. That's why I'm curious to know if I should keep buying pullstarts or invest in a battery powered/shaft starter?
Old 10-25-2008 | 09:44 PM
46u's Avatar
46u
With something like a Roto Starter you will still have a lot to tote around and you are subject to have more problems with it then a starter box. But to run a starter box you will more then likely have to get different engine mounts or a bigger flywheel. Check out the below link for shaft starters. Has a listing for your engine I do believe.
http://www.ofna.com/start-shaft.html
Old 10-26-2008 | 09:06 AM
Good to know, so basically any alternative requiers me having to be careful or have to carry lot's of stuff around. I thought the Roto Start may be the less problematic for a basher like myself since there's no string to break and as long as I remember to charge the battery in the roto I would be fine.
If anyone know of a way I can put away the normal pull start so as not to break string as often I would appreciate them sharing it with me....
Old 10-26-2008 | 09:17 AM
Banned
When starting loosen the glow plug a litle to reduce the compression. Once started tighten it back up.
Old 10-26-2008 | 09:36 AM
46u's Avatar
46u
ORIGINAL: bsrman14
The Ravager is know for melting the handle and string on the pull starter from the exhaust. Good advice but will not fix this problem.
