official smartech buggy thread
Old 04-29-2008 | 09:49 AM
  #3926
jamiet2's Avatar
Default RE: official smartech buggy thread
amzk
it might be the cluch cos i had it hapen befor then i brake it stalled to test this put it on somthing and pull the stater cord if the wheels turn then it is the cluch
Old 04-29-2008 | 10:05 AM
  #3927
tried it and it does spin but its fine though i think i might need to adjust the settings servoo likage but the screw is rounded off. help with this?
Old 04-29-2008 | 10:09 AM
  #3928
jamiet2's Avatar
so the wheels dont turn when you pull the pull start
i never had a problem with it you could try the throttle trim maybe cos i used a different radio to the one i gave u so it might need some adjust ment
Old 04-29-2008 | 10:22 AM
  #3929
how do you adjust the 2 speed transmission?
Old 04-29-2008 | 10:30 AM
  #3930
docphysics's Avatar
ORIGINAL: amzk
that was just posted yesterday
http://www.rcuniverse.com/forum/fb.asp?m=7430889
Old 04-29-2008 | 10:31 AM
  #3931
jamiet2's Avatar
i posted the awnswer back a page
it was changing gear at the right time you should hear it
but it might not go any faster as the second small gear is stripped even if you adjust it
you will hear it change but it wont go faster
Old 04-29-2008 | 10:44 AM
  #3932
where can i get decent cheap spares and do you have the tuning instructions for the cen nt16 engine?
Old 04-29-2008 | 10:49 AM
  #3933
jamiet2's Avatar
blacksmith products on ebay
er i dont have the tuning instuctions for that engin but they would be the same as the smartech insructions i didnt need them any way if you turn the hight speed nedle left it will make it more lean right would make it more rich and the same for the lowspeed i think
Old 04-29-2008 | 11:06 AM
  #3934
clockwise anticlockwise?
Old 04-29-2008 | 11:09 AM
  #3935
jamiet2's Avatar
for what
Old 04-29-2008 | 02:11 PM
  #3936
i wonder if there are any metal 2 speed transmision?
Old 04-29-2008 | 02:50 PM
  #3937
jamiet2's Avatar
nope not that i know of smarthech isnt a very well known make so they dont make any hopups
Old 04-29-2008 | 03:22 PM
  #3938
btw do acme condor parts fit on it as i saw notes on the instruction manual
Old 04-29-2008 | 03:49 PM
  #3939
jamiet2's Avatar
i dont know i know some parts do like shocks but not sure about any thing else
Old 04-29-2008 | 03:51 PM
  #3940
what else can you upgarde to get more speed out of it
its running on 20%nitro
Old 04-29-2008 | 04:00 PM
  #3941
jamiet2's Avatar
you could put a bigger engin in it like an OS i wouldnt run it on 20% cos it was only run on 15% most people only use 15 or 16% fuel if you change the fuel it changes the engines tunning that might have been y it was stallin my savage whith a 4.6 engine is only run on 20% and the engine is three times as big if it isnt changing gear cos the small gear is shreded then geat a new gearbox that will make it go faster
Old 04-30-2008 | 05:37 AM
  #3942
Guess what happened. The pull start disengaged and i hade to screw the backplate of the pull start!
Old 04-30-2008 | 09:29 AM
  #3943
jamiet2's Avatar
what how did that happen
Old 04-30-2008 | 12:08 PM
  #3944
maritimeracing
Thanks alot for your help. But i have another problem...when i pull the pull start the wheels move. I took the engine out and the metal gear like cogs dont spin freely. Be great it you could help. Thanks
Old 04-30-2008 | 12:18 PM
  #3945
jamiet2's Avatar
if you mean the cluch bell wich is
this isnt spining freely than it is you clutch
Old 04-30-2008 | 12:52 PM
  #3946
the screws of the pull start backplate were slighltly loose therefore not lettin it start. You gave me an extra set of shocks. which are better ones
Old 04-30-2008 | 01:51 PM
  #3947
jamiet2's Avatar
no the 2nd set are crap thats why i got the ones that are on it the second ones bottom out all the time and sink with the wight of the buggy
Old 05-01-2008 | 08:08 AM
  #3948
Is there any reverse module for these?
Old 05-01-2008 | 08:09 AM
  #3949
docphysics's Avatar
nope, never will be either.
Old 05-02-2008 | 03:00 PM
  #3950
New problem
The car hardly starts and ends up flooding evey time i nearly pull it. also i think the glow charger is losing its charge. how can i prevent it from floodin and how can i make it start up really fast!
