switching to lipos???
ok so im running an evader st with a castle 5700kv and im ditching the nimh"s and going lipo. but really need to know what charger and batteries i can run at a reasonable price. not really sure what kind of charger i need that will safely charge them ac/dc and not burn the house down. if im missing anything else needed for the conversion let me know.. thanks guys
TX
RE: switching to lipos???
In RCU, threads get pushed down pretty quickly in the car forums because of the popularity. If you don't want to helpthe OP....then don't post ANYTHING!
ORIGINAL: rc awesome
There are about threethreads about this now. Look around before asking questions.
ORIGINAL: res3567
In RCU, threads get pushed down pretty quickly in the car forums because of the popularity. If you don't want to help the OP....then don't post ANYTHING!
There are about three threads about this now. Look around before asking questions.
TX
Newbes coming into RCU should be greeted with open arms......I don't know the answer to the OP's question....but the newbes TO THE FORUMshould not BE TOLD TO LOOK AROUND BEFORE ASKING QUETIONS!
hes been on here for 2 years. hes not that newb anymore.
when i need infos, i try to find them on my own before asking a question that is asked everyweek.
even if they get pushed quick, looking on page #2 or 3 isnt that hard.
RCU is a great forum but its drowned by A LOT of topics on the same subject.
TX
You have been here since 08....with 700+ posts. He has been here since "09...with 20 plus posts. Lots ofpeople don't live on the RC hobbyinternet...as there is other thingsin life to consider. Do you now were the threadsare thatcould answer his question is?
ORIGINAL: impalapolicepack
TX
You are challeging me now....ok point well taken.....look at how many times I have helped other OP's when I knew the answer. I was challenging another poster who left a negative post and then you turn it back on me.......GOOD JOB!
TX
These are the batts i am using
http://www.hobbyking.com/hobbyking/s...obby_Warehouse
And this is the charger I am using
http://www3.towerhobbies.com/cgi-bin...&I=LXTCK1&P=ML
I have a Tamiya Frog.... running a Traxxax VXL with a Tacon 3930 brushless motor........so I don't know how it will work with the Evader and Castle setup
ORIGINAL: stealth si
TX
Ok AUTOMAN....YOUR REPLY TO THE OP???????
ORIGINAL: AutoXMan
ORIGINAL: res3567
TX
ORIGINAL: res3567
http://tinyurl.com/5wffvnr
TX
Ha....you had to call me a hypicrite BEFORE you left the OP a reply. I don't know about the Evader/Castle setup....but I challenged a poster who almost ran off another OP cause I thought it was not right. I thought I was doingthe right thing but you chose to say otherwise and call me out......
MI
I just got a Thunder AC680 from Hobbypartz and it's very nice for the price imo.
http://www.hobbypartz.com/73p-ac680-accharger.html
I ordered, but haven't received 2 Turnigy 2S 30C 5000mAh Lipo's from Hobbyking.
I'm not sure on your specific truck, but you'll want to make sure you have metal trans gears and I myself just today replaced all of my bushings with bearings.
Do a search before asking?
And res, why stick up like you are dating the op? Save the advice on HOW and WHAT to post for the mods, youre no higher up or "holier" than any of us. Chill
ORIGINAL: res3567
ORIGINAL: AutoXMan
ORIGINAL: res3567
The castle stuff likes LIPO's so yeah Id run them instead of NIMH'S.
Me, I use alot of Tekin, Novak and LRP stuff so im fine with nickel metal packs.
I have no cogging like others have experienced running nickel's with the castle esc's.
Because I know which ones to use with the packs I have.
Since I have no castle stuff Im better off with NIMH.
Read up on how to take care of your lipos and you should be ok.
You have to know alot of things before you change over.
FL
I have an [link=http://www.hobbypartz.com/thac6smbachw.html]AC6[/link] charger and a [link=http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8357]zippy lipo.[/link] I picked both of them up towards the end of 09 and have been using them since with no problems.
i run venom 2s and 3s5000 mahbatteries and use the duratrax onyx 235charger with built in cell balancing. i have not had any problems with either and they sell for a resonable price. just make sure you do not exeed you motor and speed controllers limit with the batts.
TX
Pont well taken. I am not comming across as being better than any of ya'll. I was just trying to stick up for the OP. But you are right. I aint no mod and I will chill......stuff like that irritates me....that is all......
ORIGINAL: HimmlerHimself
ORIGINAL: res3567
ORIGINAL: AutoXMan
ORIGINAL: res3567
ORIGINAL: chase1
i run venom 2s and 3s 5000 mah batteries and use the duratrax onyx 235 charger with built in cell balancing. i have not had any problems with either and they sell for a resonable price. just make sure you do not exeed you motor and speed controllers limit with the batts.[img][/img]
how do you exceed the motor, and speec controller limits?
I run 30C 5200mah batteries on 35 ESC's no issues. The MAH rating and C rating are potential not what it will use. Theoretically you could have a 5000C 500000mah battery hooked to a 35A ESC/motor setup, and it will never pull over what the motor can use. Think of it like your real cars gas tank you fill it upto 10-15 gallons (or whatever capacity it is) and it drives for awhile the engine doesn't just take the whole tank at once.
Personally as for batteries measure your battery compartment and start from there. Lipos come in a variety of sizes and sometimes fitting one up to the battery compartment is a royal PITA. Then figure out how many continuous amps you will need (usually in the motors specs) and start shopping from there.
Chargers I love the turnigy accucell 6's I own 2, and made one of these http://www.rc-monster.com/forum/showthread.php?t=27554 to power it. (best 12V supply I've used in ages)
OH
ORIGINAL: res3567
You have been here since 08....with 700+ posts. He has been here since ''09...with 20 plus posts. Lots of people don't live on the RC hobby internet...as there is other things in life to consider. Do you now were the threads are that could answer his question is?
