Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Drifting
 POST A PIC Of YOUR DRIFT CHASSIS THREAD >
RC Drifting Discuss all aspects of rc drifting here!
Old 06-23-2007 | 08:27 PM
fl0PPsy's Avatar
Default RE: POST A PIC Of YOUR DRIFT CHASSIS THREAD
Ahhh lovin the purple there !!!
Old 06-26-2007 | 12:58 PM
Hey All,
Here are some pics of my Sprint 2 chassis. I just wanted to share some pics of my chassis. And I was bored. When I got this chassis it was a Sprint 1 and now its a Sprint 2. It got transformed over a 2 to 3 year period. Took pretty long to get it where it is now. But its totally worth it because I love it!
HPI Sprint 2
Chassis:
-Graphite: Upper Deck
-Main Chassis
-Graphite: Shock Tower F/R
-Bumper Brace
Drivetrain:
-Spur: 87 tooth, 48 pitch
-Pinion: 25 tooth, 48 pitch
-Front Geared Diff
-Rear Modded Spool
-HPI Universal Dogbones
-HPI Aluminum Center 15T Pulleys
Steering:
-Spektrum Hi-Torque Servo
-HPI Aluminum Servo Mounts
-DuraTrax Servo Arm Purple
-Purple Turnbuckle Set
-Heavy Duty Ball Cups
Suspension:
-HPI Stock Springs
-No Shock Oil
-Camber Front: -1 degrees Rear: -1 degrees
-Droop: Whatever feels good
-Toe (Rear) 2 degrees, (Front) is eyeballed
-HPI Pro Threaded Shocks
Tires and Wheels:
-ABS and HPI Radial Type A's
-Speed Way Pal Slide Masters 6mm offset (front), 8.5mm offset (rear)
Electronics and Motor:
-Novak GTB ESC
-Reedy 3 Star
-Spektrum DX3
Misc:
Titanium Screw Kit
*Coming Soon:
-Integy Purple Antenna Mount
-Hpi Pro4 Servo Saver
-Cyclone Belt Tensioner (purple of course)
-Ball Differential
-Purple Cone Washers
So, if you got this far, you get to see the pictures, enjoy. . .
action shots,NAKED!
I know, alot of pics, I JUST LOVE MY SPRINT 2! Thanks for looking, leave questions if you have any. I'll be pleased to answer them. :wink:
P.S-Thanks marc for the layout. :lol:
Old 06-26-2007 | 10:51 PM
take the pics of them while it's sideway with body on
Old 06-27-2007 | 02:35 AM
redeyes's Avatar
what did it take to go from the sprint 1 to the 2?
I love my Sprint 1 with oneway in front and locked in the rear.
Old 06-27-2007 | 03:53 AM
peetiewonder's Avatar
Sexual Cyclone S
Deeeeeeeeeep Dish
Mamba and Racing Slicks =
In my other car im running a mamba max 7700 on 6 cells, 8+ coming soon
My drifter has a 19t K-dragon with a LRP ESC
Spektrum Reciever and Servo and a buncha standard equipment, lots of CF and Bling to come!!!
Old 06-27-2007 | 05:58 AM
  #31
Heres my Schumacher Mi2 set up for some drifting. enjoy!
ID:	712099   Click image for larger version
ID:	712100   Click image for larger version
Old 06-27-2007 | 07:48 AM
  #32
Nice cars,
Mamba's can really burn rubbers...............EH?
Old 06-27-2007 | 12:56 PM
  #33
ORIGINAL: redeyes
I basically swaped all of the old sprint 1 parts with sprint 2 parts, since the sprint 2's design was based of the a little of the pro4. Like the c-hubs and steering parts. You can put my sprint up against a sprint 2 and look almost the same.
But its still a Sprint 1 in spirit.
Old 06-28-2007 | 03:18 PM
  #34
krayzBIGmac can you please tell me where you got the aluminum spur gear holder. damn mamba keeps striping my plastic one.
thanks
Old 06-29-2007 | 01:27 AM
  #35
ORIGINAL: tougedrift
thanks
I actually got it when it was still available for the hpi pro2. So look around on ebay, hopefully u can find one there. Good luck!
