Guys, Is This Normal.?
Old 07-30-2008 | 06:24 AM
qaiz's Avatar
Default Guys, Is This Normal.?
Guys well ive decided to make the Jump and run LiPos as reciever packs.
Was trying to charge it today, its a 7.4V pack, and the charger showed this [&:]
No idea whats happening, im using a LiPo charger.?
And this is the battery
Also, I picked up a " Step Down Regulator " , is that fine.?
They didnt have a 6V reg, so I setteled for a 5.1V for the time being..
Old 07-30-2008 | 06:39 AM
My Feedback: (325)
Default RE: Guys, Is This Normal.?
Both look fine to me.
Old 07-30-2008 | 07:16 AM
qaiz's Avatar
ORIGINAL: guver
Thanks Guver
Wasnt sure if it was being charged right.
Old 07-30-2008 | 11:20 AM
It looks fine but it'll take a few hours at that rate. You can charge that battery at 1 amp to speed it up.
Old 07-30-2008 | 03:28 PM
DaveG55's Avatar
ORIGINAL: ozium
A 1050 mah battery will only take 2 hours to charge at a .5A charge rate, not a few hours. For that battery 1C would be slightly over 1A and will charge it in 1 hour, instead of 2. And that's assuming the battery is at it's cut-off voltage. If it has some charge left those times could be much shorter. As for the voltage, if that's what you're asking about, 7.75 volts for a fully charged 2S battery is just fine. The rated voltage is a nominal voltage, not a fully charged number. But what you really need to watch is the balance between the two cells. Use a volt meter and check the voltage on each cell. They should be identical - or very close to it. If you get a ballancer then that won't be an issue either.
And, yes, the reciever and servos will work fine on 5.1 volts, but will be faster/stronger if you can upgrade it to 6v.
Old 07-31-2008 | 10:05 PM
ORIGINAL: DaveG55
Thanks Capt Obvious! (just kidding lol).
Yes, 2 hours...is a few hours.[sm=bananahead.gif]
And yes, 1 hour is less than 2 hours, which is why I said the battery will charge faster at 1amp. You didn't have to clarify that for me, thanks. And I don't know of any chargers that will let you charge at 1.05 amps, which is why I said 1amp.
Old 08-01-2008 | 10:23 AM
common usage of the word few usually means 3 or more
when most people mean 2 they say a "couple"
Old 08-01-2008 | 10:34 AM
Yes, in the dictionary it states a few as meaning 3-5 and a couple meaning 2.
Old 08-01-2008 | 11:38 AM
The Hedgehog's Avatar
I agree 3-5 is a few. 2 is a couple. 3 is company.
Old 08-01-2008 | 03:48 PM
Good Lipo chargers use the CC/CV method. Constant Current/Constant Voltage
If the charger is set at 1C, and yes, some can charge at 1.05amps, then it will start at 1C. That's the CC portion of the charge cycle
Once the voltage of the pack reaches 8.4v (for a 2S pack, or 3.7v per cell), amperage will start dropping to avoid going over that voltage. This is the CV portion.
Once amperage reaches 0, or something close to it, then the pack is considered charged.
