Lunchboxer's TXT-1 project...
#2601
RE: Lunchboxer's TXT-1 project...
I could maybe do a 6x6, but as you mention lunchboxer, i would have to modify the middle axle, however, I've never seen it done on a TXT/Jugg axle or any other for that matter...
#2602
#2603
WOW!! 24 Lbs. Pretty huge due to running brushless motors it still tops 21 MPH.
Dont let that speed fool you either, a big truck like that going 21MPH is equal to a clod going 35MPH.
is this better???
is this better???
#2604
ORIGINAL: Lunchboxer
This link might give you some ideas:
http://www.beanos.com/~tsoutij/tikiw...moet+6WD%2F6WS
but it wouldnt be so high up! that looks like it would tip over on just about any turn that you were going more than a few mph on!
also i would be fabbing the body from scratch...
still just ideas...
#2605
Anyone got any ideas about hop up shocks? I mean any other than Tamiyas quite expensive set.
How long are the stock shocks center hole to center hole when unloaded?
#2607
Without measuring them, I think they are pretty standard 4" shocks.. but I can confirm for sure when I get home...
http://www.rcmart.com/catalog/produc...ducts_id=21460
I guess the Yearacing kit with 110mm may work?
http://www.rcmart.com/catalog/produc...ducts_id=20087
Or 100mm?
http://www.rcmart.com/catalog/produc...ducts_id=20086
Anyone tried any of the above kits?
The Tamiya kit looks a little bit 'old' designwise.
#2608
The first item you listed -> those are the tiny shocks from TLT.. on a Clod / Bullhead, you run 2 of those at each corner..
Not what you want for your TXT..
You need bigger bore shocks..
Tamiya actually released a TXT specific hop-up shocks.. they are discontinued, however...
You can use the rear of the DF-03 hop-up shocks!! But that means you'd need 2 sets! [:@]
#2609
#2610
Hmm.. since you got a DI, maybe you can go home and measure the rear shocks of your stock DI?!
I thought they are 100mm for the rear.. and maybe 80mm up front?!
#2611
Those integy shocks work great on my TXT! I've been using them just fine, even if they are for a E-Maxx.
They dont fit the Blackfoot EX however, got buggy oil filled shocks on it so it looks like a race truck kind-of,
but wont be racing it, no point it's a cheap basher that I built.
#2612
ORIGINAL: bmaglinger
#2614
Just measured, the stock TXT shocks, eye to eye = around 3.75"
I'd say any 4" shocks would work... !!
I just measured the DI rear and front shocks also. They are 96mm rear, and 75mm front center hole to center hole.
I don't think I'll buy 2 DF03 kits though. A little wasteful.
#2615
WOW. Chesk out the 40 series 23mm adapters. Cheap too.
http://stores.ebay.com/Bizarre-Hobbi...QQftidZ2QQtZkm
Looks like Bizarre Hobbies have quite a few hopups for the TXT.
#2617
Not wasteful if you use the 2 sets of front shocks on something else....
ORIGINAL: ArildS
96mm then.
96mm then.
#2619
Are you sure moving to GPM is considered "upgrade"?!
3Racing shocks for the DF03 are at about 25USD per set. I guess they would be good enough.
#2620
Keep us posted ArildS! But maybe first thing first, build it up and run it!! I want to see those big paddles in action!
#2621
#2623
Or drive w/ one hand and take pics w/ the other?! hee hee..
Only the mirror reflex is good enough to get good action shots.
Problem is only to have the time. [:@][:@][:@]
#2624
LOL, yeah.. looking forward to the action shots!
So what are you working on right now?! I see that you got Frog and Hornet as up next.. you ordered those yet!
#2625
