Drifter Survey (Car Setups & Performance)
OK
I'd like to just gather some information on your setups.
Basic Stats:
1. How long have you been drifting/race
2. How often do you drift? (times per week/month)
3. Car
4. Battery
5. ESC
6. Motor
7. Tires
8. Pinion to Spur Ratio
9. Servo
10. Radio
11. Upgrades
12. How much did you pay?
Subjective Observations:
1. How does it drift?
2. What is your runtime? (Range: race/bash)
3. Is there a specific surface it performs best?
4. Is the car balanced drifting to the left and right equally, or does it drift to one side easier.
5. Describe the performance characteristics of your car, compare and contrast if possible to other setups you've had or seen first hand.
Thanks, I hope the info we generate can benefit us all
Basic Stats:
3. Car
4. Battery
5. ESC
6. Motor
7. Tires
9. Servo
10. Radio
11. Upgrades
il start this then..
1. How long have you been drifting/race ....4years and i still suck...lol
2. How often do you drift? (times per week/month) .... most days/ 4 times a week
3. Car ... tt01 and a yoko blitz
4. Battery ... tornado 4300 hump packs
5. ESC ... lrp no limit brush or brushless
6. Motor ... 19turn peak racing v2 dynasty motor
7. Tires ... hpi hard compound
8. Pinion to Spur Ratio ... 59 spur.. erm... 21 pinion i think..il double check later...lol
9. Servo ... ko propo digital pds-2366 ics... $250!!!
10. Radio ... futaba mj
11. Upgrades ... to many, check my "im back post to look at cars...lol
12. How much did you pay? ... to much!!
1. How does it drift?.. tt01 is like a god, yoko sucks but it carrys a very nice image!!
2. What is your runtime? (Range: race/bash) ... semi race, gatherings mainly
3. Is there a specific surface it performs best? ... wooden fllors and polished marble!!
4. Is the car balanced drifting to the left and right equally, or does it drift to one side easier. ... equal as all cars should!!
5. Describe the performance characteristics of your car, compare and contrast if possible to other setups you've had or seen first hand. .. my car rocks, i use my tt01 over my yoko, i take alot of pride in my cars, set-up and looks, if you cant show of whats the point, these cars are for showing off, and i try my best to do it in style!!...lol
i try...lol...
i try...lol...
SECOND!
1. How long have you been drifting/race [4 months LOL]
2. How often do you drift? (times per week/month) [2 times a week]
3. Car [Tamiya TB02]
4. Battery [Venom 7.2V 3300 mAh NiMH]
5. ESC [Dynamite Tazer 15T]
6. Motor [Team Orion 19x2T Method]
7. Tires [ABS from ebay]
8. Pinion to Spur Ratio [19T Pinion, 58T Spur. (still wondering if this is a good ratio)]
9. Servo [Crappy acoms servo that came with my radio]
10. Radio [acoms technisport 5]
11. Upgrades [aluminum oil filled dampers, carbon damper stays, motor, esc, battery, stabilizers, heatsink with fan, HPI diff screws, um i forgot]
12. How much did you pay? [seriously, way too much]
1. How does it drift? [Drifts great, since it can drift right out of the box cuz i t has alu shaft, bearings, and ball diffs, all you need is tires]
2. What is your runtime? (Range: race/bash) [Run time is approx 1hr and 15 mins]
3. Is there a specific surface it performs best? [smooth pavement, and tarmac]
4. Is the car balanced drifting to the left and right equally, or does it drift to one side easier. [it has balanced drifting]
5. Describe the performance characteristics of your car, compare and contrast if possible to other setups you've had or seen first hand. [I beat my friends TT01, ill tell you that
Basic Stats:
1. How long have you been drifting/race... Havent started yet...
2. How often do you drift? (times per week/month)... see above
3. Car... TT-01R
4. Battery... DuraTrax 6-Cell 7.2V DTX4200 NiMH Stick Standard
5. ESC... Novak XRS
6. Motor... 27t p2k2 copperhead pro
7. Tires... ABS on 10 spoke touring rims (chrome HPI)
8. Pinion to Spur Ratio... 7.2:1
9. Servo.. spectrum race
10. Radio... hitec 75mhz/spectrum reciver soon to come with dsx3
11. Upgrades comes wit full bearings and oil shocks with alum shafts metal motor mount and p2k copperead pro 27t
12. How much did you pay? roughly $400 CDN bucks
will fill thispart out after i get the car...
