Fail safe issues with range?
Old 04-27-2007 | 10:52 PM
Default Fail safe issues with range?
Has anyone had issues with their fail safe sort of going wacky when the car is far away? I have an ofna fail safe and I'm using a futaba fm radio on my Jato. It doesn't do it with the steering, just the throttle, thats why I'm assuming its the fail safe.
Old 04-28-2007 | 12:08 AM
Default RE: Fail safe issues with range?
One of the purposes of a failsafe is to activate when the radio signal is low or lost. So since you mention you are having a problem when the car is far away and it only impacts your throttle, I would say your failsafe is working as designed. I always check my failsafe before I start by turning on my car/radio then turining the radio off and checking my car to see if the throttle servo/ESC moves to the failsafe psoition. How far away is your car when you are having these problems? And what kind of radio are you using?
Old 04-28-2007 | 06:56 AM
I have the same problem with my venom thermal fail safe. I heard alot of complants that the radio range drops by half when using a failsafe
Old 04-28-2007 | 09:46 PM
I'm using a futaba FM radio, their latest non synthesized. I'm also using a novak receiver, could that be the issue? The distance it cuts out isn't really that far, not enough to do a good top end pass (the jato does take a little while to completely wind out). I'm pretty confident with the radio so I may remove it.
Old 04-29-2007 | 01:43 AM
Most modern radios have excellent range, several hundred yards? It appears something is causing interference and reducing your range. Batteries fresh? Antenna ok (both transmitter and receiver)?
Old 04-29-2007 | 08:33 AM
Like I said before, it could be your failsafe. Take off your failsafe, put your car up on a stand or some blocks (so the wheels can spin) start it up, then take the walk LOL.
see if your range increases. If it does = failsafe, if it doesn't = radio
