Go Back  RCU Forums > RC Airplanes > RC Combat
 need plans >
need plans
RC Combat Discuss rc combat planes, techniques and strategies here.
need plans
Old 10-17-2006 | 10:51 PM
Default need plans
Hi, I need plans for the spad the "Spadrastic". This is my first time building an airplane so, I need the instructions to be easy to follow, and as for terms sutch as "flute" I have no clue what they mean. I know how to fly but, not build!!![sm=wink_smile.gif]
Thank You for any help, karate2kid
Old 10-18-2006 | 07:48 AM
Wild Foamy's Avatar
Default RE: need plans
erm... as for flute not even i know what it means, but i only joined R/C airplanes a few weeks ago...
try something basic, cheap n' easy such as an ugly stick (dont let the name put you off, they arent that bad) or a Free Flight/control line plane.
just my 2 cents... you could check http://www.modelaircraft.org/plansall/m-plans.pdf and see if they have them there, then you can order them
Old 10-18-2006 | 09:06 AM
A "flute" is the segment of corogated plastic. If you look at Coro end-on, you see a row of little boxes, those are the flutes.
Here's a picture of the horizontal stab from my Rapier plane. You can see the flutes at the bottom, and you can see how one side of one flute was cut away to make a hinge.
Old 10-18-2006 | 01:14 PM
Knight_74's Avatar
You can find the plans here:
http://users3.ev1.net/%7Ecdjump/main...gns/index.html
For basic information on spads you should go here:
http://www.spadtothebone.com/
Old 10-18-2006 | 08:57 PM
Thank you,Wild Foamy,Montague,Knight 74,
As for the Ugly Stick i do know what it is(a nice looking plane),as for simple goes,I have a B.U.H.O.R. that I used as a trainer,but now use it as a sport plane along with my Cap. Montague could You send a pic of your Rapier plane,please?[sm=rolleyes.gif]
Old 10-19-2006 | 10:07 AM
Sure, though it's not much to look at, looks a lot like a stick. It's an SSC-class combat plane, so it's built to be simple and rugged with out much regards to looks. I just had that picture sitting on a website.
Two Rapiers during a combat match. Mine is the red one.
Old 10-19-2006 | 07:15 PM
Thanks,nice pic. Just to let you know I am puting a GMS .76 2-stroke on my combat plane.
So,thanks again every one,I might post a pic of my combat plane on the forum but,that might be a while.
P.S. What happend, Montague?
Thanks,Karate2kid
Old 10-19-2006 | 08:13 PM
Alex Treneff's Avatar
Karate2Kid,
I don't think I have heard of anyone flying combat with a .76. The damage when the planes hit will be immense, not to mention the pieces flying toward the pilots.
You might want to look into one of the established .15-.25 classes, or even a .46 for club combat. A .76 is just huge!
Old 10-20-2006 | 10:13 AM
.76 class combat? Who are you flying against with that kind of power?
You'd do better with smaller engines, like Alex said, the damage to the planes goes up quite a bit as the engine power goes up.
I'm also not sure I understand what you're asking when you said "what happened" above. Do you mean that picture? I think it was taking right after a mid-air between those two planes, though I'm not sure. I used that picture because it was the first I found that showed the plane from a good angle where you could see the shape of the wing and fuse and so on.
Old 10-20-2006 | 03:21 PM
Judging from the streamers, Id guess just after a mid air...
The first combat spads we flew at our club were .40 size spads we down loaded off spadtothebone.com. I built a 48" Devistator v tail rig and a few other variations of it. If you go to the spad forum there are also links to plans there. I started out with a K&B 65 on mine at about 5 pounds. It was very fast. We eventually went to more standard nimble .25 size planes though we do still fly open C rules at club events using .40-46 size engines once a year or so. .40 size or less is good guideline, we like the 40 size combat cause more people here have old trainer motors lying around than .25s.
Have fun and be safe, combat adds additional risks due to the nature of the game.
Old 03-28-2010 | 02:55 PM
I know this is kinda out of date according to the original post dates but:
I would also like to have the link to plans for the SPADrastic or the Talon.....
The link in post #2 and #4 are no longer viable.....
I am an accomplished builder, have built 2 Spadette LC-40 trainers,
A dogfighter which is yet to be maidened,
Have a Spad Stick in process,
and About half way finished one of draftman1's Coyote,
not counting the several balsa planes i have built and flown over my years in the hobby before I found plastic.....
stumblebum2
ama47306
Old 03-28-2010 | 03:25 PM
Knight_74's Avatar
You could try a search here:
http://spadworld.net
I'm sure the plans are kicking about someplace!
Old 03-28-2010 | 07:39 PM
draftman1's Avatar
hows it going with the coyote?
Old 04-26-2010 | 10:40 PM
draftman1,
Again let me say it is not my intention to hi-jack this thread.
In reply to your question about the Coyote:
Got the wing finished except for the graphics and installing the axels and wheels.
Got the fuse built and rear servos mounted.
Got the fuse covered. I covered it in white to make it more visible (the white vinly is brighter than the downspout).
Got the fuel tank and engine mounted.
Got the stab and fin ready to mount.
Finally figured out the tail gear and got it set up.
Hope to maiden Friday if it doesn't rain.
Need a little enlightnment on the canopy.
Will post picture of finished plane here if I can learn how to do it or will e-mail to you.
Have fun in KC
stumblebum