3. Car... TT-01R
5. ESC... Novak XRS
OK
Basic Stats:
1. How long have you been drifting/race [1 month!]
2. How often do you drift? (times per week/month) [4 days a week]
3. Car [Tamiya TT01]
4. Battery [Tenergy 3800 Mah 6 Cell]
5. ESC [Tamiya TEU-101 BK 23Turn]
6. Motor [Mabuchi 540]
7. Tires [ABS Drift]
8. Pinion to Spur Ratio [P 19: S 61]
9. Servo [Tower Hobbies]
10. Radio [Tower Hobbies 2txp]
11. Upgrades [wheels]
12. How much did you pay? Around 330 for everything.
1. How does it drift? [It is sluggish and underpowered. It has a hard time drifting both directions with ease.]
2. What is your runtime? (Range: race/bash) [20 minutes aggressive]
3. Is there a specific surface it performs best? [the smoother the better it doesn't like bumps]
4. Is the car balanced drifting to the left and right equally, or does it drift to one side easier. [No it turns right easier than left]
5. Describe the performance characteristics of your car, compare and contrast if possible to other setups you've had or seen first hand. [Compared to the Himoto Nascada the TT01 stock configuration leaves quite a bit to be desired while offering its own perks, such as the great body, solid construction, nice wheels, and LED's.
Basic Stats:
1. How long have you been drifting/race a year
2. How often do you drift? (times per week/month) twice a week
3. Car kyosho v one s
4. Battery N/A
5. ESC N/A
6. Motor GS 15R, Nitrostar T-15
7. Tires yokomo one ring, PVC, ABS
8. Pinion to Spur Ratio not sure
9. Servo Hitec, futaba
10. Radio futaba Magnum Jr
11. Upgrades stock other than the replaced engine
12. How much did you pay? free car and radio 99 bucks for the T-15
1. How does it drift? ok, had to balance the car with added weight.
2. What is your runtime? (Range: race/bash) about 20 min.
3. Is there a specific surface it performs best? tennis courts ( much more grip )
4. Is the car balanced drifting to the left and right equally, or does it drift to one side easier. answered above
5. Describe the performance characteristics of your car, compare and contrast if possible to other setups you've had or seen first hand. it's my first one.
FL
1. Ive been running 1/10th on-roads (started with nitro's then electric's) for around 4 yers. Ive been drifting nitro for about a year when im bored, and ive started seriously drifting electrics about 6 months ago.
2. I drift probably 3 times a week, and during summer, probably 5 times a week.
3. Tamiya TA05
4. Megatech 4100mAh NiMH Batteries
5. Novak XRS (soon to be Novak Brushless set-up)
6. Trinity Co27 PRO 27T motor (also soon to be Novak Brushless)
7. ABS Tries made by Dorifto Kingu from the www.sflrcdrift.com scroll to bottom of page. their some of the best tires I've ever seen.
