RC Drifting Discuss all aspects of rc drifting here!
Nitro drifter
Old 04-27-2007 | 04:41 PM
GTB
Default Nitro drifter
I was thinkin' about getting a nitro as my first drifter.
RS4 3 Evo+, was my choice.
If I get this can I run pvc tires? I'm 15 and still in school. I can't burn my tires off quick or else I won't be drifting at all.
Thanks.
Old 04-28-2007 | 12:00 PM
GTB
Default RE: Nitro drifter
Bump
Old 04-28-2007 | 12:08 PM
yes you can run pvc i've ran pvc on my koysho v one s and it's been pretty fun.
Get ABS Tires because it has more grip than pvc. PVC don't really have any tractions at all. But just one thing, if your a nitro drifter try not to overheat your engine when drifting because you have to be at a certain rpm to have amount of torque.
Old 04-28-2007 | 12:12 PM
i find that for nitro pvc and abs are pretty much the same. i've drifted both and both seems to drift alike the only difference is that the pvc wheels lasted longer than the abs wheels.
Old 04-28-2007 | 12:13 PM
GTB
Cool.
I'll prolly get one know because of this.
Now I'm wondering if I shold get a sprint 2 or this.
Old 04-29-2007 | 03:18 AM
I wpuld Keep with the RS4 Nitro Evo +, im also getting it,
For Tires i would go for Abs or Just go to your local automotive part retailer and ask for Runnber Brakeline guides,
There a hard rubber compund and will last long and hanndle great with all that power!
Old 04-29-2007 | 08:38 PM
GTB
I'm still thinkin' about it.
Looks good though.
Old 04-29-2007 | 11:56 PM
i tried pvc not so good my next idea is abs or hpi slicks.... my onroad tires suck i had rip them now im out of tires >.<
Old 04-30-2007 | 08:33 AM
I have run both ABS and PVC on my RS4 Racer 2 and I seem to prefer the ABS a little more. With PVC, the wheels are spinning constantly to get anywhere, with ABS, they actually can grip just enough to get going or turn without have to have the wheels spinning constantly and they seem to respond better when trying to do techinical stuff.
Old 04-30-2007 | 03:26 PM
GTB
Is it goos for semi small areas?
Old 04-30-2007 | 04:01 PM
Its not too bad, here's a vid of the area I usually drift at, its not real small, but it isn't exactly huge. http://s94.photobucket.com/albums/l1...=DriftPath.flv
Old 05-01-2007 | 05:19 PM
GTB
Cool vid. The area where you drift at is way smaller than mine.
What's the setup on your car. i.e engine, pipe, etc.
Old 05-01-2007 | 05:42 PM
how are the rpms with those ? high or low ?
Old 05-01-2007 | 06:40 PM
ORIGINAL: GTB
I'm running an SH.12 with an Ofna X12 pipe. Recently bought a two-speed for it but haven't decided if I like drifting in 1st or 2nd gear. I have all four corners at zero camber, and 1 degree toe-in on the rear.
ORIGINAL: brokespokes31
Well, for the area in the vid it's about half throttle or lower with small bursts of full throttle if needed.
Old 05-02-2007 | 03:43 AM
Nice Vid!!!!
Old 05-02-2007 | 08:33 AM
ORIGINAL: FireStriker
Nice Vid!!!!
Thanks! The driving wasn't very smooth, it was the first time out in around four or five months.
Old 05-03-2007 | 09:01 PM
did u make those tires your self?
Old 05-03-2007 | 10:25 PM
No, I can't seem to find anywhere around here that sells ABC for some reason, or the people I talk to at the stores have no idea what they are talking about, so I bought them off of eBay.