Old 06-29-2007 | 06:49 AM
  #36
i kept it simple
700th post!!!
Old 07-09-2007 | 02:10 PM
  #37
GTB
Heres mine
Tamiya TA-05, Just built this weekend.
Old 07-09-2007 | 05:07 PM
  #38
studysession's Avatar
ORIGINAL: sk1pp3r
This is my Cyclone. HPI rims with custom made ABS tires. First ones, I think they turned out pretty good. ESC is on the way, can't wait!!!
Do you have a link to who makes the Cyclone? Thanks
Old 07-09-2007 | 10:06 PM
  #39
my tt-01 chassis specs:
Tamiya tt-01 Nismo Coppermix silvia kit
Tamiya ball-bearing on differentials
Boaca ceramic bearings on drive axle's and shaft
Tamiya carbon upper frame
Tamiya front and rear swaybar
Tamiya upper adjustable arms
Tamiya adjustable tie rod ends
Tamiya blue foam bumper
Tamiya aluminum racing steering set
Tamiya aluminum steering link
Tamiya aluminum toe-in rear uprights
Tamiya aluminum bumper stopper
Tamiya metal motor mount
Tamiya ball differential front
Tamiya locked stock diff rear
Tamiya aluminum clamp hub adapters
Tamiya universal axle shafts front and rear
Tamiya TRF dampner set with yellow medium springs front 30 weight oil, and AE factory team blue 18lbs rear with 30 weight oil
Tamiya evoIV prop shaft with Aluminum prop adapter front and rear
Tamiya stock 61 spur gear with Robinson Racing 22t pinion gear.
Square Racing Front carbon chassis stifner
Square Racing Rear carbon chassis stifner
Square Racing servo to steering turnbuckle link
Square Racing rear carbon bumper plate
Square Racing carbon shock tower stifner
3 racing aluminum servo mount
3 racing aluminum battery post
3 racing aluminum upper arm mount
3 racing motor heatsink w/ fan
GPM lower aluminum arms front and rear.
GPM aluminum front knuckles
GPM front aluminum bulkhead
speedway pals 37r sliders 8mm front and 10mm rear
HPI A-type drift radials
Team Novak GTB/Velocity 6.5
Hitec 965mg coreless high speed servo
Spektrum sr3001rx pro series
Old 07-11-2007 | 07:20 PM
  #40
Here is my TC3. enjoy
ID:	721035   Click image for larger version
Old 07-23-2007 | 03:23 PM
  #41
(old picture.) tamiya tt01d w/ aluminum shaft, novak xrs
I got a tc4 coming in the mail.
hopefully team factory conversion kit in the future.
Old 07-23-2007 | 09:31 PM
  #42
Coolala's Avatar
My newest chassis, TC5 (left) with old RS4 Pro2 (right). Going to race the TC5.
TC5
RS4
Old 07-24-2007 | 12:56 AM
  #43
Paulyd's Avatar
wats the difference between the abs tires, and company tires like the HPI type a's?
Old 08-01-2007 | 08:49 PM
  #44
its here! its here! not yet a drifter..
Old 10-13-2007 | 01:20 AM
  #45
Its a YooKooMoo
Old 10-13-2007 | 10:30 AM
  #46
Vic Nyce's Avatar
and now the never before seen nude pics. she was shy at first but after i tweaked her shocks, top came right off.
POW!
Old 10-13-2007 | 10:41 AM
  #47
Here are mine:
Old 10-13-2007 | 10:03 PM
  #48
fl0PPsy's Avatar
Hey nice collection
What kind of M chasis is that ?
Old 10-13-2007 | 10:17 PM
  #49
TY man.
The chassis are:
1. TT 01
2. TC4 RTR
3. Factory Team TC4
4. 18R
All brushless baby!!!!!!!!!
Old 10-14-2007 | 02:53 AM
  #50
ORIGINAL: psychorevo
TY man.
The chassis are:
1. TT 01
2. TC4 RTR
3. Factory Team TC4
4. 18R
Show off. Idea Jacker. Did i leave anything out?
Dude i better see you on the track tomorow!