8. Not sure, im running the Stock Pinion, and Spur Gear
9. Hitec HS-625MG High-Speed
10. Futaba 3PKS Synth
11. 3Racing:
Carbon fiber bumper stiffener
Carbon fiber front shock tower
Carbon Fiber Rear Shock tower
Carbon fiber front chasss stiffener
Carbon fiber rear chassis stiffener
Blue Alum. Steering block
Blue Alum. 2 deg rear hub carrier
Blue Alum. Front and rear shocks
Blue Alum. Front Spool (For Rear)
Yeah Racing:
Blue Alum. front C-Hub
Blue Alum. Battery strap
Tamiya Sway Bars
Topcad Blue Alum. Motor mount
12. It all came out to around $475 after shipping, and everything (inluding all the radio, and motor gear + all the upgrades)
1. The car drifts great, all the hop-ups I've installed especially the 3Racing alum. front spool I installed in the rear, and the shocks have really helpd the car drif much better. And even though you might think that parts like the alum Hubs, and steering blocks wouldnt make much aof a difference they got rid of alot of the slop that devlopes after a few runs with the stock plastic. Stock isnt bad, but this just thightens every thing back up and makes it a bit more responsive, espiecally ovetr time where the plastic will wear out the Alum. will still be good as new. Also the sway bars, and graphite chassis stiffeners really help the car break traction easier.
2. My runtime is around 13-15 mins (I think ivbe nevr really paid much attention to the runtime).
3. Well like preatty much all 1.10th cars you want a smooth pebble free surface, but it does a great job of drifting wel even on rougher pavement.
4. After putting some tme into getting the car balanced as well as possible side-side it drifts equally the same. Now I'm just fine tuning front-rear balance.
5. Well i realzie that in drifting the car is alot less critical then in 1/10th scale racing. but I've found this car to just drift better then many of the other TT-01's and TB-02's i see. But TT's and TB's ive seen that have as much time put into set-up as mine drift preatty much equally as well.
3. Tamiya TA05
11. 3Racing:
Yeah Racing:
Tamiya Sway Bars
DE
Basic Stats:
1. How long have you been drifting/race: About a year or so
2. How often do you drift? as much as i can without thermal shutdown
3. Car: Tamiya TA-04
4. Battery: Radioshack 3300gp and trinity 1600mah
5. ESC: Hitec EZX-R Pro
6. Motor: Trinity Acornite 19t single
7. Tires: Taped baby!
8. Pinion to Spur Ratio: Whateva stock is
9. Servo: Hitec
10. Radio: Hitec Aggressor
11. Upgrades: Stock
12. How much did you pay? $100 for the 04 $80 for the electronics $20 for the 3300 battery
1. How does it drift? pretty nicely, the switchback is sick probably need to soften up the rear
2. What is your runtime? about 25-30 minutes
3. Is there a specific surface it performs best? carpet
4. Is the car balanced drifting to the left and right equally, or does it drift to one side easier. its pretty balanced. Belt FTW!
5. Describe the performance characteristics of your car, compare and contrast if possible to other setups you've had or seen first hand: It handles much better than the t-spec in both grip and drift, can kick the rear out easier, holds more consistient slides. The 04 is a little unpredictable on some of the switchbacks but overall handles like a beast!
9. Servo: Hitec
11. Upgrades: Stock
CA
Basic Stats:
1. How long have you been drifting/race: drifting for a few months and racing for a year and a half
2. How often do you drift? (times per week/month): about every weekend
3. Car: TT-01
4. Battery: Pro Max 3000MHz
5. ESC: stock
6. Motor: some 27turn
7. Tires: PVC
8. Pinion to Spur Ratio: dunno. pinion is 19tooth
9. Servo: stock
10. Radio: stock
11. Upgrades: stock
12. How much did you pay? just over 250 for everything
1. How does it drift? TT-01 is amazying at drifting. I LOVE IT
2. What is your runtime? (Range: race/bash): around 15min
3. Is there a specific surface it performs best? anything smooth i think
4. Is the car balanced drifting to the left and right equally, or does it drift to one side easier: it goes to the right just a little. its still perfect
5. Describe the performance characteristics of your car, compare and contrast if possible to other setups you've had or seen first hand: it handles great. it drifts awesom. thats about all i can answer
3. Car: TT-01
5. ESC: stock
7. Tires: PVC
9. Servo: stock
10. Radio: stock
11. Upgrades: stock
ON, CANADA
Basic Stats:
10TH..............LOL
1. How long have you been drifting/race.............about 2 years, im only 15
2. How often do you drift? (times per week/month)..........twice a day keeps the docter away
3. Car ..............Team Lsoi XXX-S
4. Battery........GP3300
5. ESC .....LRP F1 pro reverse
6. Motor ..........Trinty speed gems chromonuin(16t double)
7. Tires .................ABS and PVS
8. Pinion to Spur Ratio ......I'LL check!
9. Servo ..........Z590M(J.R)
10. Radio ......JR XR2i
11. Upgrades .........Should i list them all and take up the whole page
12. How much did you pay? ........Im standing on about only 450 without the car
1. How does it drift?........... CRAZY
2. What is your runtime? (Range: race/bash).................15/25
3. Is there a specific surface it performs best?...............Alll u can name
4. Is the car balanced drifting to the left and right equally, or does it drift to one side easier. ..................Balanced Baby
5. Describe the performance characteristics of your car, compare and contrast if possible to other setups you've had or seen first hand............this is MY first car sinece im a broke man,
Its better then my TA-02 i guess!
wow... you guys have some neat rides...
im just of out to buy an x-ray t2 so i can go brushless, when its complete il re-apply!!.. keep them coming, even if your new!!...[sm=spinnyeyes.gif]
1. How long have you been drifting/race For About 4 mths
2. How often do you drift? (times per week/month) well being the end of winter and I started while it was snowing.Whenever I can i think I have been out about 20 times in 4 mths
3. Car TT-01 X2
4. Battery 1500 Shark
5. ESC stock Tamiya
6. Motor 540 Sport Tuned Motor
7. Tires Tyoe D tires from Tamiya (not to bad)
8. Pinion to Spur Ratio stock for tt-01
9. Servo Futaba which came with my Radio
10. Radio a futaba 2 channel
11. Upgrades Aluminum Drive shaft Metal Bearings Aluminum Steering(both parts) Stabilizers front and rear Aluminum Shocks 20%oil Aluminum Heat sink metal motor mount
12. How much did you pay? in canadian Dollars I think it's time that I took out insurance on em for they cost me more than i want to mention.
1. How does it drift? My Tuned TT-01 Drifts better on Semi Slick tires than my somewhat stock TT-01 which drifts excellently with drift tires
2. What is your runtime? (Range: race/bash) Race 15 mins just drifting for fun 20-25 mins
3. Is there a specific surface it performs best? Tarma Ashphalt (new)
4. Is the car balanced drifting to the left and right equally, or does it drift to one side easier.The tuned is to heavy on one side trying to correct it the other is fine
5. Describe the performance characteristics of your car, compare and contrast if possible to other setups you've had or seen first hand I have two cars somewhat stock and Tuned to the max with Tamiya hop ups the stock tt-01 drifts a lot better then the Modded chassis
3. Car TT-01 X2
5. ESC stock Tamiya
Basic Stats:
1. Racing for 6 years, drifting for 1 year
2. Drift as often as i can
3. TT-01D
4. Team Orion Rocket Pack 3900mAh
5. Tekin Rebel
6. Team Orion Method R 17 X 2T
7. Tamiya Drift spec
8. Pinion 19T to Spur 51T
9. Spektrum Z590
10. Spektrum DX3
11. Carbon Upper deck, aluminum drive shaft
12. $250.00 for everything.
1. How does it drift? My TT-01D is a drifting monster
2. What is your runtime? (Range: race/bash) I really don't know how long it can run for. I usually drift for 30mins at a time
3. Is there a specific surface it performs best? Not really, it slides sideways on anything.
4. Is the car balanced drifting to the left and right equally, or does it drift to one side easier. It use to drift better to the left but i filled both diffs with silicone and now it's fine.
5. Describe the performance characteristics of your car, compare and contrast if possible to other setups you've had or seen first hand. witht the aluminumm drive shaft and silicone in the diffs, the car is crazy. My friends with yokomos are buying TT-01's now.
