Help please!
Old 10-04-2010 | 07:57 PM
Default Help please!
I have a Traxxas TMAXX 2.5 which I ran into a wall goin about 25 mph. Now it will not run the tires. The engine will start fine and all of the electronics work, but when I give it gas, the wheels do not turn. When I press the throttle, the big black gear will spin, and when I turn the wheels, it will not spin. Im a newbie so talk dumb in your responses please. Anything will help.
Thanks in advance!!!!</p>
Old 10-04-2010 | 08:01 PM
sheograth's Avatar
Moderator
Default RE: Help please!
Start taking it apart and see what broke. Something in the drive line got smoked.
Old 10-04-2010 | 08:09 PM
Do you know why something in the trans would break by just running it into a wall? Lol
Old 10-04-2010 | 08:12 PM
sheograth's Avatar
Moderator
Yeah, because things can break when slammed into solid objects. In a crash at 25mph you can damage most anything on a car.
Old 10-04-2010 | 08:41 PM
SyCo_VeNoM's Avatar
ORIGINAL: dcornwell14
you could have done many different things
Broke the Diff's, tweaked the chassis, just to name a few.
You basically will have to take it apart in stages and try rotating every piece to see what is binding, and then fix it.
Old 10-04-2010 | 09:04 PM
ORIGINAL: SyCo_VeNoM
Thanks! Ill try that
Old 10-04-2010 | 09:07 PM
Once I get inside will there be any type of fluid that ill have to deal with/put more in when im done (ive never taken one apart)?
Old 10-04-2010 | 09:30 PM
sheograth's Avatar
Moderator
Unless you take apart the diffs themselves or the shocks you won't unleash any fluids. Grease and oil maybe.
Old 10-08-2010 | 10:19 PM
Took it apart and found the problem! There was some grease so should I grease everything back up or just let it be? Im hearin different things from different people.
Old 10-08-2010 | 11:08 PM
Well if grease was removed during the tear down then put back as much grease as you think you removed.
