OFFICAL PEDE THREAD
#8226
MO
RE: OFFICAL PEDE THREAD
it may be titanium. That is hard to bend. Trust me. But it sparks lol. I still have one left, i will sell it for 30 shipped. PM me if interested.
#8228
FL
ORIGINAL: j.m.
it's probably steel. It looks kinda rusty. Titanium doesn't rust.
#8230
NC
titanium is twice as heavy as aluminum. Literally.
Iron (steel, just a tad heavier) is just as heavy as titanium, so steel and titanium are about the same weight, if not steel actually being a touch lighter.
#8231
MO
uh no im pretty sure you are wrong. I work with metal every day, my dads a machinist. Titanium is lighter than steel, a little heavier than aluminum but not much. Titanium is so hard to work with cause it is so hard. It is hard to drill, it eats drill bits, and it is very hard to bend.
#8233
ON, CANADA
My stampedes driveshafts are waring out at the pins. its not to bad now but theres slack, but at one time i herd the CVD's limit shock travel is this true?
#8234
ORIGINAL: Redvanmafia
#8235
My Feedback: (8)
My pede is coming in a few hours and i just want to know what exactly needs to be done to the chassis to let sxs packs fit( i only have sxs packs)But the pede will be here soon so
#8236
SC
You will just need to stick the battery in there and see how much needs to be taken off each side. Sand it down untill it fits snug in there.
And no fuse the motor sparking isn't good. It does it at first when your first running in the motor, and it does it when the motor(atleast the comm or brushes) are getting worn out. when they are in good condition the motor shouldn't spark at all. And if it does it shouldn't be much. Wit hthe titans being somewhat low RPM they won't spark really... Just do what AD said. It will tell you exactly what is wrong...
#8237
NC
ORIGINAL: fusebmx13
The atomic weight of titanium is 47.8
The atomic weight of iron is 55.8
Steel is lighter than iron.
Aluminum is just about half the weight of titanium, which is about the same weight as iron. SO< titanium and steel are pretty much the same weight.
#8238
FL
ORIGINAL: j.m.
The atomic weight of aluminum is 26.9
ORIGINAL: fusebmx13
#8239
SC
Yeh I think you did. So I am planning on buying a 6s from a guy to cut down into 3 2s packs or else buying two Yeah racing packs SOON. Maybe... If so my 4s speed pede will come to life!
#8240
ORIGINAL: streetracer745
MTpockets - If your running 3s on vxl and are doing ONLY speed runs. No hard launches or anything. You can gear it a lot! I ran mine on a 30/70 with 2.2 road rages on maxamps 3s lipo and vxl. It was insanely fast.
#8241
Hey guys im somewhat new to the stampede i have a 96 arr i have it all running but havnt played with it for quite a while so i am going to try to get it going again. I was wondering what all i need to do to convert my wheels to ball bearings and what the best method of widening the front end is? Any info will be greatly appriciated. also if you can give a list of parts for these things.
#8242
Titanium is way lighter than steel. You can't just say steel is lighter than iron??? What kind of steel? Steels are mostly iron and very small amounts of other stuff. Steel is iron, a little bit of carbon, and whatever else you want tossed in. If you want to know if something is titanium or steel,put a magnet on it. Generally speeking the density of steel is about 1.77 times that of titanium alloys.
2"x3"x8" block of steel would weigh approx. 13.6#, if it were titanium it would be approx. 7.68#
You can't go off atomic weights to argue that titanium is remotely close to being the same weight as steel. There's a lot more going on than just raw base elements when it comes to titanium and even ferrous alloys. Alot of your titanium out there has aluminium and vanadium alloyed with titanium as a base. Alot of your steels have chromium,moly,nickel,silicon,hell you name it, its in there.
#8243
SC
ORIGINAL: MTpockets
wow, 30/70. the highest ie gone so far is 26/76 and it was pretty fast. did you happen to get any numbers off of that run?
http://www.youtube.com/watch?v=F2jKoNtDOHY
#8244
FL
I went to run my pede today and idk what happened but it started making a rather weird noise sounded like a striped gear, but different, almost like a claking noise. I actually thought i was dragging something or hitting my wheels with something but nope. I'm going to take the dif apart tomorrow and see whats going on[:@] on the bright side the wheelie bar worked very well and i got some decent pics of my pede on top of my car
BTW: about what metal it is it isnt too heavy, and it does attract magnets, sorry i dont have a scale sensitive enough to weigh it for you guys[:@]
#8245
SC
is the "clanking noise" comming from the tranny? Checked the rest of the driveline? Thats a firebird right? Your real car. Or is it Trans am?
#8246
FL
#8247
MO
#8248
SC
No sparks aren't completely bad. It just means you have brand new or worn out brushes. Once the comm and brushes set properly, the sparks shrink or stop. Once they wear out so far, the sparks come back... The motor is still fine for a while, its just performance wont be as great
#8249
FL
#8250
MO
