Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Drifting
 brushless or brushed for drifting? >
RC Drifting Discuss all aspects of rc drifting here!
Old 02-19-2007 | 10:45 PM
Default brushless or brushed for drifting?
Is it okay to have too much power for drifting? Because if it is, i'll probably just go with brushless since it is maintainence free.
Old 02-20-2007 | 01:50 AM
Default RE: brushless or brushed for drifting?
Do it man. I will never go back. I out drift everyone now. The power is a bit much at first but like anything you learn. When guys with brushed do a ten foot sideways drift, I can do twenty all day long.
Old 02-20-2007 | 05:53 AM
Brushed,
Brushless is overkill and Expensive when things go wrong
Old 02-20-2007 | 06:49 AM
jaskel's Avatar
ive been running brushless in my planes for ages..very cheap..
but what brushless motors would you guys use for a TL-01??? it would have to have the same can size as a 540 motor?
cheers
Old 02-20-2007 | 07:59 AM
there is nothing wrong with going bl. novak makes a bl system witch is equal to a 27 turn motor. novak ss4300. would be a great system.
Old 02-20-2007 | 08:31 AM
and when it goes Bang.. or overheats its more ex*****ive to fix..
I would go brushless for racing where there is adequate airflow..
Old 02-20-2007 | 08:53 AM
I am running a Mamba MAX 5700 BL system in my TC4. I love it. The motor never gets warm, nor does the ESC. There are a bunch of 540 size BL motors to pick from, just pick your favorite BL car ESC.
I dont have time for motor maintenance AND i had the BL system just sitting in a box, so that is why I used it.
I think long term, BL is cheaper, plus a lot less "motor involvement"
URC
Old 02-20-2007 | 12:02 PM
bigboi328's Avatar
or just do what im doing---go buy a brushed/brushless esc from castle creations $135 and use your brushed motor---when your ready to step up all you have to do is swap wires and motors----AND YES THE MAMBA MAX DOES BOTH MOTORS___LOOK AT THERE SITE YOU NEED THE CASTLE LINK to do it
Old 02-20-2007 | 12:07 PM
DAMN! I did not know that!!!!
Wow..you just gave me a whole new outlook on the options!
If the Mamba MAX does do both Brushed and BL motors, then it is the BEST ESC BY FAR, IMO.
URC
Old 02-20-2007 | 12:12 PM
ORIGINAL: bigboi328
BB,
I trust you, but where on thier site does it say this?
URC
Old 02-20-2007 | 01:55 PM
joeyblaze's Avatar
cann a TT01 handle a Mamba MAX 5700 BL?
what up grades would u need
i have TT01R
so i got bearings and alum drive shaft out of the box, would i be able just to drop that bad boy, then u could increase your cell count correct myabe to 8
i was more looking at the 4600kv set up says its as fast as a 12t
would this be safe for TT01R
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNKU0&P=ML]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNKU0&P=ML[/link]
Whats the stock shaft size?
Old 02-20-2007 | 02:02 PM
ORIGINAL: joeyblaze
i have TT01R
No reason why it would not work in the TT-01R. The 4600 motor would be great for drifting...but you would NOT need to increase your cell count to 8. I am running 6 and it is fast enough for drifting.
The mamba max motor dropped right into the stock TC4 motor mount.
As far as upgrade, I think you have most of them..just upgrade as you break stuff.
URC
Old 02-20-2007 | 02:08 PM
joeyblaze's Avatar
URC
yeah i think the 4600 set up would be great for drifting and if i ran an 8cell pack would rip it speed wise. what do you guys think
i just dont wanna put the BL set up and have to replaces gears and difs every run
Old 02-20-2007 | 02:33 PM
I have had no issues with my TC4 diffs or gears.
URC
Old 02-20-2007 | 03:03 PM
Users guide. Pg 5 per adobe, pg 8 per the guide.
Brushed motor wiring
(Note: There is no motor limit
with either Reversing Brushed,
or High Power Brushed Wiring
methods.)
Reversing Brushed mode:
(See Figure 2: Reversing
Brushed Motor Setup) Use
this mode if you wish to use
reverse. Use only the red and
black motor wires from the ESC.
In most applications, the red
Figure 2: Reversing Brushed Motor Setup
http://www.castlecreations.com/suppo...er%20Guide.pdf
ORIGINAL: UNITED RC
ORIGINAL: bigboi328
BB,
URC
Old 02-20-2007 | 03:10 PM
jaskel's Avatar
guys, ry ebay, i can get brushless cheaper than brushed... from a store
Old 02-20-2007 | 03:18 PM
thanks running gag
Old 02-20-2007 | 03:19 PM
ORIGINAL: jaskel
Jaskel,
EXACTLY. BL is getting cheaper and cheaper.
URC
Old 02-20-2007 | 03:33 PM
I would go with novak ss4300 that chiman2 mentioned. A buddy has one and i tried it and was really impressed. Has good power, and personally I liked it better than my setup (ta05 gts novak, d1-drift 19T motor).
Old 02-20-2007 | 03:41 PM
jaskel's Avatar
I think ill look into this BL setup...ill let u know what i find.
I just bought a brushless and ESC for one of my planes and it cost 35 bucks shipped.... see what I mean
Old 02-20-2007 | 04:00 PM
ORIGINAL: A.U.S.O
um. the chances of that happening would be next to zero. and you wouldnt be able to cause that to happen without purposely trying to break it. if that did happen. i could easily be a factory mistake. brushed motors break way more than brushless motors. bl are virtually maintanence free. no comm cuts. no brush changing. nothing. on the other hand with brushed motors. you have to do all that and brushed motors and i would think that brushed motors have a way shorter lifetime than brushless.
Old 02-21-2007 | 12:03 AM
jaskel's Avatar
agreed!!!! I have never touched a motor...i run my plane motor full blast all the time...its still going strong after 6 months.
Old 02-21-2007 | 06:01 AM
TT-01 will Handle a 13T Brushed motor so I think the 4600 would be safe..
Old 02-21-2007 | 11:01 AM
joeyblaze's Avatar
yeah how did u find this out, or are u just talking about the stock ESC
Old 02-21-2007 | 04:18 PM
i woudl think that a tt01 can handle more than 13t because people have put bl systesm that are like 8 turns and its fine. and no he does not mean the stock esc. the stock esc is rated for 27t. but tamiya says its actually rated for tamiya motors not others. but its fine.
