official smartech buggy thread
Old 07-30-2007 | 01:23 PM
  #3626
Default RE: official smartech buggy thread
Hi guys newbie here. got a winner sport about 2 years ago but have not run it for about a year, went to start it the other day and to my suprise it fired up straight away, but the died after about 2mins. i started to muck about with both the high end and low end needles and think i have really messed up now as it wont even idle very long, does anyone know how to put it back to the factory settings so i can start again, also do you have to mess around with the low end needle as much as the high end one, all help will be appreciated, also it has a new glow plug in it.
Old 07-31-2007 | 09:30 AM
  #3627
jamiet2's Avatar
i put the spring back to gether as it had came un hooked but not i will hardly start an im gettin anoyed [:@]with it
ORIGINAL: nitro danny
does anyone know how to put it back to the factory settings so i can start again also it has a new glow plug in it.
same as nitro danny does any one know the factory setting please
Old 07-31-2007 | 10:45 AM
  #3628
docphysics's Avatar
HSN - 2.5 turns out.
LSN - flush with brass about 2 turns out.
Idle - 1 mm barrel opening.
Old 07-31-2007 | 10:53 AM
  #3629
jamiet2's Avatar
ok thanks alot is the low speed needal the main ajusting and is the high one the idle screw
Old 07-31-2007 | 10:56 AM
  #3630
docphysics's Avatar
idle screw is directly under the air filter, low speed needle is connected the servo linkage.
Old 07-31-2007 | 10:57 AM
  #3631
I've had my Smartech Speed Master VH-X5 for a few weeks now and the acceleration still sucks -.- . I had a leak where the exhaust joins the motor and just replaced the gasket expecting a dramatic increase in performance, but still nothing. My friends one just takes off and mine has much slower acceleration. Any ideas?
~Thanks
Ohh, and his makes a much more high pitched sound while mine sounds like i'm barely accelerating (Even though the intake is completely open ~_~). Same result without Air filter.
Old 07-31-2007 | 11:04 AM
  #3632
docphysics's Avatar
Is it tuned correctly? Sounds like one or both needles is too rich.
Old 07-31-2007 | 11:23 AM
  #3633
jamiet2's Avatar
ah right thanks so what about the main ajustin needle where should that be
thanks again
Old 07-31-2007 | 11:33 AM
  #3634
docphysics's Avatar
yea, the HSN is the big one sticking up in the air on one side of the carb.
Old 07-31-2007 | 11:35 AM
  #3635
jamiet2's Avatar
so thats got to be 2 .5 out
thanks
Old 07-31-2007 | 11:41 AM
  #3636
docphysics's Avatar
yes, that's the place to start your tuning
Old 07-31-2007 | 11:49 AM
  #3637
jamiet2's Avatar
ok thanks alot i will try it later might try 2 moro as well cant thusday as got to get my electric ready to race
but i will tell you how i get on thanks for the help
Old 07-31-2007 | 07:08 PM
  #3638
Where's the other Needle? I only know of the one next to the air filter, and the idle one.
Old 07-31-2007 | 08:29 PM
  #3639
SAVAGEJIM's Avatar
ORIGINAL: (X)
lol my smartech buggy was my first nitro RC, I got it when I was about 10.. And my dad knew nothing about them either..
These are amazing for the price! Mine was Always either super rich or super LEAN, and I didn't break it in, WOT on my first tank for most of it..
Anyway, it lasted me about 2 YEARS!
It's broke now, it's completely screwed up.. but I think all I will need to fix it is some new electrics and a new engine
Hey, Lewis, I didnt know you had a Smartech! I though you were a Monster truck basher, Savages and stuff.
BTW, why did you change your name to X?
Old 08-01-2007 | 04:50 AM
  #3640
jamiet2's Avatar
there is one needal the main ajusting one next to the air filter the big one sticking up then there is the high speed needle (idle screw under the air filter) and them there is a low speed needle where the servo linkage is where the rod coneccts to the carb
hope that helped
Old 08-01-2007 | 09:59 AM
  #3641
Ahh, thankyou ^_^.
Old 08-01-2007 | 10:21 AM
  #3642
jamiet2's Avatar
well i tryed mine quickley again to day but no luck would not start i know it just needs tuning but i just cant seem to get it to work any more also the pull start is now hard to pull even though the engine is not flooded anyone know if a lhs would be able to do it.model word is the closest one where i live
Old 08-01-2007 | 10:43 AM
  #3643
docphysics's Avatar
lift the wheels off the ground and pull the pull start. DO the wheels spin when you pull the pull start?
Old 08-01-2007 | 10:47 AM
  #3644
jamiet2's Avatar
no they did but it was the spring and i sored that out
Old 08-02-2007 | 05:12 PM
  #3645
Hey guys just bought a Smartech Speedy tiger on ebay and it needs a pull starter but i can't find the part # online any where and was wondering if any new what it was. I'm new to the Nitro RC world so any advice will be appreciated. Thanks
Old 08-02-2007 | 09:12 PM
  #3646
Keith.Desbois's Avatar
Just about any .15 size pull starter should fit. Take the old one to your LHS and try to match up the mounting holes with some they have. Just make sure you keep your one-way bearing or the new one has the same shaft size for the bearing. Good luck!
Keith.Desbois
Old 08-03-2007 | 12:22 AM
  #3647
Also i need a new clutch for it, just wondered if any other brands worked as i was reading past threads about stock clutch problems.
Old 08-03-2007 | 09:55 PM
  #3648
hi im new and i got a speedy tiger and when ever i start it it wont idle thanks please reply
Old 08-06-2007 | 02:28 PM
  #3649
Well I have a few questions about the Smartech buggy as well. I also own the winner sport and Its not all that bad. Its a great project car. Thats the reason I got into the hobby anyway. I would rather build it up myself rather then buy one for 500 or more $
Anyway my question is, Will I be able 2 fit the O.S. .18TM in the car and what other things should I change about the car? I am already looking 2 buy better shocks. Also should I change the clutch, flywheel. and clutch shoe or anything else. What is a good failsafe that will fit in the car? I am also just learnig. I know a lot about cars so I look at rc cars in that aspect just on a smaller scale.
CAN NE 1 HELP????????? THANKS.
Old 08-06-2007 | 02:41 PM
  #3650
jamiet2's Avatar
yep i think that the os will fit as ther is people that have said abou them later in the thread defenatly buy new shocks as the old ones are c**p they botom out all the time the common problem i have heard is the cluch shoes going i have aliminium ones wich i think are suppos to be better than stock may be tunned exsoust pipe and manifold the fly wheel will be fine not sur about the fail safe but i know they are deffernaty worth getting
