Guys please help with this pleaseeeeeee
Oh Man
Just got the savage 4.6 and thought i would upgrade the remote to the DX3E and well now the whole thing is messed up
I knew i should have left it i took the old receiver off and took out all the wires and none of them fit into the new receiver the ends of the plugs that went into the old receiver do not fit into the new one they are slightly bigger......
I will now have to pay a shop to sort it out because i have taken them all out and don’t know where they go..... plus none of them fit into the new receiver not even the failsafe
dam only just got the thing not even had a chance to try it yet.... now it will be sometime before i can take it to a shop unless one of you nice guys can walk me step by step through this whole thing if i take pictures of everything
Do you have the Owner's Manual? It shows how to hook up the stock system. You can then use it until you figure out what's up with the connectors.
By the way, are they really too big, or is it just a little "tang" on the servo connectors that wont' allow fitment into the receiver?
TX
Ok, you sound like you're new to the hobby. It's not all that complicated. Your Steering servo wire goes into Channel 1. Your Throttle servo plugs into Ch. 2, and if you have a 3rd servo or accessory, it'll go into Ch. 3 on your receiver.
Just go back to your stock radio, turn it on. Plug your old receiver back into the truck like I advised above, and turn it on. Don't run your truck's engine, obviously. Now test your trigger, and steering and make sure the correct servo moves.
If it's too confusing, plug the steering servo by itself into the receiver's slots, and test your steering to see if it works when you turn the radio's wheel. If the servo is plugged into the correct slot (channel) on the receiver, it should steer. Leave the steering plugged in and move onto the throttle servo, and test it with the trigger to make sure it works in the correct slot. So on and so forth.
Let this be a lesson. Don't just blindly pull wires out without understanding where they go first. And if you are upgrading to a DX radio, at least know what the wires plug into and what they do.
Most likely assuming all your equipment uses 3 wire servo plugs, your connectors need to be trimmed a little to allow them to slip into the new receiver's slots.
Thanks for the reply
No i don’t have the manual as i just brought the car 2nd hand i was going to take it out today for a little go but no i had to buy the dx3e and now its messed up
No it’s very small i could get some sandpaper and rub it down a bit do you think that would be ok and then it would fit
I am also unsure to what goes into AUX it says in the manual for the DX3E that the bottom is for the bind plug but then some where else in the manual it shows that’s where the battery pack gets plugged into
Am i correct in saying where it says Bind is where the battery pack goes and where it says AUX is where the failsafe goes?
Thanks again
Thanks again
Hi Slo-V Flyer
Thank you for your help
Yeah i just got a bit excited that’s all and thought i could just pull out plug in and go
Now my receiver does not have ch1 ch2 like you said
Picture below
Picture below
OH
Trim off the "ear" on the leads for your servos and battery holder and such, first thing.
Can't find a good picture, but if you compare your servo's plug to the receiver it should become clear.
After that, plug your steering servo into Channel 1 and throttle to channel 2 and your failsafe accordingly.
If you need any other help, let us know
ORIGINAL: Jo1234
Thanks again
Thanks again
<div style="margin: 0in 0in 0pt">The bind port would be where the receiver battery plugs in.</div><div style="margin: 0in 0in 0pt">The DX3E has a built in failsafe so you wouldn’t need an add on.</div><div style="margin: 0in 0in 0pt">The Aux would be for a transponder or something similar.</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt">You can download the manual here.</div><div style="margin: 0in 0in 0pt">http://www.spektrumrc.com/Products/Support.aspx?ProdID=SPM3160</div>
