Go Back  RCU Forums > RC Boats > RC Boats General Discussion
Need a quiet RC boat >
RC Boats General Discussion Discuss general rc boating topics here.
Old 10-17-2024 | 03:49 AM
Default Need a quiet RC boat
Hi, I need an electric RC boat that will go about 10 ft/sec (3m/sec) as quietly as possible. Its only purpose is to be a platform for a GoPro. I’ll only be using it under light wind conditions. I’m hoping for a little advice for where to start. Thanks
Old 10-17-2024 | 04:13 PM
Hydro Junkie's Avatar
Just about any boat would work as a camera platform. I would recommend a boat of at least 36" for stability reasons. It sounds like you need something that isn't very quick since you're looking at less than 7MPH. Are you looking at a ready to run or would you consider building something out of wood?
o1grossman (10-18-2024)
Old 10-18-2024 | 08:21 AM
Thanks for your response. I have experience building models but I’m also open to buying something. As far as materials, I’ve seen a lot of diy projects made with insulation foam and fiberglass. Appearance is low on the list of priorities. The sort of things I’d like advice on are size, hull shape and choice of motor. I’m wondering if a catamaran might also be a good choice and would a shrouded prop be any quieter than an open one.
Old 10-18-2024 | 10:41 AM
A vee hull or cat would both work. Not sure why you would need a shrouded prop, that is unless you plan on an airboat. A boat with an underwater prop wouldn't need any kind of shroud.
Would one of these work?
SK Daddle Kit #1401 – Dumas Products
Swamp Buggy Kit #1501 – Dumas Products
o1grossman (10-19-2024)
Old 10-19-2024 | 12:25 PM
Originally Posted by Hydro Junkie
Not sure why you would need a shrouded prop…
I was thinking that a shrouded prop would be less likely get tangled up with seaweed. I’m guessing that a catamaran would be less likely to capsize.
Old 12-11-2024 | 05:13 PM
Is the necessity for quiet running for photographing wildlife? Check my math here but it sounds like roughly 7 MPH? Is it for a specific course, that is must it directly go from point A to point B? The reason I ask is because a sailboat in a light breeze is very quiet if you are ok with it tacking.
