official smartech buggy thread
Old 08-06-2007 | 02:47 PM
  #3651
jamiet2's Avatar
Default RE: official smartech buggy thread
buggy 12 when you pull the pull start do the wheels turn? if so it will be the cluch if not it will be idleing to high so you need to turn down the needle
Old 08-06-2007 | 04:53 PM
  #3652
well I did wanna get a tuned pipe and header. What do you guys think would be the best pipe and header 2 go along with my O.S. 18TM? It needs 2 be a right side exhaust set up.
Old 08-06-2007 | 05:08 PM
  #3653
jamiet2's Avatar
not sure this is the tunned pipe and header kit for the os 18tm http://impaktrc.com/product_info.php...osCsid=d5e22ae
there is also alot on that site that will fit
Old 08-06-2007 | 05:16 PM
  #3654
Well I already have the manifold I just need the pipe. Thsi does look like it will work tho. what about a driveshaft? Im sure the stock driveshaft is gonna be a little 2 weak 4 all the power and prolly a diff as well.
Old 08-06-2007 | 05:21 PM
  #3655
jamiet2's Avatar
should be able to handle the power as people have put bigger motos in than the os 18 you might be able to get steel drive shafts and dif outdrives
some one eles might know
Old 08-06-2007 | 05:29 PM
  #3656
well I guess I'll just go with what I have now and see how it does with the engine. But thanks 4 the link 2 the exhaust. I think I will get that 1 ans see how things go.
Old 08-06-2007 | 09:07 PM
  #3657
docphysics's Avatar
the OS 18TM won't work. It is rear exaust, so your header will hit the rear upper chassis plate. You need the OS 18 CV-RX with rotary carb for a direct fit engine.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGGP7
ORIGINAL: ajk2649
Well I have a few questions about the Smartech buggy as well. I also own the winner sport and Its not all that bad. Its a great project car. Thats the reason I got into the hobby anyway. I would rather build it up myself rather then buy one for 500 or more $
Anyway my question is, Will I be able 2 fit the O.S. .18TM in the car and what other things should I change about the car? I am already looking 2 buy better shocks. Also should I change the clutch, flywheel. and clutch shoe or anything else. What is a good failsafe that will fit in the car? I am also just learnig. I know a lot about cars so I look at rc cars in that aspect just on a smaller scale.
CAN NE 1 HELP????????? THANKS.
Old 08-07-2007 | 10:43 AM
  #3658
hi Doc P
I got a Q about this OS engine. Will it be a direct bolt on or would someone need more accessories to fit the engine i.e. engine mounts, manifold gaskets, Just curious to know the pattern of the complete swap.
Thanks in advance for your help
Maurice
Old 08-07-2007 | 10:58 AM
  #3659
Well by looking at some of the specs on the engine it does looks like its gonna fit. I know the O.S. 18 CV-RX will fit. The only thing about the O.S. .18 TM that you may run into some problems is with the crankshaft. Its an easy fix tho. Just get a new crankshaft. That is what I have been told anyway. If anyone has anything diff feel free 2 let us know.
Old 08-07-2007 | 11:04 AM
  #3660
the clutch works and when i tried adjusting the idle needle it doesnt really work, should i turn it clockwise or counterclockwise to turn the idle down
Old 08-07-2007 | 11:11 AM
  #3661
thanks do you have any more suggestions, wich way do i turn the idle needle to turn it down
Old 08-07-2007 | 11:19 AM
  #3662
docphysics's Avatar
I think clockwise turns the idle down, but just look at the barrel opening to make sure. Also check your throttle trim to make sure the the servo isn't holding the barrel more open then the idle set screw.
ORIGINAL: buggy12
Old 08-07-2007 | 11:21 AM
  #3663
docphysics's Avatar
The OS 18 CV-RX is a direct fit. You can use the motor mounts, header, clutch, flywheel etc.... from the smartech engine and put it on the OS.
ORIGINAL: VFR700FII
hi Doc P
Maurice
Old 08-07-2007 | 11:23 AM
  #3664
thanks dock i was thinking about putting an os engine in my car do they run prety good with an os engine
Old 08-07-2007 | 11:30 AM
  #3665
i have another Q have the smartech engines been none to be sort of craapy or alright engines
Old 08-07-2007 | 11:39 AM
  #3666
docphysics's Avatar
well, the OS is an awesome engine and makes a ton of power. They start right up and hold a tune forever. However, you will be transferring addition power through the drive train, so if you womp on the gas you run the risk of stripping your plastic spur gears or breaking dogbones.
I really liked the Smartech engines. I had 3 of them and never had a problem with any of the engines themselves. Only had a OWB in the pull starter die on me. Other then that, I liked them. They were a little low on power compared to others, but they ran great.
ORIGINAL: buggy12
Old 08-07-2007 | 11:50 AM
  #3667
when i start mine up it the thing gos crazy it gos full throttle without me touching the reciever
Old 08-07-2007 | 12:06 PM
  #3668
docphysics's Avatar
how big is the barrel opening in the carb?
Old 08-07-2007 | 12:22 PM
  #3669
What so u guys think would be the best header and exhaust 2 get 4 the 18 CV-RX? Does anyone have a link they could post or have a website?
Old 08-07-2007 | 12:43 PM
  #3670
docphysics's Avatar
Here's what I recommend:
http://www2.towerhobbies.com/cgi-bin...&I=LXSP47&P=ML
http://www2.towerhobbies.com/cgi-bin...&I=LXBTB5&P=ML
ORIGINAL: ajk2649
Old 08-07-2007 | 01:05 PM
  #3671
im not sure its in my dads shop and its locked and has a alarm but probalbly a little more than 1mm
Old 08-07-2007 | 01:20 PM
  #3672
docphysics's Avatar
tweak your idle screw and throttle trim to a little less than 1 mm and see what happens.
Old 08-07-2007 | 01:55 PM
  #3673
i got the o.s max 18 but i need a clutch who makes an alluminum clutch for it?
Old 08-07-2007 | 02:30 PM
  #3674
thanks dock i will try today
Old 08-07-2007 | 02:51 PM
  #3675
Well you said it wont fit the O.S. 18TM because its rear exhaust and will hit the rear upper chassis plate. What if I were 2 buy the header that fits the engine and is horse shoe shaped so it will curve around and I can have it as the right hand side exhaust set up that I need it 2 be?
