Tamiya F-150 Race Truck
#176
RE: Tamiya F-150 Race Truck
The chassis is all plastic, the body is just a Lexan Shell. You would need to wrap the ESC,Reciever, and Servo in some sort of cover...
It's not going to be easy to full waterproof anything like this.
It is a cool model that is relatively cheap though!
#177
MN
How good is the flex and stuff like that.
I'm going to be using this as an all around truck.
Also, is the ground clearance any good?
Thanks for answering all my questions!
#180
I think the ground clearance on the F-150 is decent.. but it is more of a rally car.. i.e., for gravel / dirt.. it is not meant for crawling over big rocks..
For a lot of flex, you can look into cars that have solid axles.. but then, of course, you gave up some handling right there..
So there's always a trade off....
#182
No doubt the F-150 will handle a lot better on less rough surface... TLT will have more potential for crawl over big rocks.. BUT, at stock form, the TLT isn't much of a crawler either.. due to the low ground clearance.. but you can modify it, etc.
#188
MN
ORIGINAL: rc monkey
[X(] how is it that size? ots massive!
ORIGINAL: hunter306
16ins Long x 7ins Wide
I was thinking the same thing.
#189
It's really not that big... consider my XXX-T is even wider!!
The measurements are directly from the top of the body shell.
16ins long, 7ins wide. No exageration.
#192
MN
I wonder if my parma bronco shell would fit....
AWESOME!!!
I just measured it and it's 7 1/4 inches wide and 15 1/2 inches wide.
I'm gonna do that with mine.
That would look really scale!!!
AWESOME!!!
#193
MN
Just keeping this thread alive....
I plan to purchase this truck and thank you hunter306 for the guide!!
Is it worth everything and what is the stock motor?
On tower it just says 540 size, no turn specs and such.
#194
Rofl, keeping it alive after one day! We don't forget that easily...
Stock motor= silver can. 27t. comes with tamiya kits. Its a long lasting motor, good for runtimes, but it's a bit slow. Remember, this isn't really designed for anything faster.
#195
MN
Yeah, It's gonna be fun in the snow!!
I'm just coming over from URC and over there, if a thread is on the next page of threads, it's a month old.
Is that a sealed can motor?
#196
No the stocker is not a sealed can. It is just a standard mabauchi motor (about 27t).
I run it in my lunchbox and it has been going strong for a long time. I ran it in the F-150 for about 2 runs, but it is a little slow.
If you have a chance, a 19t motor makes this thing FAST. 19t is almost too much, due to the slimmer wheelbase. Regardless, this is a fun little truck and seems to be pretty capable overal. Plus, I love the "Mud Terrain" tires it comes with, they look really cool.
#198
MN
Last I check in the T-Egg thread you made you had TLT tires on it....
I just won the photo contest on URC and got a $30 gift certificate to towerhobbies. I think I might pick one up...
#199
Yeah, that's why I said, same tires as my "stock" T-Egg...
Congrats on the win!!! NICE!!
ORIGINAL: aircruiser