3. TT-01D
5. Tekin Rebel
9. Spektrum Z590
10. Spektrum DX3
ON, CANADA
ORIGINAL: crash_alot
1. How long have you been drifting/race - About a year, roughly. Maybe a bit under.
2. How often do you drift? (times per week/month) - Used to drift every day/couple of days but haven't drifted at all for the past month due to needing a new charger.
3. Car - Team Losi XXX-S
4. Battery - Venom 3600mAh
5. ESC - Novak/Losi XRS
6. Motor - Trinity "Nervous Breakdown" 19T (soon to be a 17T)
7. Tires - PE pipe (soon to be HPI Drift Radials)
8. Pinion to Spur Ratio - Ah **** I can't remember
9. Servo - Whatever comes with the JR XR2i
10. Radio - JR XR2i
11. Upgrades - None
12. How much did you pay? - $369AU RTR
1. How does it drift? - Bloody awesome, very smooth.
2. What is your runtime? (Range: race/bash) - 20 - 30min roughly
3. Is there a specific surface it performs best? I've only ever used it on tarmac so I can't really compare to other surfaces
4. Is the car balanced drifting to the left and right equally, or does it drift to one side easier. - It's very balanced, perfectly even
5. Describe the performance characteristics of your car, compare and contrast if possible to other setups you've had or seen first hand. - The car is great outta the box. It drifts perfectly without any mods bar tyres. It kicks the crap outta my old TB-02 which drifted to the left slightly better than the right. It's also a lot quieter being belt-driven
10. Radio - JR XR2i
11. Upgrades - None
ON, CANADA
ORIGINAL: heretic_666
10. Radio - JR XR2i
11. Upgrades - None
10. Radio - JR XR2i
11. Upgrades - None
Basic Stats:
1. Drift 1 year, Race 10years
2. Average about once a week
3. HotBodies Cyclone S
4. Intellect IB4200
5. Tekin G10 Pro
6. Tamiya RZ 23T
7. ABS
8. About 6:1
9. BlueBird 716ddg i think
10. Spektrum DX 3.0
11. Carbon Graphite Diff Cups
Carbon Graphite C-Hubs
12. Ahhh pass. made from many years of spending money
1. Very smoothly. handles very close to how I like it. Maybe a bit under steery which could be fixed with a sway bar
2. about 30min
3. Usually on smooth Tarmac but awsome on astro turff due to slightly more traction
4. Even as
5. Alot more even than my tt01. very similar to most decent cars on the market
4. Intellect IB4200
5. Tekin G10 Pro
6. Tamiya RZ 23T
7. ABS
8. About 6:1
10. Spektrum DX 3.0
2. about 30min
4. Even as
1. How long have you been drifting/race - about 5 days :P
2. How often do you drift? (times per week/month) - read above
4. Battery - Venom 3000mAh and a Trinity 3000mAh
6. Motor - Trinity "Nervous Breakdown" 19T, Just got a 17t, haven't tested it for drifting
7. Tires - PVC
8. Pinion to Spur Ratio - Pinion is a 24t and spur i think is 40 something i think 42.. not 100%
10. Radio - JR XR2i
11. Upgrades - 17t motor
12. How much did you pay? - $399AU RTR
1. How does it drift? - very smooth and very very responsive
3. Is there a specific surface it performs best? i ise it on my old wooden floor inside and it works great with pvc ultra slide
4. Is the car balanced drifting to the left and right equally, or does it drift to one side easier. - It's very balanced, the xxxs has an awesome chassie
5. Describe the performance characteristics of your car, compare and contrast if possible to other setups you've had or seen first hand. - The Losi XXX-S is a very good set up straight out of the box, you can start drifting with a very small adjustment... just change wheels to PVC
I made one adjustment and went and bought a 16t motor.. havnt tested it for drifting yet but we will see.. it should work
7. Tires - PVC
10. Radio - JR XR2i
it's not my track, right now i'm in New York writing my exams, so i don't know what's happening in scarborough, but i'll contact you for sure when i get back.
